Davo23 Clutched June 28, 2017 Share June 28, 2017 Is RS Chip different from bluefin? How many km since remap? Any noticeable different in term of power and fuel economy? rs chip is a piggyback not remap. i can feel torque and slight improvements. ↡ Advertisement Link to post Share on other sites More sharing options...
Fett 2nd Gear June 28, 2017 Share June 28, 2017 rs chip is a piggyback not remap. i can feel torque and slight improvements. Hi bro, u mind sharing more info on the rschip, never used anyting like dat before Link to post Share on other sites More sharing options...
Davo23 Clutched June 28, 2017 Share June 28, 2017 Hi bro, u mind sharing more info on the rschip, never used anyting like dat before Hi bro, you can read the whole thread abt rschip under performance and tuning section. another alternative would be racechip ultimate but a lot more expensive. cheers! Link to post Share on other sites More sharing options...
7hm Turbocharged June 28, 2017 Share June 28, 2017 yes i did all this and slightly more than that. rims was changed immediately out of showroom, rs chip installed after 2000km. always on Ron95 and reading was 12 to 12.1kpl. of cos depends on your right foot but no need to always be light footed otherwise not fun at all. i dunno if regent used shell or motorcraft engine oil on my first servicing though. For a more direct comparison do you have data on your FC prior to installing the RSChip? I've been considering a piggyback/remap for the larger 2.0 EcoBoost as well but I'm more interested in knowing if it will be more efficient. Link to post Share on other sites More sharing options...
Davo23 Clutched June 28, 2017 Share June 28, 2017 For a more direct comparison do you have data on your FC prior to installing the RSChip? I've been considering a piggyback/remap for the larger 2.0 EcoBoost as well but I'm more interested in knowing if it will be more efficient. sorry no data cos i went for it straight after abt 2,000km. the rschip is quite ok for me and its not very expensive as well. best thing is that it can be brought over to your next car. Link to post Share on other sites More sharing options...
7hm Turbocharged June 28, 2017 Share June 28, 2017 sorry no data cos i went for it straight after abt 2,000km. the rschip is quite ok for me and its not very expensive as well. best thing is that it can be brought over to your next car. How much did they charge you for your 1.0 EcoBoost's map? Link to post Share on other sites More sharing options...
Davo23 Clutched June 28, 2017 Share June 28, 2017 How much did they charge you for your 1.0 EcoBoost's map? like i said. its not a map but a chip. Link to post Share on other sites More sharing options...
7hm Turbocharged June 28, 2017 Share June 28, 2017 like i said. its not a map but a chip. ...they have to get the appropriate map for the chip, don't they? Link to post Share on other sites More sharing options...
Davo23 Clutched June 28, 2017 Share June 28, 2017 ...they have to get the appropriate map for the chip, don't they? u can google rschip and find out more in the website. this is not a software so there are no maps. its basically to ''álter'' the parameters of the stock ecu. Link to post Share on other sites More sharing options...
7hm Turbocharged June 28, 2017 Share June 28, 2017 u can google rschip and find out more in the website. this is not a software so there are no maps. its basically to ''álter'' the parameters of the stock ecu. Last I checked most of these chips will be best with a customized map for your car, so I was curious if they charged you specifically just for the chip or whether you got a RSChip programmed specifically for your car. Link to post Share on other sites More sharing options...
Davo23 Clutched June 28, 2017 Share June 28, 2017 Last I checked most of these chips will be best with a customized map for your car, so I was curious if they charged you specifically just for the chip or whether you got a RSChip programmed specifically for your car. if you have these chips then u dun need a customised map. if you go for customised tuning then these chips are useless. rschip is compatible for most cars and is just plug and play via obd port in the car. Link to post Share on other sites More sharing options...
7hm Turbocharged June 28, 2017 Share June 28, 2017 (edited) if you have these chips then u dun need a customised map. if you go for customised tuning then these chips are useless. rschip is compatible for most cars and is just plug and play via obd port in the car. that kind I don't feel work as well as a chip programmed for your car. I mean like a generic chip I'm sure can do something, but going off RSChip web and RaceChip etc. they ask you whats your car, so I assumed there's a map specific to the engines. I can't help but feel if it's specifically tuned to improve your specific engine it would do better than a generic program... Edited June 28, 2017 by 7hm Link to post Share on other sites More sharing options...
Davo23 Clutched June 28, 2017 Share June 28, 2017 that kind I don't feel work as well as a chip programmed for your car. then you can spend 1k plus for a generic map or go for a customised tuning for your car. note that warranty will be void. Link to post Share on other sites More sharing options...
7hm Turbocharged June 28, 2017 Share June 28, 2017 then you can spend 1k plus for a generic map or go for a customised tuning for your car. note that warranty will be void. Piggyback will probably also screw with your warranty if they find the thing. At any rate I was always under the impression that these RSChip and similar things could be specially mapped for the target car, hence they charge you for a new map when you get a new car. So yours was more than 1k? Link to post Share on other sites More sharing options...
Davo23 Clutched June 28, 2017 Share June 28, 2017 Piggyback will probably also screw with your warranty if they find the thing. At any rate I was always under the impression that these RSChip and similar things could be specially mapped for the target car, hence they charge you for a new map when you get a new car. So yours was more than 1k? rschip no issue. and it will not cost close to 1k for new. i think u shd go read more abt rschip and racechip. cheers! Link to post Share on other sites More sharing options...
7hm Turbocharged June 28, 2017 Share June 28, 2017 rschip no issue. and it will not cost close to 1k for new. i think u shd go read more abt rschip and racechip. cheers! I already been to those threads a few times, but until now I don't have the simple answer to the simple question I originally ask, how much did your RSChip cost for your Focus??? Link to post Share on other sites More sharing options...
Davo23 Clutched June 28, 2017 Share June 28, 2017 I already been to those threads a few times, but until now I don't have the simple answer to the simple question I originally ask, how much did your RSChip cost for your Focus??? pls go to market place and look around. diff places diff price but its more or less ard there. just click on marketplace and type rschip! the price doesnt depend on car brands. just turbo or NA type tats all! pls note i share my experiences here and i DON'T OWE YOU anything. Link to post Share on other sites More sharing options...
7hm Turbocharged June 28, 2017 Share June 28, 2017 pls go to market place and look around. diff places diff price but its more or less ard there. just click on marketplace and type rschip! the price doesnt depend on car brands. just turbo or NA type tats all! pls note i share my experiences here and i DON'T OWE YOU anything. You don't owe me anything, and if I wanted a random marketplace price, I would've gone and done that (which I already did before). I just wanted to know what kind of real price a real Ford driver got. No need to be so hostile. If you don't want to share, you could have just said so. There is nothing wrong with that. ↡ Advertisement Link to post Share on other sites More sharing options...
2017 Hyundai i30
2017 Hyundai i30
2022 Tesla Cybertruck and the Ford Executive Challenge
New MG3 hatchback
New MG3 hatchback
Comparing Opel Astra 1.6 Twinport and Ford Focus 1.6 H/B
Ford Doing BTO, KYM?
Mitsubishi Space Star
Europe's Seven Big Car Brands In Free Fall Over Last 20 Years, Except One
In need of vehicle history software
