Dark_flan 2nd Gear January 2, 2015 Share January 2, 2015 Often heard / saw discussion on engine mounting but no one really talk on this. Just to check what is the frequency to get this changed? I have been driving for 200,000+ km without changing this but did not notice any erratic behaviour except some vibration during stopping @ traffic lights other than that car behave like new car shifting smoothly throughout and no jerking @ all. This is obvious especially in D gear. Engine mounts checked still working well and in good condition. Pls advise on this before I carry out this maintenance. ↡ Advertisement Link to post Share on other sites More sharing options...
Marcostan 4th Gear January 2, 2015 Share January 2, 2015 Transmission mounting spoil will not affect the shifting. In my case since I am changing the EM the workshop just change the TM at the same time. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 3, 2015 Share January 3, 2015 my fren's altis oso 200+k km, engine mounting not so good, car vibrates more during idling at D. he put to neutral when he stops at red light. Link to post Share on other sites More sharing options...
Kippei 3rd Gear January 3, 2015 Share January 3, 2015 When change is usually change all to balance up the mounting Link to post Share on other sites More sharing options...
Dark_flan 2nd Gear January 4, 2015 Author Share January 4, 2015 Went to seek different opinion from different workshop and claimed that my mounts are not that good as I only changed partial while old one was never changed since brand new. Heard some rattling sound when I shift to D around the rear of my engine. Does that means the rear is gone? Also is it normal for the air box to vibrate that much? All of which happens when I shift to D. Link to post Share on other sites More sharing options...
Kippei 3rd Gear January 4, 2015 Share January 4, 2015 (edited) thats the transmission mount on most of the car. the transmission mount is just underneath the airbox Edited January 4, 2015 by Kippei Link to post Share on other sites More sharing options...
Meanmachine 6th Gear January 4, 2015 Share January 4, 2015 The truth is this bro; If it ain't broke, don't change it. If it does not bother you much, don't insist on it- some car can last more than 200K mileage ( most Japs car can last that long. ) Don't change it juz becoz Ah Seng and Beng do it. it isn't much fanfare. U must be damn lucky to have a car that served you that long, it's worth the effort, speak to your car about it, not the mechanic. Your car hold truth to it. 2 Link to post Share on other sites More sharing options...
Dark_flan 2nd Gear January 6, 2015 Author Share January 6, 2015 Seen one says it underneath the air box and seen my air box really vibrating a lot at times. Think it is gone most likely. Anyway I am changing later along with my mountings. Shall update if its the cause. Link to post Share on other sites More sharing options...
Wallaw819 4th Gear January 6, 2015 Share January 6, 2015 Seen one says it underneath the air box and seen my air box really vibrating a lot at times. Think it is gone most likely. Anyway I am changing later along with my mountings. Shall update if its the cause. Most FWD cars have the trans coupled together with the engine as 1 whole block so there should not be any distinction between engine/transmission mounting. Usually there are 3/4 mountings and ws always recommend to chage all together one. If the airbox is vibrating so much most likely some part of the block is rubbing against it. Update us after you changed. Link to post Share on other sites More sharing options...
Dark_flan 2nd Gear January 7, 2015 Author Share January 7, 2015 (edited) Just an update. Problem resolved. Apparently the mounting is damaged resulting in the huge vibration of the air box and engine though not quite to the extent of vibration of when the car is going to stall alike. Anyway now behaving like new car with silent and smooth engine / gear changes which makes it more preposition as I intending to renew my car longer since car prices are still so expensive. Edited January 7, 2015 by Dark_flan 3 Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear January 7, 2015 Share January 7, 2015 Hi Darkflan, your car is toyota? How much you paid in total for the engine mount inclusive of labour huh... Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 7, 2015 Share January 7, 2015 Just an update. Problem resolved. Apparently the mounting is damaged resulting in the huge vibration of the air box and engine though not quite to the extent of vibration of when the car is going to stall alike. Anyway now behaving like new car with silent and smooth engine / gear changes which makes it more preposition as I intending to renew my car longer since car prices are still so expensive. good to do "preventive maintenance" before vibration severe n affects other parts like drive shafts n wheel bearings. not to mention handling & comfort of ride Link to post Share on other sites More sharing options...
Dark_flan 2nd Gear January 8, 2015 Author Share January 8, 2015 Hi Darkflan, your car is toyota? How much you paid in total for the engine mount inclusive of labour huh... I had paid $330 all engine/gear box mountings inclusive of labor. Yes it's a Toyota. good to do "preventive maintenance" before vibration severe n affects other parts like drive shafts n wheel bearings. not to mention handling & comfort of ride True since I intend to renew this ride so its better to do it before anything happens after. This ride never fails me for so many years since brand new so should last beyond the validity and still looks brand new outside and inside. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear January 8, 2015 Share January 8, 2015 I had paid $330 all engine/gear box mountings inclusive of labor. Yes it's a Toyota. True since I intend to renew this ride so its better to do it before anything happens after. This ride never fails me for so many years since brand new so should last beyond the validity and still looks brand new outside and inside. bro, did you buy the replacement mounting from a stockist? or was everything provided by the workshop you went to? which workshop is that? Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear January 8, 2015 Share January 8, 2015 Hi dark-flan wah 300plus with parts and labour is cheap. Which which shop? Pls share contact. Thanksss Link to post Share on other sites More sharing options...
Kippei 3rd Gear January 8, 2015 Share January 8, 2015 I just bought $280 mount for Avante Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear January 8, 2015 Share January 8, 2015 Hi Kippei - how much yr work shop quote you for installation... Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 8, 2015 Share January 8, 2015 I had paid $330 all engine/gear box mountings inclusive of labor. Yes it's a Toyota. True since I intend to renew this ride so its better to do it before anything happens after. This ride never fails me for so many years since brand new so should last beyond the validity and still looks brand new outside and inside. wow bro, the price is super competitive - can share? if not, pm also ok, TIA. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
