Zvicki Neutral Newbie January 4, 2015 Share January 4, 2015 When pressing brake at higher speed ( about 60 km/hr and above), can hear "ge ge ge" sound and steering wheel vibrating. some time can also feel brake pedal push my foot intermittedly. would you suggest what is the problem? I am driving honda stream thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
F355 Turbocharged January 4, 2015 Share January 4, 2015 Most likely rotors needs replacing. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged January 4, 2015 Share January 4, 2015 when u brake, you can feel vibration? if yes, then rotor wrapped alrd. Link to post Share on other sites More sharing options...
Earthboy 4th Gear January 4, 2015 Share January 4, 2015 probably only part of the problem? he felt like brake pedal push his foot intermittedly. I thought that is the job of the ABS when u brake, you can feel vibration? if yes, then rotor wrapped alrd. Link to post Share on other sites More sharing options...
TJX Turbocharged January 4, 2015 Share January 4, 2015 Skim rotor disc. Shd be ok. 10 Link to post Share on other sites More sharing options...
Watwheels Supersonic January 5, 2015 Share January 5, 2015 Is it the ABS kicking in? I think it's the way you drive. Link to post Share on other sites More sharing options...
Thedecemberone 3rd Gear January 5, 2015 Share January 5, 2015 When pressing brake at higher speed ( about 60 km/hr and above), can hear "ge ge ge" sound and steering wheel vibrating. some time can also feel brake pedal push my foot intermittedly. would you suggest what is the problem? I am driving honda stream thanks. Do you brake hard all the time? It depends on the situation. At 60 km/h on dry road it should not be the ABS being activated. There would be rapid vibration on the foot pedal when the ABS is activated. I experienced it on wet MSCP where the surface is smooth cement, even at only 10 km/h the ABS will be activated because of the skid. Link to post Share on other sites More sharing options...
Watwheels Supersonic January 5, 2015 Share January 5, 2015 (edited) Do you brake hard all the time? It depends on the situation. At 60 km/h on dry road it should not be the ABS being activated. There would be rapid vibration on the foot pedal when the ABS is activated. I experienced it on wet MSCP where the surface is smooth cement, even at only 10 km/h the ABS will be activated because of the skid. That's a misconception thinking ABS only kick in in the wet. As long as the sensor detect any of the wheels lock during braking it will activate. Regardless wet or dry. Probably the tires on TS car are worn out. That could easily trigger the ABS as well. Edited January 5, 2015 by Watwheels 1 Link to post Share on other sites More sharing options...
Thedecemberone 3rd Gear January 5, 2015 Share January 5, 2015 (edited) That's a misconception thinking ABS only kick in in the wet. As long as the seonsor detect any of the wheels lock during braking it will activate. Regardless wet or dry. No lah! Don't get me wrong. I am just citing an example that even on wet road at only 10 km/h the ABS can also be activated. We all know what the ABS does. It's to prevent wheel lock and as a direct result, prevent skidding and allow the vehicle to be steered properly and safely. Edited January 5, 2015 by Thedecemberone Link to post Share on other sites More sharing options...
Zvicki Neutral Newbie January 5, 2015 Author Share January 5, 2015 thank you ALL for the diagnostic and warm suggestion. i didn't brake very hard indeed. Actually when press harder, the situation is a little better:). it happens when my wife drives the car as well. i recently changed the tires ( 1 months ago). I will send to the WS to check and report back when I have any news. thank you! Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 5, 2015 Share January 5, 2015 disc rotor, wheel alignment (front wheels hit anythin lately?), abs light up, worn shocks (mayb - not firmly pressed onto ground so cause abs).? try from cheaper to more ex solution - if alignment, centre steering wheel, measure front wheel only frontward n backward of same thread used for measuring from one side wheel to another - front > back = toe out, back > front = toe out. no confident to do send to any computer wheel alignment ws. rotor issue - if warp, check skim cost vs oem rotor cost (mine is same price, only diff w labor if replace rotor, so i replaced rotor). worn shocks - check vehicle equilibrium on level surface, check oil leak from shocks during dry weather (wet weather can confuse u w water wetting shocks), no leak doesn't mean no issue (can b too bouncy or doesn't bounce; guide is 80-120k km replace shocks; more so if hear any occasional croak / clunk / clock, esp on paving blocks). abs light up - use diagnostics, other advice unsure. above my experience, method may not b that correct but as guide. Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 5, 2015 Share January 5, 2015 If it was me I will get a professional to look at it. As for high speed braking it shouldn't be done, the best way to slow down is to take the foot off the accelerator to slow the car down and then brake at a lower speed. If you always brake at high speed means you are driving too close to the car in front. Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 5, 2015 Share January 5, 2015 TS what colour is your Honda Stream? If I see you in my rear view mirror I will certainly give way to you. Link to post Share on other sites More sharing options...
Celicar Turbocharged January 5, 2015 Share January 5, 2015 When pressing brake at higher speed ( about 60 km/hr and above), can hear "ge ge ge" sound and steering wheel vibrating. some time can also feel brake pedal push my foot intermittedly. would you suggest what is the problem? I am driving honda stream thanks. "Ge ge ge" sound may be from the Korean drama you are playing in the car. Oppa..... Link to post Share on other sites More sharing options...
Kippei 3rd Gear January 5, 2015 Share January 5, 2015 Wrapped rotor if the steering wheel vibrate 1 Link to post Share on other sites More sharing options...
Ake109 6th Gear January 9, 2015 Share January 9, 2015 Dunno what you mean by "ge ge ge" sound but it might be your brake pads wearing out. Some pads have wear indicators such that once the indictors are exposed, they make the screeching noise to warn the driver. Link to post Share on other sites More sharing options...
Airwaver 4th Gear January 9, 2015 Share January 9, 2015 When pressing brake at higher speed ( about 60 km/hr and above), can hear "ge ge ge" sound and steering wheel vibrating. some time can also feel brake pedal push my foot intermittedly. would you suggest what is the problem? I am driving honda stream thanks. Disc rotor wraped. https://www.youtube.com/watch?v=fbjKugxocMs Link to post Share on other sites More sharing options...
Zvicki Neutral Newbie January 19, 2015 Author Share January 19, 2015 I change disk rotor. problem solved. Now my ride is perfect. not worry, road friend, no need to give way :). I also fixed drive shaft (right site). hope I don't need to change any thing in coming years... ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
