Jefftansc Neutral Newbie April 29, 2017 Share April 29, 2017 Just curious to know how much you paid for your FD4? . ThanksI pay 23k for that civic. How abt you? I just went to mechanic to do servicing, engine oil seem leaking. He say honda car tend to leak fron the gasket. How much you pay for FD4? ↡ Advertisement Link to post Share on other sites More sharing options...
Mali 1st Gear April 29, 2017 Share April 29, 2017 I pay 23k for that civic. How abt you? I just went to mechanic to do servicing, engine oil seem leaking. He say honda car tend to leak fron the gasket. How much you pay for FD4?I bought mine as new car in 2008 and have been driving Since. Back then I paid 73 k . Cannot get any new car for that price now Link to post Share on other sites More sharing options...
Jefftansc Neutral Newbie April 29, 2017 Share April 29, 2017 I bought mine as new car in 2008 and have been driving Since. Back then I paid 73 k . Cannot get any new car for that price now ð. The dealers only offering 1k above scrap value now for my car if I trade in. Plain Crazy the amount of money these guys want to make . Recently had to fix a leak in the VTec valve gasket. Other than that the usual wear and tear stuff . This has been my most reliable car and hence will renew COE. Ok. So you are expert. I have been driving toyota for 10 years and the car scrapped last year. Has always want to try honda and till now, quite happy with it. Anyway nicr chatting with you. Keep in contact Link to post Share on other sites More sharing options...
Lilukl 1st Gear April 30, 2017 Share April 30, 2017 I also just got 08, FD1 less then two months, there are few items need to fix. 1. Oil leak from engines top cover and V tech - Buy top cover rubber gasket and vtech gasket. 2. Power steering leak - can buy power steering repair kit 3. Front shock absorber, mounting, stopper and cover all need to change 4. Drive shaft cover need to change at driver side 5. Front lower are passenger side need to change Car powerful but FC is around 10km/L. Currently use the apps to keep track the monthly FC Link to post Share on other sites More sharing options...
jcchia 3rd Gear April 30, 2017 Share April 30, 2017 That may cost u ard 1.5-2k. Dun mind sharing what apps u using to monitor fc? Thanks Link to post Share on other sites More sharing options...
Lilukl 1st Gear April 30, 2017 Share April 30, 2017 Fuelio, for Android. For Front absorbers, original or kyb? Any one can advice? Original abt 135 while kyb 120 Link to post Share on other sites More sharing options...
vinceyeo82 Neutral Newbie April 30, 2017 Share April 30, 2017 Just curious to know how much you paid for your FD4? . Thanks got mine for 43k last sept. with renewal of 5 year COE so far i have replace engine gasket, vtec gasket, rear wheel bearing ( both side) and engine mounting. next in line is suspension system. But not sure whether to replace the absober only or the entire set Link to post Share on other sites More sharing options...
jcchia 3rd Gear May 1, 2017 Share May 1, 2017 It good to replace as a set, old parts may wear off much easier in contact with new..... Link to post Share on other sites More sharing options...
Ignissport 4th Gear May 5, 2017 Share May 5, 2017 (edited) Any bro here installed a gearbox oil cooler..for their AUTO Fd...thinking of doing so saw this on carousel https://carousell.com/p/honda-civic-fd-atf-cooler-93685690/?ref=search&ref_query=gearbox%20oil%20cooler&ref_rank=11&ref_referrer=%2Fsearch%2Fproducts%3Fquery%3Dgearbox%2520oil%2520cooler see already like very shiok... Edited May 5, 2017 by Ignissport Link to post Share on other sites More sharing options...
Ichibawa 5th Gear May 5, 2017 Share May 5, 2017 Any bro here installed a gearbox oil cooler..for their AUTO Fd...thinking of doing so saw this on carousel https://carousell.com/p/honda-civic-fd-atf-cooler-93685690/?ref=search&ref_query=gearbox%20oil%20cooler&ref_rank=11&ref_referrer=%2Fsearch%2Fproducts%3Fquery%3Dgearbox%2520oil%2520cooler see already like very shiok... You don't track and your car is not made to track so don't waste money. Just change Honda original ATF and you will be OK. If that thing is mounted in front of the radiator then you risk overheating the engine to cool the gear box? Stay stock is best. The more things you put in the car is directly proportion to your chances of screwing up the car. 2 Link to post Share on other sites More sharing options...
Lilukl 1st Gear May 9, 2017 Share May 9, 2017 Any one can comments use SACH ($100) n SHOWA ($91)suspension? Which one to get? Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear May 9, 2017 Share May 9, 2017 Any one can comments use SACH ($100) n SHOWA ($91)suspension? Which one to get? Showa is the OEM for Honda dampers. i have been using them since i bought the car. for normal driving, Honda dampers are more than sufficient. Link to post Share on other sites More sharing options...
Lilukl 1st Gear May 9, 2017 Share May 9, 2017 Showa is the OEM for Honda dampers. i have been using them since i bought the car. for normal driving, Honda dampers are more than sufficient.Thanks for your input. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear May 9, 2017 Share May 9, 2017 Thanks for your input. btw, are you referring to Showa-branded or Honda-branded dampers? i was not able to locate Showa-branded dampers, hence i ended up with the Honda-branded ones. they are basically the same except the ones with the H logo cost more. Link to post Share on other sites More sharing options...
Lilukl 1st Gear May 10, 2017 Share May 10, 2017 Any one bought spare part from Tenage Jaya before? How their service? Plan to buy tokico Thailand make suspension from them btw, are you referring to Showa-branded or Honda-branded dampers? i was not able to locate Showa-branded dampers, hence i ended up with the Honda-branded ones. they are basically the same except the ones with the H logo cost more.Showa branded, cost 91 with GST Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear May 10, 2017 Share May 10, 2017 Any one bought spare part from Tenage Jaya before? How their service? Plan to buy tokico Thailand make suspension from them Showa branded, cost 91 with GST i believe someone did. he mentioned the shop had Honda spare parts and their prices were relatively lower. there's another shop along the same row as well. Jati Auto. which shop sells Showa-branded dampers? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 12, 2017 Share May 12, 2017 how much are you guys paying for those buying COE civics or Type R? heard that COE cars only can buy 3rd party? No comprehensive cover correct? Link to post Share on other sites More sharing options...
Lilukl 1st Gear May 12, 2017 Share May 12, 2017 i believe someone did. he mentioned the shop had Honda spare parts and their prices were relatively lower. there's another shop along the same row as well. Jati Auto. which shop sells Showa-branded dampers? http://thianseng.com ↡ Advertisement Link to post Share on other sites More sharing options...
Car repair and maintenance
2025 Mitsuoka M55
2025 Mitsuoka M55
Ho Hup Seng......Some good info for our Brudders
