  • Search this thread
  • Reply to this topic
113 replies to this topic | 287 praises
#1
Posted 09 January 2015 - 02:08 PM
pat3g
  • THREAD STARTER
  • Premium member
    pat3g
    2nd Gear
    Author Image
    229
Few months after TC launched this model. I thought it may be good for owners of Teana to share their experience here.
Overall driving experience is good,especially when I managed to get 10 KM/l  for FC on 2.5 engine.
The only issue I have is the 8" touch screen head unit, following is the problems I encountered.
1. Poor radio reception
2. Blue tooth function is bad when making call using my iPhone. Either to noisy back ground noise or bad reception.
3. Speaker humming noise even volume control is set to zero. You will be able to hear it when you switch off your air con & bring you volume control to zero.
After visiting TC service center for 3 times, I have learned that even the all new cars that comes with this HU will have the same issue. TC have yet to find any solution. I'm in touch with TC service manager regarding this issues. I keep all bros  posted if they found a solution.
Edited by HyperTonic, 10 February 2015 - 11:43 AM.
#2
Posted 09 January 2015 - 02:13 PM
RH1667
  • Premium member
    RH1667
    2Fast2Furious
    Author Image
    94,651
I believe you are using the new HU with integrated GPS?
I have upgraded mine 2 months ago.
I do not use the blue tooth function, so cannot comment.
But for radio, no reception problem so far.
For the humming noise, I did not try turning the volume to zero, so cannot comment. But when I select " video in " so that only GPS voice is activated, I do not hear any humming noise.
Hope TC can provide a solution the problems you mentioned soon to car owner affected.
Columbian78, Spring and Toothiewabbit praised this
#3
Posted 09 January 2015 - 02:22 PM
pat3g
  • THREAD STARTER
  • Premium member
    pat3g
    2nd Gear
    Author Image
    229
RH1667,
Try using the blue tooth to make phone calls & you will know what I mean.
There is no "video in" connector provided. Therefore, if you select "video in" you will only see a black screen.
Edited by pat3g, 09 January 2015 - 02:26 PM.
RH1667 praised this
#4
Posted 09 January 2015 - 02:26 PM
ruddies
  • ruddies
    2nd Gear
    Author Image
    228
Did u install rear car camera that may distort radio reception?
R u using iPhone for blue tooth? There may be some bugs depending on your ios version.
#5
Posted 09 January 2015 - 02:28 PM
pat3g
  • THREAD STARTER
  • Premium member
    pat3g
    2nd Gear
    Author Image
    229
the rear camera was come pre-installed by TC.
weather using iphone, android or nokia phones, the result is the same.
#6
Posted 15 January 2015 - 09:44 PM
voleman
  • voleman
    Author Image
    0
Hi guys
May I ask if the upgraded HU can link to smartphone (android/iphone) waze?
Thanks
#7
Posted 15 January 2015 - 10:14 PM
Micb
  • Premium member
    Micb
    5th Gear
    Author Image
    1,197
Seems like the HU issues affect both Qashqai and Teana models (at least this is what I read).
I hope TC can get their act together considering these models are higher-end models costing 140k or more.  To me, it is unacceptable to use a cheapo HU (made in C*** ?) considering paying a premium.   It should at least come with factory fitted HU with the bells and whistles for a complete integrated look.   Or at the very least, use a branded aftermarket unit like Pioneer or Alpine, etc !
I was quite interested in the Qashqai initially, but considering they go to this extent to offer a locally fitted HU with such quality.  No way for me, even we have Cefiro and Sunny in the household which have been very reliable all these years.
Gonna change brand, this time round.
#8
Posted 15 January 2015 - 11:20 PM
RH1667
  • Premium member
    RH1667
    2Fast2Furious
    Author Image
    94,651
RH1667,
Thanks, but I do not like to connect my phone to my car and make it like a speaker phone for all in my car to listen to my phone conversation.
I select " video in " and use the GPS, so still can use the map and listen to the GPS voice.
Toothiewabbit, Byteslurve, Spring, Jamesc, FourZero, Aaronlkl, Camrysfa and 2 other members praised this
#9
Posted 16 January 2015 - 08:16 AM
pat3g
  • THREAD STARTER
  • Premium member
    pat3g
    2nd Gear
    Author Image
    229
Hi guys
Thanks
The upgraded HU can be linked to smartphone (android/iphone) using blue tooth for making calls & music playback.
It's window CE OS so  I think you can't run waze. Correct me if I'm wrong.
Edited by pat3g, 16 January 2015 - 08:17 AM.
