flashbang Turbocharged November 8, 2016 Share November 8, 2016 Top quality ramp from UK These are easy to use, but I think still safer to have a pair of jack stands below. If the ramp gives way, immediate uplorry. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 9, 2016 Share November 9, 2016 These are easy to use, but I think still safer to have a pair of jack stands below. If the ramp gives way, immediate uplorry. TUV/GS approved - very high engineering standards. The safety factor should be 4 times the rated total carrying load = 2.5 ton x 4 = 10 ton. Keep clear from those axle stands and jacks from MIC if you value your life. Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear January 28, 2018 Share January 28, 2018 Using this old thread to look for a new car jack as current piece of mine from Taobao had failed. Looking to get an upgraded lightweight aluminium 2+ to 3 ton hydraulic floor jack. Key is lightweight, dual piston, and easy operation including safety feature to prevent overload. Is there a supplier or seller locally with ready stock? Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear January 30, 2018 Share January 30, 2018 bim bim bump. Link to post Share on other sites More sharing options...
Feelucky25 Neutral Newbie January 31, 2018 Share January 31, 2018 I have a Lightweight Compact Aluminium Jack one for sale if you are interested.. Capacity: 1.5 Ton Min Saddle Height: 80mm Max Saddle Height: 370mm Weight: 11.5 kgs Dual Parallel Pump System Used only once and still very good condition with 6 month warranty $200.00 Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 31, 2018 Share January 31, 2018 I have a Lightweight Compact Aluminium Jack one for sale if you are interested.. Capacity: 1.5 Ton Min Saddle Height: 80mm Max Saddle Height: 370mm Weight: 11.5 kgs Dual Parallel Pump System Used only once and still very good condition with 6 month warranty $200.00 If yr is a USA make alum racing car jack and only use once, yr offered price is extremely low. Yr pocket much be very deep . Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear January 31, 2018 Share January 31, 2018 Can this type of 1.5 ton floor jack be used on a 2 ton SUV ? There is no plan to jack up the car's front of rear at the central area(between both front or rear wheels if you know what I mean) but the idea is to just jack up the vehicle to do simple jobs which many people may use a scissors jack(which is very unstable and unreliable) Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear January 31, 2018 Share January 31, 2018 I have a Lightweight Compact Aluminium Jack one for sale if you are interested.. Capacity: 1.5 Ton Min Saddle Height: 80mm Max Saddle Height: 370mm Weight: 11.5 kgs Dual Parallel Pump System Used only once and still very good condition with 6 month warranty $200.00 what brand is this jack. Link to post Share on other sites More sharing options...
Feelucky25 Neutral Newbie January 31, 2018 Share January 31, 2018 Can this type of 1.5 ton floor jack be used on a 2 ton SUV ? There is no plan to jack up the car's front of rear at the central area(between both front or rear wheels if you know what I mean) but the idea is to just jack up the vehicle to do simple jobs which many people may use a scissors jack(which is very unstable and unreliable) For your SUV, best to get a 2.5 Ton Jack as the one i have is mainly for low cars.. Link to post Share on other sites More sharing options...
nazerath Turbocharged January 31, 2018 Author Share January 31, 2018 Low car jacks are more costly. 4 Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear February 1, 2018 Share February 1, 2018 For your SUV, best to get a 2.5 Ton Jack as the one i have is mainly for low cars.. you got PM. Link to post Share on other sites More sharing options...
Simonraj Neutral Newbie March 20, 2019 Share March 20, 2019 I have a Lightweight Compact Aluminium Jack one for sale if you are interested.. Capacity: 1.5 Ton Min Saddle Height: 80mm Max Saddle Height: 370mm Weight: 11.5 kgs Dual Parallel Pump System Used only once and still very good condition with 6 month warranty $200.00 Still for sale do WhatsApp me. I sent you a pm ↡ Advertisement Link to post Share on other sites More sharing options...
Kia Cerato Variant 2 persistent overheating issue
Any recommended workshop with reasonable labour charges?
P2096 Check engine light
Where to get a bicycle rack for car?
Replacing fuel filter
Nissan Almera 2004 MT making whining sound
