Charmaine12 3rd Gear November 6, 2014 Share November 6, 2014 HiAnyone knows what the reason. Was waiting for traffic light , idling and car died off.Then start but next traffic light .. same thing happenIs it battery low ? ↡ Advertisement Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic November 6, 2014 Share November 6, 2014 Time to change car Jk Is it rpm below normal level? Link to post Share on other sites More sharing options...
Yeshe Turbocharged November 6, 2014 Share November 6, 2014 Hi Anyone knows what the reason. Was waiting for traffic light , idling and car died off. Then start but next traffic light .. same thing happen Is it battery low ? wat car? did it does the auto restart or u manually crank to start? Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic November 6, 2014 Share November 6, 2014 wat car? did it does the auto restart or u manually crank to start? Latio bro Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 6, 2014 Share November 6, 2014 (edited) see if throttle body dirty maybe choke not enuff air at idle battery only start car, rest of time shake leg... Edited November 6, 2014 by Furrynadz Link to post Share on other sites More sharing options...
Badieboy 1st Gear November 6, 2014 Share November 6, 2014 How long has it been since you cleaned your throttle body? Clean it plus clean the idle air control valve. The valve is choked with carbon. Link to post Share on other sites More sharing options...
NightWind 4th Gear November 6, 2014 Share November 6, 2014 If your engine rpm is fluctuating, it maybe an ecu problem. Get the car towed back to nissan fer assessment Latio bro Link to post Share on other sites More sharing options...
Watwheels Supersonic November 7, 2014 Share November 7, 2014 I wonder TS regularly send his car for servicing. TS you are not one of those who service car once a year? Link to post Share on other sites More sharing options...
Kb27 Supersonic November 7, 2014 Share November 7, 2014 Hi Anyone knows what the reason. Was waiting for traffic light , idling and car died off. Then start but next traffic light .. same thing happen Is it battery low ? Not battery. ECU or idling valve controlling air passage is not working properly. Due to lack of air, the engine dies. Could be due to dirty throttle body or the valve. Link to post Share on other sites More sharing options...
TL173 1st Gear November 7, 2014 Share November 7, 2014 Likely due to idle control valve, but do the cleaning on throttle body & control valve 1st. Best to strip the throttle body & control valve for thorough cleaning. If you have technical skillset, you can do it yourself else you have to bring it to workshop to do... and probably, let them diagnose 1st. Link to post Share on other sites More sharing options...
Watwheels Supersonic November 7, 2014 Share November 7, 2014 Usually it's the Mass Air Flow sensor or MAF sensor requires some cleaning. Bring to a mechanic have him spray some MAF sensor cleaner on it. Change the Engine air filter while you are there. If you have been servicing your car regularly and air filter replace periodically you won't have all the what MAF sensor or throttle body dirty. 2 Link to post Share on other sites More sharing options...
NightWind 4th Gear November 7, 2014 Share November 7, 2014 That would be me bro. Lol I wonder TS regularly send his car for servicing. TS you are not one of those who service car once a year? Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear November 7, 2014 Author Share November 7, 2014 Is it true that if i clean my throttle .. i will need to reset my ecu? Driving cvt latio Link to post Share on other sites More sharing options...
Mrmilktooth Supercharged November 7, 2014 Share November 7, 2014 Not battery. ECU or idling valve controlling air passage is not working properly. Due to lack of air, the engine dies. Could be due to dirty throttle body or the valve. should be lack of air.. my manual also suffered from this before.. until the mech gave it more air.. just let AIR in .. Link to post Share on other sites More sharing options...
Kezg1 5th Gear November 7, 2014 Share November 7, 2014 Hi Anyone knows what the reason. Was waiting for traffic light , idling and car died off. Then start but next traffic light .. same thing happen Is it battery low ? ..hv this problem too...first mechanic said throttle body dirty..get cleaned, but at night same problem... enquired from a website and send to T. C..told the sale rep the problem...they called back 3 hrs later saying diagnostic did not captured any iregularities...so suggested to change the cranshaft motion sensor as what the website reply...after that every when well...that was some 3 months ago. Maybe TS can ask outside ws to change...cheaper i guess Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear November 7, 2014 Author Share November 7, 2014 How much is the motion sensor? Link to post Share on other sites More sharing options...
Hotshot85 4th Gear November 7, 2014 Share November 7, 2014 (edited) Usually it's the Mass Air Flow sensor or MAF sensor requires some cleaning. Bring to a mechanic have him spray some MAF sensor cleaner on it. Change the Engine air filter while you are there. If you have been servicing your car regularly and air filter replace periodically you won't have all the what MAF sensor or throttle body dirty. Same thing happened to my Rex. I too, second having your MAF sensor check and cleaned first. Edited November 7, 2014 by Hotshot85 Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear November 9, 2014 Author Share November 9, 2014 Finally got my car repaired. Wasted whole sat waiting at workshop. Done it up at autosaver. Damage is about 300 ↡ Advertisement Link to post Share on other sites More sharing options...
Swift Battery Specialist | 24hrs Car Battery & Car Tyre
Another doctor in trouble
Calciphylaxis: An almost fatal disease.
The 2017 Alfa Romeo Giulia
Malaysian man about to cremate son gets phone call, telling him he has the wrong body
Harbour pilot dies after falling overboard into waters off S'pore's Southern Islands
Former Pope Benedict has died aged 95
