  • Search this thread
  • Reply to this topic
335 replies to this topic | 66 praises
#1
Posted 19 March 2015 - 05:25 PM
Leelk
  • THREAD STARTER
  • Premium member
    Leelk
    1st Gear
    Author Image
    93
I am unsure why the previous thread about the Pioneer AVH-X8750BT was removed. Starting another one.
Question: Does AVH-X8750BT come with HDMI cable?
What's come with the box?
#2
Posted 23 March 2015 - 11:58 AM
Melbs
  • Melbs
    Clutched
    Author Image
    25
wondering the same thing why the old 8750by thread was deleted also, it had some useful and unconfirmed info about the headunit.
anyway to those that own this unit, pls reply to confirm if the unit has:
1. network mode
2. appradio mode or appradio usb
thanks
^ to the thread starter, my old 8650bt avh unit did not come with hdmi cable, so i doubt the 8750bt will have as well. only comes with a remote and a usb extension cable
Edited by Melbs, 23 March 2015 - 12:10 PM.
#3
Posted 23 March 2015 - 12:01 PM
Gaolow
  • Premium member
    Gaolow
    4th Gear
    Author Image
    896
Dose not come with HDMI cable
1. no network mode
2. appradio mode meaning you need CDIH202 for Iphone and CD-AH200C for Android phone
USB 1 is for carplay
I tried carplay..kind of cool when calling or receiving phone and also read up and reply sms..
hope they support whatsapp and other apps soon
Edited by Gaolow, 23 March 2015 - 12:05 PM.
Leelk and 1 Anonymous member praised this
#4
Posted 23 March 2015 - 12:18 PM
Melbs
  • Melbs
    Clutched
    Author Image
    25
1. no network mode
oh my the very sad news for me since it has no network mode, so i'll be sticking with my 8650bt unit then i guess as the difference between this and 8650bt is almost zero.
appradio mode, as in you can use the HU to control apps such as waze, car media player and car browser. yes you can use cdih202 or simply get any hdmi cable and lightning cable plus digital av adapter from apple for it to work. useable by using usb1 via lightning cable and hdmi via hdmi cable to interconnect to digiatl av adapter and setting your HU usb1 as iphone digital av adapter.
yes like 8650bt carplay is useable using usb1 via lightning cable and setting your HU usb 1 as iphone usb.
#5
Posted 23 March 2015 - 12:48 PM
Gaolow
  • Premium member
    Gaolow
    4th Gear
    Author Image
    896
i mean cable wise same as 8650BT..but whether dose 8650BT support
time alignment? 8750BT have this features.
Edited by Gaolow, 23 March 2015 - 12:49 PM.
#6
Posted 23 March 2015 - 03:30 PM
Kelyeo8104
  • Kelyeo8104
    Author Image
    10
8650 has time alignment. It totally improves the imaging compared to my 4450 which I've upgraded from.
#7
Posted 23 March 2015 - 10:37 PM
Leelk
  • THREAD STARTER
  • Premium member
    Leelk
    1st Gear
    Author Image
    93
Just collected my ride with 8750 installed. Haven't got chance to play with it, but it did not have the hdmi. I thought 8650 had the HDMI come with it by default. My mistake.
I saw apple car play option earlier in the setting screen. But the manual state "may not be available in all country". Have to try it.
#8
Posted 24 March 2015 - 09:35 AM
Melbs
  • Melbs
    Clutched
    Author Image
    25
8650bt has time alignment in standard mode, so that's front left and right, rear left and right plus subwoofer, but no network mode.
5750bt has time alignment in standard mode, and in network mode.
i still can't get over the fact that the top of the line 2015 avh 8750bt does not have network mode as you claimed. boo pioneer!
Leelk praised this
#9
Posted 24 March 2015 - 09:44 AM
Melbs
  • Melbs
    Clutched
    Author Image
    25
correct, came from a 5650 unit that also has no time alignment and changed to the 8650, it improved a lot on imaging and staging.
however the best improvement came when i used the 8650's rear L and R channels as front L and R midbass, while the front L and R channel as L and R tweeter on a semi active set up.
Newkid praised this
#10
Posted 24 March 2015 - 10:39 AM
Thcdaniel
  • Thcdaniel
    Author Image
    10
Bros,
I'm just wondering whats the main difference between 5750 & 8750? Dont know which one should i upgrade to.
Thanks.
#11
Posted 24 March 2015 - 07:42 PM
Melbs
  • Melbs
    Clutched
    Author Image
    25
Bros,
Thanks.
5750 is basically a 8750 without the carplay/auto android, dual zone audio, hdmi input and sd card
Edited by Melbs, 24 March 2015 - 07:49 PM.
Micb and 1 Anonymous member praised this
#12
Posted 24 March 2015 - 08:34 PM
Ddarksire
  • Ddarksire
    Author Image
    6
What version of firmware is your 8750 install with? Does it support carplay?
Understand that Aus set 8750 supports Carplay and firmware ver 1.06 is available for download for even 8650.
#13
Posted 24 March 2015 - 09:48 PM
Leelk
  • THREAD STARTER
  • Premium member
    Leelk
    1st Gear
    Author Image
    93
Mine is version 1.0. Just released only, pioneer website doesn't even have information about it, so it is natural that no other update is available.
It runs CarPlay fine, just need to turn it on at the setting screen.
Australia pioneer website host the firmwar for 8650 that you can download. Accordingly 1.06 and above would run caplay. I believe current firmware is either 1.08 or 1.09.