#10
Posted 19 January 2015 - 10:50 AM
pat3g
  • THREAD STARTER
  • Premium member
    pat3g
    2nd Gear
    Author Image
    229
I would like to find out is there any Teana owner having the 8" touch screen head unit encountered poor radio reception?
especially channel 93.8.
Edited by pat3g, 19 January 2015 - 10:57 AM.
#11
Posted 22 January 2015 - 11:01 AM
pat3g
  • THREAD STARTER
  • Premium member
    pat3g
    2nd Gear
    Author Image
    229
Looks like there is not many Teana owners reading reading this tread. Or could it be they have no issue with their HU and I'm just the unlucky one.
#12
Posted 27 January 2015 - 03:58 PM
pat3g
  • THREAD STARTER
  • Premium member
    pat3g
    2nd Gear
    Author Image
    229
Just an update...
I think you are right. The rear camera cabling is the culprit. On my third complaint visit to TC, they re-route the cable for the rear camera & re-configured the HU blue tooth for iPhone. I must say, the HU now works much much better now.
TC should done this right at the first installation instead of having the customer to go down so many times.
I guess I may be the first few customers that did the HU upgrading. So no choice become their guinea pig, very suay.
Edited by pat3g, 27 January 2015 - 03:59 PM.
#13
Posted 27 January 2015 - 05:04 PM
RH1667
  • Premium member
    RH1667
    2Fast2Furious
    Author Image
    94,651
Just an update...
Glad to know they managed to solve the problem.
Enjoy your ride!
2BDriver, Jamesc, Spring, Aaronlkl, Toothiewabbit and 1 Anonymous member praised this
#14
Posted 27 January 2015 - 05:15 PM
Lala81
  • Lala81
    2Fast2Furious
    Author Image
    95,847
Based on my understanding of mcf, I think you are the first teana owner ha.
Just like i'm the first accord owner Lol.
L23 praised this
#15
Posted 08 February 2015 - 10:58 AM
pat3g
  • THREAD STARTER
  • Premium member
    pat3g
    2nd Gear
    Author Image
    229
5" stock HU dosn't good compare to a 8'' upgraded HU on a 2.5 Teana.
Not sure why isn't many owner do the upgrade?
RH1667 praised this
#16
Posted 08 February 2015 - 11:18 AM
Camrytron
  • Premium member
    Camrytron
    Supercharged
    Author Image
    5,291
Bro u did the right choice.swee on 8"
How much u pay for change?
Edited by Camrytron, 08 February 2015 - 11:18 AM.
#17
Posted 08 February 2015 - 12:21 PM
ER-3682
  • Premium member
    ER-3682
    Author Image
    9,195
I think the 8" Headunit are on the later batches,because buyers wanted GPS in it,like the Mazda 6,but the original 8" unit from Japan[like the 3.5 model] will be very expensive,so Tan Chong 'sourced' cheaper [thumbsdown]  [.MIC.?] unit..to complete the thing.
Edited by ER-3682, 08 February 2015 - 12:22 PM.
Fairlady.
#18
Posted 08 February 2015 - 12:28 PM
Columbian78
  • Columbian78
    5th Gear
    Author Image
    2,163
Read the qashqai thread and it will be clear why many informed people take the stock hu or go out and do their own. I myself also has this China made hu and it failed on the day of new car collection.
#19
Posted 08 February 2015 - 02:47 PM
Camrytron
  • Premium member
    Camrytron
    Supercharged
    Author Image
    5,291
So the 5 or 8" from TC all from China.
Source from Sony or any good brand got same exact size for teana?
#20
Posted 08 February 2015 - 03:28 PM
ER-3682
  • Premium member
    ER-3682
    Author Image
    9,195
Nope,i am afraid no aftermarket Headunit can fit nicely w/o bracket...this type of Headunit,are not like the older cars,1 DIN or 2 DIN standard.
Fairlady.
Back to Japanese Talk  ·  Car Brands Top Reply to this topic
Nissan Teana
Nissan Teana  |  Rating   Submit Review
Reviewed by wpy  |  4th Gear
Unbelievably comfortable
Test drove 2.5l verson of this car in late March. To be honest, I'd initially struck the Teana off my list after reading some of the reviews on sg carmart. However, after testing numerous other Japanese and Korean cars, I eventually decided t... » Read More
Nissan Teana
Reviewed by kelvinguru  |  Neutral Newbie
Think Again, Are you Sure??
Hi everyone, Consider other makes before getting Nissan Teana. Honda Accord and Toyota Camry are the major 2 makes that you cannot leave out in your decision making. I have owned a Nissan car before before changing it to other makes.... » Read More
Related New Cars search on sgCarMart.com : Nissan Teana
Quick Reply
Tags: nissan, teana, 2014, experience and 3 more...
