BrandonNg_57942 1st Gear June 1, 2016 Share June 1, 2016 i have tried to drive for a while without i-stop. not feeling the vibration. even when engaging reverse. When did you first discover this issue? I reflected this issue during my 1k servicing, they told me this issue has been rectified for the newer YOM ↡ Advertisement 4 Link to post Share on other sites More sharing options...
rawrz 2nd Gear June 1, 2016 Share June 1, 2016 I reflected this issue during my 1k servicing, they told me this issue has been rectified for the newer YOMSo to say..Ours won't have this problem? Fingers crossed Link to post Share on other sites More sharing options...
Mazda2gal 5th Gear June 1, 2016 Share June 1, 2016 (edited) Just to clarify, YOM refers to 'Year of Manufacture'? So meaning it is a common issue for older batches of cars and acknowledged by Mazda? May I ask when was your 1k servicing? I got my car in Dec 15, and I felt this unusual vibration right from the first few days of driving. I cannot tell where the vibration came from but it seems strongest when the brake is almost fully depressed, for example when reversing the last few centimetres into the lot. I never had this issue with my first gen Mazda 2, even after 9+years. I reflected this issue during my 1k servicing, they told me this issue has been rectified for the newer YOM Edited June 1, 2016 by Mazda2gal 1 Link to post Share on other sites More sharing options...
BrandonNg_57942 1st Gear June 1, 2016 Share June 1, 2016 Just to clarify, YOM refers to 'Year of Manufacture'? So meaning it is a common issue for older batches of cars and acknowledged by Mazda? May I ask when was your 1k servicing? I got my car in Dec 15, and I felt this unusual vibration right from the first few days of driving. I cannot tell where the vibration came from but it seems strongest when the brake is almost fully depressed, for example when reversing the last few centimetres into the lot. I never had this issue with my first gen Mazda 2, even after 9+years. Yea Year of Manufacture, they didnt declare as a common issue but when I asked the service guy they are aware of the mounting issue. They will need to inspect your car and see if its indeed a mounting issue and if yes they wont change it too early until it becomes very bad. Link to post Share on other sites More sharing options...
Runforyourlife 5th Gear June 2, 2016 Share June 2, 2016 Ahhh YOM issue come liao. heng i insist on 2016 stocks. Link to post Share on other sites More sharing options...
Mrmilktooth Supercharged June 2, 2016 Share June 2, 2016 I would say my vibration is much lesser than before i change the engine mount. I still feel slight vibrations ocassionally when reversing but not as serious as before. with istop off? no vibration now after your mounts changed? this i need to test again... if not need to highlight to change them.. how long did tek take to change yours? Link to post Share on other sites More sharing options...
UncleSky 2nd Gear June 2, 2016 Share June 2, 2016 (edited) I actually noticed this vibration issue after some1 else also pointed it out... hence i became "more sensitive" then.... Before changing the engine mount, slight vibration when at stationary(i stop off) and serious vibration when reversing. I would say it is when the rpm drops very low(like when u step brake then release abit) Afte the engine mount change(which i waited for about 2months for spare to arrive), i would say it was not as serious as last time....there is still ocassional slight vibration? during reversing however i didnt really test it out Edited June 2, 2016 by UncleSky Link to post Share on other sites More sharing options...
junh 1st Gear June 7, 2016 Share June 7, 2016 Do you all wait for the High rev cold start to lower before driving off or just go straight. Tried driving off straight today and the rev drop to normal speed when I put to D. Link to post Share on other sites More sharing options...
Mrmilktooth Supercharged June 7, 2016 Share June 7, 2016 I actually noticed this vibration issue after some1 else also pointed it out... hence i became "more sensitive" then.... Before changing the engine mount, slight vibration when at stationary(i stop off) and serious vibration when reversing. I would say it is when the rpm drops very low(like when u step brake then release abit) Afte the engine mount change(which i waited for about 2months for spare to arrive), i would say it was not as serious as last time....there is still ocassional slight vibration? during reversing however i didnt really test it out mine is normal .. only when istop off.. then will feel a little on & off.. not obvious type .. Do you all wait for the High rev cold start to lower before driving off or just go straight. Tried driving off straight today and the rev drop to normal speed when I put to D. what i do is.. on the engine... seatbelt on, lock door. drive off.. less than 10s... 1 Link to post Share on other sites More sharing options...
Cumzilla 4th Gear June 7, 2016 Share June 7, 2016 Do you all wait for the High rev cold start to lower before driving off or just go straight. Tried driving off straight today and the rev drop to normal speed when I put to D. according to manual recommend to drive off straight Link to post Share on other sites More sharing options...
rawrz 2nd Gear June 8, 2016 Share June 8, 2016 coe up up and away.. this weekend mazda2 6digit price liao Link to post Share on other sites More sharing options...
dcb Turbocharged June 8, 2016 Share June 8, 2016 Won't be as much as what i paid for my deluxe HB model coe up up and away.. this weekend mazda2 6digit price liao Link to post Share on other sites More sharing options...
rawrz 2nd Gear June 9, 2016 Share June 9, 2016 Won't be as much as what i paid for my deluxe HB model Hahaha to be fair your paper value higher. Lil bit of consolation Link to post Share on other sites More sharing options...
junh 1st Gear June 16, 2016 Share June 16, 2016 Guys is there any way to off the engine while keeping the radio on after driving? After parking, currently I off the engine and press the engine start again for the radio to on again. Any better ways? 1 Link to post Share on other sites More sharing options...
dcb Turbocharged June 16, 2016 Share June 16, 2016 You press the start button again without stepping on brakes right? Thats the only way that i know of to listen to the car's radio with engine off. Guys is there any way to off the engine while keeping the radio on after driving?After parking, currently I off the engine and press the engine start again for the radio to on again. Any better ways? Link to post Share on other sites More sharing options...
SimonSeah 2nd Gear June 16, 2016 Share June 16, 2016 You press the start button again without stepping on brakes right? Thats the only way that i know of to listen to the car's radio with engine off.Someone says to set gear to neutral and press the start button, so it only turn off engine. I haven't tried it yet. 1 Link to post Share on other sites More sharing options...
dcb Turbocharged June 16, 2016 Share June 16, 2016 Do update us if it works. Someone says to set gear to neutral and press the start button, so it only turn off engine. I haven't tried it yet. Link to post Share on other sites More sharing options...
junh 1st Gear June 16, 2016 Share June 16, 2016 Someone says to set gear to neutral and press the start button, so it only turn off engine. I haven't tried it yet. It works! Thanks! But remember to press the start twice before you leave else the car will be in acc mode. ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda EZ-6
2025 Mazda EZ-6
MAZDA 6
MAZDA 6
2017 Hyundai i30
2017 Hyundai i30
New MG3 hatchback
New MG3 hatchback
2015 Forester 2.0
2015 Forester 2.0
2019 All new Mazda 3
