QQDreamer 4th Gear April 5, 2015 Share April 5, 2015 Hi All, Does a weak radiator fan/ motor cause the car to overheat? My car radiator fan is running, however after about 30mins of driding the temp will go up more than half gradually. And when moving, it will sometimes come down depends. Usually stop sometimes the temp willdo down. Is it radiator "choke"? or water pump faulty or thermostat? Any bros can advise or have similar experience before. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 5, 2015 Share April 5, 2015 Hi All, Does a weak radiator fan/ motor cause the car to overheat? My car radiator fan is running, however after about 30mins of driding the temp will go up more than half gradually. And when moving, it will sometimes come down depends. Usually stop sometimes the temp willdo down. Is it radiator "choke"? or water pump faulty or thermostat? Any bros can advise or have similar experience before. there can be 2 speed that the radiator run. High and low. feel the wind speed of the fan with the air con turned on, if its not the "forceful" type, probably the fan is kaput. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 5, 2015 Author Share April 5, 2015 there can be 2 speed that the radiator run. High and low. feel the wind speed of the fan with the air con turned on, if its not the "forceful" type, probably the fan is kaput. the fan is still running.. but sometimes when i turn to no.2 ( as mine have 4 speed) the fan dun run i need to knock knock than fan start to turn. when aircon cuts , the fan stops, when aircon kicks in its not running ( by right should run) but other speed like 3 and 4 is ok it is running yesterday i did a pressure test at workshop. no sign of leaking. i wonder if is it the thermostat or water pump thats not working or the radiator is choke. Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 5, 2015 Share April 5, 2015 is your air con cold? some car would deactivate the fan to slower speed if there is not enough freon gas in the system. that again, if you needed to knock, high chance your fan is about to kaput. 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 5, 2015 Author Share April 5, 2015 is your air con cold? some car would deactivate the fan to slower speed if there is not enough freon gas in the system. that again, if you needed to knock, high chance your fan is about to kaput. aircon is cold. only thing is the temp will go up. i will try to change the fan motor first and monitor. if problem still persist than may be something else already. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 5, 2015 Author Share April 5, 2015 by the way anyone knows where got sell radiator fan motor? Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged April 5, 2015 Share April 5, 2015 (edited) by the way anyone knows where got sell radiator fan motor? your stockist should carry that. My Vios radiator fan coil cost $80 if I remember correctly. Other Japs/ Korean car should cost around the same range. Edited April 5, 2015 by Tigershark1976 Link to post Share on other sites More sharing options...
Toyotay Neutral Newbie April 5, 2015 Share April 5, 2015 (edited) I know what you meant, TS. Just last week , my altis had gone through the high temp when at stopping , esp when jammed during afternn when the sun is bright n hot. bring to WS , diagnosed kaput fan motor and dying radiator .. changed both ($100 + $ 290 + $80) then ok. Hope this helps Edited April 5, 2015 by Toyotay Link to post Share on other sites More sharing options...
Shibadog Turbocharged April 5, 2015 Share April 5, 2015 my Subaru fan assembly (motor + fan blades) cost $200 fm stockist changed both fan motors in the last 4 months Link to post Share on other sites More sharing options...
Kb27 Supersonic April 5, 2015 Share April 5, 2015 the fan is still running.. but sometimes when i turn to no.2 ( as mine have 4 speed) the fan dun run i need to knock knock than fan start to turn. when aircon cuts , the fan stops, when aircon kicks in its not running ( by right should run) but other speed like 3 and 4 is ok it is running yesterday i did a pressure test at workshop. no sign of leaking. i wonder if is it the thermostat or water pump thats not working or the radiator is choke. Change thermostat first. It's probably the cause. I experience twice, overheat due to thermostat. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 6, 2015 Share April 6, 2015 Most electric fans have a pair of 1/2 carbon bush that will wear over time. Once they are worn the fan will not work at its optimum speed. Link to post Share on other sites More sharing options...
Nikeair 1st Gear April 6, 2015 Share April 6, 2015 Yes, I had the same problem as well. The carbon bush for the fan has worn out. Sometimes when you knock the fan, it will jump back to life. Just change the entire fan just to be safe incase you get stuck at custom. (infact I did get stuck at custom) Link to post Share on other sites More sharing options...
flashbang Turbocharged April 6, 2015 Share April 6, 2015 Check if coolant level is correct first, as this is the easiest step and free. If overheating continues even when you have the right amount of coolant, then you know something else is wrong. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 7, 2015 Author Share April 7, 2015 (edited) I know what you meant, TS. Just last week , my altis had gone through the high temp when at stopping , esp when jammed during afternn when the sun is bright n hot. bring to WS , diagnosed kaput fan motor and dying radiator .. changed both ($100 + $ 290 + $80) then ok. Hope this helps ok noted. im thinking like wise to replace both also. Change thermostat first. It's probably the cause. I experience twice, overheat due to thermostat. thermostat is ok. cos if thermostat no open, the lower radiator pipe wont even be hot at all. but the lower radiator pipe is hot after it is warm up. Yes, I had the same problem as well. The carbon bush for the fan has worn out. Sometimes when you knock the fan, it will jump back to life. Just change the entire fan just to be safe incase you get stuck at custom. (infact I did get stuck at custom) that sounds scary.. stuck at custom and overheat... i understand your feel. Check if coolant level is correct first, as this is the easiest step and free. If overheating continues even when you have the right amount of coolant, then you know something else is wrong. coolant level is ok. nothing wrong. Edited April 7, 2015 by MkMan Link to post Share on other sites More sharing options...
TVT Supercharged April 7, 2015 Share April 7, 2015 that again, if you needed to knock, high chance your fan is about to kaput. Yup, agreed fully. Better change it asap. Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 8, 2015 Share April 8, 2015 (edited) A very simple and fast way to check for cooling system high temp location (s) is to us a non-contact infra-red thermometer. PS Even when the thermostate is in close position , the coolant will still flow via a small by-pass hose to the radiator. Edited April 8, 2015 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
Car repair and maintenance
Kent Seng Car Repairer
Teana repair/parts
Teana repair/parts