#14
Posted 24 March 2015 - 09:53 PM
Ddarksire
  • Ddarksire
    Author Image
    6
Thank you for your input. So far, v1.0 only works with phonecall, message and apple map right? Does siri works too?
I believe yours is a local set and updating of firmware in future (since carplay is new there maybe many upcoming updates) can be done at the local distributor?
#15
Posted 24 March 2015 - 10:22 PM
Gaolow
  • Premium member
    Gaolow
    4th Gear
    Author Image
    896
8750 out of box already support carplay. mine set is local set and carplay work fine.
currently only phone call, SMS, apple map and spotify (kind of buggy ). Siri do work as well.
Have try using carply with siri to make a call, answer call, receive and send/reply sms. Truly hand free
#16
Posted 24 March 2015 - 10:36 PM
Ddarksire
  • Ddarksire
    Author Image
    6
Good to hear that the basics are working. Esp apple map for GPS. Hopefully more app will be ready for carplay and updating of firmware is as easy as updating of iOS.
What connection do you use for carplay? USB or HDMI with adapter? Can it connect wireless with bluetooth?
#17
Posted 24 March 2015 - 10:49 PM
Leelk
  • THREAD STARTER
  • Premium member
    Leelk
    1st Gear
    Author Image
    93
I got the 8750 from my PI's subcon. I forgot to ask but it should be a local set and can get local support.
Firmware update you can do it yourself, I believe the concern is more on using the locally-supported firmware. CarPlay is not officially available in Singapore, the firmware 1.0 that came with my unit have it there and running fine.
Siri works perfectly fine, only limitation is 8750 by default cannot integrate with all my steering buttons. I press-and-hold iPhone home button to activate Siri and get Siri to call the person I tried to reach out, worked fine.
Note, there is a paragraph in the manual supplement, reproduce here:
Notice to customers with Apple CarPlauy-compatible devices
If you connect an Apple CarPlay-compatible devices to this product, you will be able to control compatible features directly from the product's screen. For details on using Apple CarPlay, please visit the website for your region (see table at right) to access the instruction manual for Apple CarPlay.
Apple CarPlay may not be available in your country or region. To learn more about country availability and compatible apps, visit http://www.apple.com/ios/carplay.
Carplay goes through the lightning cable. 8750 comes with a USB cable, your installer need to make sure it is connected to USB1. Then connect your iphone with Lightnight cable to this USB cable, enable CarPlay, voila!
#18
Posted 24 March 2015 - 10:53 PM
Ddarksire
  • Ddarksire
    Author Image
    6
I see. So it is not the control on steering wheel or the icon on the touchscreen that is use to activate siri.
For carplay, USB extension (male to female port) must be connected to USB1 at headunit, then the apple cable to the female port of the extension. Did you also provide an HDMI cable for them to install? Does different grade of HDMI affects the video output to the headunit?
#19
Posted 24 March 2015 - 10:58 PM
Leelk
  • THREAD STARTER
  • Premium member
    Leelk
    1st Gear
    Author Image
    93
There is a button on 8750 screen to activate Siri also.
I didn't expect HDMi was optional item, thought came with it. The product diagram shown in manual shows that the HDMI port is just a regular HDMI female connector, so a regular HDMI cable will work fine I suppose.
HDMI cable grade....I am not sure if you can spot the difference at such small screen.
#20
Posted 25 March 2015 - 09:48 AM
Melbs
  • Melbs
    Clutched
    Author Image
    25
For those asking how carplay works:
You do not need any other cable except your apple lightning cable plugged in usb1 of 8650/8750 for it to work. Just make sure your smart phone settings in your 8650/8750 is under usb and not digital av.
In 8650 carplay will not work with your digital av adapter(hdmi+lightning), that is solely for appradio mode.
Just plug your iphone and your 8650/8750 will automatically launch carplay.
To access siri by voice command, just make sure in your iphone settings that siri can be activated by turning on "hey siri" (plugged in usb)
You can likewise activate siri by pressing contacts and messages from the headunit and siri will ask who would you like to call or message.
Even if you are not in carplay and just in pioneers main os, you can still use siri, by pressing a dedicated button to call siri or simply say hey siri as well (plugged in usb)
No, hdmi sends digital signal, does not matter if its $5 or a $100 hdmi cable, the video quality will be the same.
Edited by Melbs, 25 March 2015 - 09:50 AM.
Back to In-Car-Entertainment  ·  Aftermarket Top Reply to this topic
Pioneer HD DVB-T2 TV Tuner (GEX-1750DVB2)
Pioneer HD DVB-T2 TV Tuner (GEX-1750DVB2)  |  Rating   Submit Review
Reviewed by Akszaksz  |  3rd Gear
Overall pleased with the product
Installed this so that my kid can watch kids channel like Octo, instead of my downloading youtube videos and play for them. Overall image is clear. Quite responsive As usual, under MSCP, basement or tunnel, can't received signal. When dr... » Read More
Pioneer AVH-X2850BT
Pioneer AVH-X2850BT  |  Rating   Submit Review
Reviewed by Mervynwm  |  2nd Gear
Impressive to have !
Changed this from X2650 to this, must say its more intuitive and nicer graphics. Only the auto bluetooth connect is taken away, otherwise is nicer to have as well.
Related Product Guide search on sgCarMart.com : Pioneer AVH-X8750BT, DVD Player
Quick Reply
Tags: pioneer, ice, avh-x8750bt and 2 more...
