Lahgal Neutral Newbie December 8, 2016 Share December 8, 2016 10 jalan pendekar 17 taman ungku tun 81300 skudai 10 is the unit number Jalan pendekar 17 is the road name Taman ungku tun is building 81300 skudai is postal code Which one should I key into the gps,thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 8, 2016 Share December 8, 2016 10 jalan pendekar 17 taman ungku tun 81300 skudai 10 is the unit number Jalan pendekar 17 is the road name Taman ungku tun is building 81300 skudai is postal code Which one should I key into the gps,thanks key in everything and see if it is similar to the attached map. Walking distance is it ? Can tabao the duck home or not ? SAF rule #1: you can do anything, but don't get caught. if get caught, act blur. Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear December 8, 2016 Share December 8, 2016 (edited) Walking distance is it ? Can tabao the duck home or not ? walk 1 min reach liao. funny thing today was there was 3 FD civics. all 3 were sliver. all 3 sg plate. Edited December 8, 2016 by Jumpmanz Link to post Share on other sites More sharing options...
Lahgal Neutral Newbie December 9, 2016 Share December 9, 2016 key in everything and see if it is similar to the attached map. SAF rule #1: you can do anything, but don't get caught. if get caught, act blur. Thank you for your detail map. Link to post Share on other sites More sharing options...
AHBA 2nd Gear December 10, 2016 Share December 10, 2016 Walking distance is it ? Can tabao the duck home or not ? There is a big pasar malam held on every Saturday at the "777" marketplace starting from 5pm. Less than 2 minutes drive from Jet's workshop You can tabao roasted duck & pork, big bun, fruits, fresh veggies, chili crabs, bakeries ........ 1 Link to post Share on other sites More sharing options...
Lahgal Neutral Newbie December 11, 2016 Share December 11, 2016 I am back home !! Really thanks for the advice given and I reach there before 9.30am . Jet Cheng is really good! Strongly recommended workshop in JB. 1 Link to post Share on other sites More sharing options...
zipping Supersonic December 12, 2016 Share December 12, 2016 My FD1 front left mud guard keep kana hit/scratch when go thru hump until crack abit, any way to replace it or remove it? 1 Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 13, 2016 Share December 13, 2016 My FD1 front left mud guard keep kana hit/scratch when go thru hump until crack abit, any way to replace it or remove it? did you lower your car? it's best you first try to identify the reason why the mud flap keeps getting hit. the mud flap is held in place by a few screws. it should be quite easy to remove it. see if it is still available from the link below. else you could buy from one of the local Honda stockists. http://www.shc-forum.com/viewtopic.php?t=258103 1 Link to post Share on other sites More sharing options...
Pentium77 Clutched December 13, 2016 Share December 13, 2016 need help from FD member, recently I encounter some knocking sound, this knocking sound happen when I move the steering wheel left and right (vehicle not moving) send to workshop and was told the gear inside power steering rack is worn that y cause this knocking sound when moving left and right. Any member encounter this knocking sound esp for FD4 as this model is using electric power steering. my front lower arm, tie rod, end rod, stabilizer link, suspension etc all replaced. Anyone can advise or encounter such sound for FD4,thanks 1 Link to post Share on other sites More sharing options...
zipping Supersonic December 13, 2016 Share December 13, 2016 did you lower your car? it's best you first try to identify the reason why the mud flap keeps getting hit. the mud flap is held in place by a few screws. it should be quite easy to remove it. see if it is still available from the link below. else you could buy from one of the local Honda stockists. http://www.shc-forum.com/viewtopic.php?t=258103 Nope...did not lower my car, have to carefully go thur humps nowadays. Mayb will remove e mudguard totally. 1 Link to post Share on other sites More sharing options...
Alfie07 Neutral Newbie December 13, 2016 Share December 13, 2016 Hi guys, need some recommendation on reliable workshop to change rear wheel bearing at a reasonable price. Link to post Share on other sites More sharing options...
Alfie07 Neutral Newbie December 14, 2016 Share December 14, 2016 There is a big pasar malam held on every Saturday at the "777" marketplace starting from 5pm. Less than 2 minutes drive from Jet's workshop You can tabao roasted duck & pork, big bun, fruits, fresh veggies, chili crabs, bakeries ........ [:p Does Jet's workshop open on sunday? Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 14, 2016 Share December 14, 2016 Does Jet's workshop open on sunday? yes, till 2pm on Sunday. after that, it's badminton time. Hi guys, need some recommendation on reliable workshop to change rear wheel bearing at a reasonable price. as spoken, you may want to get the replacement parts from the stockist i mentioned and get the failing parts replaced at Jet's workshop. Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear December 14, 2016 Share December 14, 2016 My FD1 front left mud guard keep kana hit/scratch when go thru hump until crack abit, any way to replace it or remove it? buy from taobao. dirt cheap. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 15, 2016 Share December 15, 2016 need help from FD member, recently I encounter some knocking sound, this knocking sound happen when I move the steering wheel left and right (vehicle not moving) send to workshop and was told the gear inside power steering rack is worn that y cause this knocking sound when moving left and right. Any member encounter this knocking sound esp for FD4 as this model is using electric power steering. my front lower arm, tie rod, end rod, stabilizer link, suspension etc all replaced. Anyone can advise or encounter such sound for FD4,thanks could it be a drive shaft issue? go get a second opinion. Link to post Share on other sites More sharing options...
Alfie07 Neutral Newbie December 15, 2016 Share December 15, 2016 yes, till 2pm on Sunday. after that, it's badminton time. as spoken, you may want to get the replacement parts from the stockist i mentioned and get the failing parts replaced at Jet's workshop. ic.. thank bro, will call the no given soon. Link to post Share on other sites More sharing options...
Marlboro1983 Neutral Newbie December 20, 2016 Share December 20, 2016 Need help from bros here. I driving 2008 FD4. when driving panel'D' indicator is blinking. Tried to stop, off engine and start engine again, D indicator stop blinking. Any bro here got encounter this problem before and any ideal how to solve. Thank Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 21, 2016 Share December 21, 2016 Need help from bros here. I driving 2008 FD4. when driving panel'D' indicator is blinking. Tried to stop, off engine and start engine again, D indicator stop blinking. Any bro here got encounter this problem before and any ideal how to solve. Thank mine's a manual gearbox, so i have not seen this issue. does the owner's manual say anything about this? any strange behaviour from the gearbox recently? shift through all the gears and see if there's any issue. if there's any problem, you might see the CEL (a tap sign) being lit. since the D indicator is no longer blinking, you might want to monitor for a while to see if this issue comes back. ↡ Advertisement Link to post Share on other sites More sharing options...
Car repair and maintenance
2025 Mitsuoka M55
2025 Mitsuoka M55
Ho Hup Seng......Some good info for our Brudders
