MaxFactorGarage 1st Gear October 5, 2015 Author Share October 5, 2015 Bardahl Track Car - Honda Civic FD2R Track Maintenance For Sepang last week. Bardahl Syn Racing 0w30 Bardahl Maxtran 80W90 Bardahl Glycool Coolant Flushing Bardahl Dot 5.1 Racing Brake Fluid Flushing Good job Team Bardahl Racing! ↡ Advertisement Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear October 5, 2015 Author Share October 5, 2015 Nissan GTR Gearbox Fluid Recharged. Pentosin - Replacement Fluid For The Godzilla. Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear October 5, 2015 Author Share October 5, 2015 Toyota Harrier Undercarriage Maintenance Vehicle vibrates when idling and on uneven road. Lower Arm Replaced Lower Arm Ball Joint Replaced Engine Mounting Replaced Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear October 5, 2015 Author Share October 5, 2015 Subaru Impreza Air-Con Maintenance: Compressor Oil Drained & Flushed R134A Gas Renewed Cooling Coil Cleaned High Low Pressure Pipe Blockage Done The revolutionary machine for your air-conditioner system that save money on the replacement of the expensive parts. Book your appointment today to experience the power of KoolTec Air Con Revitalising Package. Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear October 5, 2015 Author Share October 5, 2015 Mitsubishi Colt General Maintenance: Bardahl Otran-CVT Changed Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear October 5, 2015 Author Share October 5, 2015 Mazda RX8 Replacing Gas Pedal With Sensor. 2nd gear above 6000RPM gave out loud noises before we changed. Problem solved after primary diagnostic. At Max Factor Garage, we dutifully check out the existing faulty part instead of amplifying the issue so as not to incur higher repair cost for our customers. Profit is important in a business but integrity and trust is our direction. Call Ben at 92302438 for more information. Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear October 5, 2015 Author Share October 5, 2015 Volkswagen Golf GTi Braking System: Front Brake Pad Replacement Bardahl SynPulsar Servicing Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear October 5, 2015 Author Share October 5, 2015 Lexus Gs300 Air-Con Servicing KoolTec Air-Con Servicing: Threebond Air-Con Cleaner Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Bardahl Concept WorkshopWith the supporting full range of Bardahl's products in store. MAX FACTOR GARAGE Synergy @ KB 23 Kaki Bukit Rd 4 #01-21 S417801 Contact Ben @ 9230 2438 Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Suzuki Every - Air-Con System Repair Condensor, Compressor, Cooling Coil, Valve Replaced 23 Kaki Bukit Rd 4 Synergy @ KB #01-21 S417801 9.30am to 6.30pm Monday to Saturday Contact Ben @ 92302438. Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Servicing For GTR: Brake Pad, Disc Rotor, Gearbox Transmission, Tuning, BodyWorks, Cosmetics. Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Opel Combo CDTI Engine: Engine Overhaul Manifold Top Gasket Turbo Downpipe Decat Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Subaru Wrx Sti Braking System Front Brembo Rotor Replacement Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Hyundai Avante Braking System: Front & Rear Rotor Replacement Front & Rear Brake Pad Replacement Fuel Pump Assy Replacement Steering Bushing ( EPS ) Replacement Door Panel Beating & Spray n Polishing Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Gearbox Repair Work: Before & After Repair Solonoid Replacement Clutch Repair Torque Converter Repair Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Engine Modification: Port & Polish Engine Cylinder Big Bore Upsize High Compression Piston Valve Skim Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Hyundai I30 Atf & Engine Oil Servicing: Bardahl Otran-MV ATF Fluid100k ATF Filter Replacement For better mileage, owner highly recommend to replaced the atf filter every 100k. Link to post Share on other sites More sharing options...
MaxFactorGarage 1st Gear November 17, 2015 Author Share November 17, 2015 Bmw E90 Braking System Replacement: Front & Rear Brake Pad Front & Rear Rotor With Sensor Cable ↡ Advertisement Link to post Share on other sites More sharing options...
Kia EV9 Concept
Kia EV9 Concept
Car repair and maintenance
The all new Lexus UX
2021 2nd Generation BMW 4 Series (G22 / G26)
President Hopeful TKL Firm Runs 4-D App Store ....
