Somebody 1st Gear June 26, 2015 Share June 26, 2015 anyone experienced this before? mine is a 2006 IS250. Its soaked. I've been using rolls and rolls of tissue. thrown away rolls of soaked tissue. they are soaked with a clear liquid. any ideas how to solve this and where to go to solve this? thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 26, 2015 Share June 26, 2015 air con hose that drain water out dislodged ? Link to post Share on other sites More sharing options...
Othello Supersonic June 26, 2015 Share June 26, 2015 what is the liquid ? Rain water ? I guess go to those grooming shops see if they can help. My neighbour's Jazz also like that. Everytime after rain sure to see him open boot open doors suntan Link to post Share on other sites More sharing options...
Somebody 1st Gear June 26, 2015 Author Share June 26, 2015 air con hose that drain water out dislodged ? that's possible? i shall go get that checked. thanks! Link to post Share on other sites More sharing options...
RadX Moderator June 26, 2015 Share June 26, 2015 my very first car, after rain sure to flood. There was a leak in the seal at the boot side and caused water to go in. However, that led to the 'shui' enter the car and i got much fortune after that. Look on the bright side...hahahaha 1 Link to post Share on other sites More sharing options...
Stevle 5th Gear June 26, 2015 Share June 26, 2015 happen to me b4 after repair (chain collision back in 1993). "flooding" was really bad and had to endure the trouble for quite some time until one day I decided to drive up to the top level of MSCP and stripped all the seats and carpet and sun it for the whole day. before replacing back the carpet after it was dried, i removed the drain plugs on the floor board (permanently). but that lead to another problem - crockroaches crawling inside freely - I got rid of that ride within that 12 mths. Link to post Share on other sites More sharing options...
Fitvip Supersonic June 26, 2015 Share June 26, 2015 Since it is the rear floor, it may not come from the air-con condenser. The rear screen washer ( if there is one) could be the source. Sun roof is another one. If it is rain water, it could be from any hardened weather strips. Link to post Share on other sites More sharing options...
Dualshock 1st Gear June 26, 2015 Share June 26, 2015 i used to own an IS250 and had the exact same problem...it is caused by a clogged...errr...something like a one-way plug whereby the aircon water supposed to drain out from... that plug is located just above the transmission below the carriage... solution to this...send it to my previous mechanic, aesop auto care...tell them the problem... they will jack up your car, go under the carriage, stick their hands above the transmission to unclog the plug...you'll see plenty of water drain out...after that problem solved... here is the TSB http://www.clublexus.com/forums/attachments/is-third-generation/363860d1434215305-drain-plug-clogged-l-sb-0016-10.pdf 4 Link to post Share on other sites More sharing options...
LYC 3rd Gear June 26, 2015 Share June 26, 2015 My previous civic have this prob as well. Whenever it rains, the rear seat floor will flood + the spare tyre well also. Its leaking in from the boot area. But mine is due to a bad rear collision. Link to post Share on other sites More sharing options...
Dadiao 1st Gear June 26, 2015 Share June 26, 2015 A very detail solution, Thanks ! :) Link to post Share on other sites More sharing options...
Somebody 1st Gear June 27, 2015 Author Share June 27, 2015 i used to own an IS250 and had the exact same problem...it is caused by a clogged...errr...something like a one-way plug whereby the aircon water supposed to drain out from... that plug is located just above the transmission below the carriage... solution to this...send it to my previous mechanic, aesop auto care...tell them the problem... they will jack up your car, go under the carriage, stick their hands above the transmission to unclog the plug...you'll see plenty of water drain out...after that problem solved... here is the TSB http://www.clublexus.com/forums/attachments/is-third-generation/363860d1434215305-drain-plug-clogged-l-sb-0016-10.pdf That was an awesome link! I printed it and brought it to the garage and got it sorted. Garage used a shortcut and sprayed air into the spot and cleared it. It helped the garage identify the location quickly! Thank you! 1 Link to post Share on other sites More sharing options...
Bleuzone 1st Gear June 27, 2015 Share June 27, 2015 Awesome! This is what I love about the power of a forum and sharing experiences ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
MCF HangOut X Lexus – 9 May 2024, Lexus Boutique
Lexus Finally Figured Out The Three-Row SUV
The all new Lexus UX
2024 2nd Generation Lexus LM
