  • 1
  • Search this thread
  • Reply to this topic
13 replies to this topic | 0 praises
#1
Posted 22 May 2015 - 11:37 PM
Kippei
  • THREAD STARTER
  • Premium member
    Kippei
    3rd Gear
    Author Image
    361
Can recommend brand.
Apparently, my car battery can start my engine quite well but it cant hold charge long enough.
When my Blackvue is running it will just drain till left 12v before it cut off. Battery CCA test show good.
What i read is the alternator quick charge doesn't really charge the battery, only top off. You need a wall charger to really deep charge the battery.
I top off the electrolyte and my specific gravity is less than 1.25 at 12 V
#2
Posted 23 May 2015 - 12:42 AM
Zippaboy
  • Premium member
    Zippaboy
    5th Gear
    Author Image
    1,210
Either get from limbat or get one from sim lim tower basement.
I got the Vanson charger from SLT.
Too many vehicles at home, so i have been using this charger to charge the batteries, so far so good. Think been using this for 5 years min....
Honestly the power magic pro not good , cut off voltage at 12V is too low.
Either you add a secondary battery (those who really into ICE will do this), or add a Cell link B.
Edited by Zippaboy, 23 May 2015 - 12:43 AM.
#3
Posted 23 May 2015 - 02:25 PM
Spinelli_ck
  • Premium member
    Spinelli_ck
    6th Gear
    Author Image
    3,360
I would recommend Ctek battery charger. easy to use and packed with features.  :D
#4
Posted 23 May 2015 - 04:02 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    32,203
To desulphate and increase specific gravity, you need a power supply, charging at 15.8V.
However, you need to monitor s.g regularly and stop charging once it reach max.
A cheap power supply I use is gopher (or gophert), look for it at aliexpress.
#5
Posted 23 May 2015 - 05:34 PM
Kippei
  • THREAD STARTER
  • Premium member
    Kippei
    3rd Gear
    Author Image
    361
i went ahead and bought ctek with recond function
#6
Posted 24 May 2015 - 10:40 PM
Kippei
  • THREAD STARTER
  • Premium member
    Kippei
    3rd Gear
    Author Image
    361
I think i over dilute the acid. Thats why the specific gravity is so low. Now using the recond function to boil off the excess water
#7
Posted 02 June 2015 - 01:10 AM
max15
  • max15
    Author Image
    -15
i also need a good quality charger
#8
Posted 02 June 2015 - 09:21 AM
Othello
  • Premium member
    Othello
    2Fast2Furious
    Author Image
    38,925
Limbat also has his in-house charger, cheaper  [;)]
"O, devil, devil! If that the Earth could teem with woman's tears, Each drop she falls would prove a crocodile. Out of my sight!" (Act IV Scene I)
#9
Posted 05 August 2017 - 10:14 AM
Limbat
  • Limbat
    Sponsor
    Author Image
    381
CTEK Battery reconditioning session by our CTEK Battery Chargers,
this SUNDAY Morning 6th August 9.30am-2pm at our ShowRoom at EastLink Building unit 03-22 -  address is on our webby- http://www.limbat.com.sg/ -
Please  call 98181138 WHATSAAP ONLY if u need direction. In celebrating National Day - we will be serving Nasi Lemak by RSVP only & Coffee / Tea on the house.
We will be demonstrating - CTEK Charging Station for a free charge at your timing.
Lim Battery.
#10
Posted 06 October 2017 - 10:09 AM
Innocuous
  • Premium member
    Innocuous
    3rd Gear
    Author Image
    405
Someone enlighten me
is it too early to have my E250 car battery and brake pad change at mileage 36k at 3 years old
Thank you .
#11
Posted 06 October 2017 - 10:17 AM
babyjyo
  • Premium member
    babyjyo
    2nd Gear
    Author Image
    189
Thank you .
You only need to change them if battery shows sign of it being weak or brake pads are worn out. E.g. Occasional problems during starting engine, brakes giving screeching sounds
#12
Posted 06 October 2017 - 01:32 PM
Phang
  • Premium member
    Phang
    6th Gear
    Author Image
    3,094
Thank you .
does your car has the stop/start system?
If yes
when the main battery is weak, the stop/start function will quit, that is a very early sign
for brake pads, different driving styles give different wear rate, E250 has pad wear sensor, you will get the message on the dash when it is due for replacement
Edited by Phang, 06 October 2017 - 01:33 PM.
#13
Posted 06 October 2017 - 01:35 PM
Innocuous
  • Premium member
    Innocuous
    3rd Gear
    Author Image
    405
If yes
for brake pads, different driving styles give different wear rate, the best is by checking the pads visually, can be done by using a torch light
Thank you for answering.
I sent my E250 for svc yday and they told me, brake pads needs to change
battery is about there , might as well and it comes w 2 years warranty.
also , one minor leaks, which I have no clue , though no indication on my digital panel, but during their checks, they saw it .
I am mostly surprise given my low usage 3 years at 36,000 km , need to change brake and batter .
But since i asked around the forum , most said is about there, PLUS / Minus
#14
Posted 06 October 2017 - 01:58 PM
Phang
  • Premium member
    Phang
    6th Gear
    Author Image
    3,094
my car has the same engine as yours (different model)
first brake pad change (front) at 50k+ km
first battery change around the 4th year
  • 1
Dynamics Mechanic Pte Ltd
Energizer Battery
Energizer Battery  |  Rating   Submit Review
Reviewed by PT55555  |  Neutral Newbie
Good product!
Purchased a new Energizer battery for my Car. Their batteries are designed for long-lasting, reliable starting power in automotive applications. I would not hesitate to recommend this to any of families or friends.
MaxPower 6000mAh PowerResQ
MaxPower 6000mAh PowerResQ  |  Rating   Submit Review
Reviewed by GongJiaoWei  |  4th Gear
Power bank with extra feature
Instead of just carrying a power bank to charge our mobile phones and ipads, this unique power bank is able to help me to jump start in car if needed. Have done comparison on some jump start kit in the marketplace. I think this is the onl... » Read More
Related Product Guide search on sgCarMart.com : Battery
Quick Reply
Tags: battery, charger, car
