Kevinhwc 2nd Gear July 21, 2016 Share July 21, 2016 When you insert the card, shouldn't the cam auto format? At least mine does.. ↡ Advertisement Link to post Share on other sites More sharing options...
Kevinhwc 2nd Gear July 21, 2016 Share July 21, 2016 Anyone bought the GPS unit to use the ADAS function? Any feedback? Link to post Share on other sites More sharing options...
Dscheng 3rd Gear July 22, 2016 Share July 22, 2016 When you insert the card, shouldn't the cam auto format? At least mine does.. Ya, it supposing to work this way by camera auto format? I am not sure why this samsung card has problem? I use other card no issue, can auto format too. Anyone bought the GPS unit to use the ADAS function? Any feedback? Ya, seem like not bad that ADAS function. Link to post Share on other sites More sharing options...
dcb Turbocharged July 22, 2016 Share July 22, 2016 Anyone having problem with Samsung Evo+ 64Gb micro SD card? Trying a lot of time, but the set keep saying wrong card or card damaged. I try format a few time also no luck. Anyone same situation too?Happened to me before. Unplug power to the V9 and then insert the Evo+ again. That worked for me. Link to post Share on other sites More sharing options...
Imac 5th Gear July 28, 2016 Share July 28, 2016 Anyone know where to get a good price for the V9 with installation? I have been to carousell...it seem most seller there listed their price without installation. Link to post Share on other sites More sharing options...
elmoguy 2nd Gear July 28, 2016 Share July 28, 2016 Anyone know where to get a good price for the V9 with installation? I have been to carousell...it seem most seller there listed their price without installation. From my experience that V9 QC is lousy, I think it is better for you to buy from authorized dealer so that you can have unlimited support during warranty period. Link to post Share on other sites More sharing options...
Imac 5th Gear July 28, 2016 Share July 28, 2016 From my experience that V9 QC is lousy, I think it is better for you to buy from authorized dealer so that you can have unlimited support during warranty period. Lousy ? but why it seem that it is one of the top selling brand with Blackvue and Thinkware.... Link to post Share on other sites More sharing options...
elmoguy 2nd Gear July 28, 2016 Share July 28, 2016 Lousy ? but why it seem that it is one of the top selling brand with Blackvue and Thinkware....Product is good but the Qc is lousy. I had to change cam and cables for a few times. My friend encountered pcb faulty issue. My another friend also change cam. We all bought in the same month. Link to post Share on other sites More sharing options...
Lunloon Neutral Newbie August 4, 2016 Share August 4, 2016 I just installed the V9 with the white security LED. thought something was wrong when i exit the car and the camera flash like nobody's business, then i walked away it started scrolling left to right. I have used the Itonics ITB-100HD for many years, and cameras have always been hot. It is recording, the chip is processing, the memory card is writing/reading, sure produce heat.My old car I set the camera to turn off when the ignition off cos the Power Magic Pro works like a fish out of water. Hope the voltage cut off works good (current setting 12.3V, cos OPC, use on weekends only). Havent tried to experiement if the parking recording can be turned off. Also haven updated firmware. Hope to see something good after updating. Link to post Share on other sites More sharing options...
Car_byte 3rd Gear August 4, 2016 Share August 4, 2016 Using V9 and will sometimes get a message like "..installing the program do not switch off....". Anyone care to share similar experience and what is the cause? Also on PC, any means to view recording without using the iroad viewer? Link to post Share on other sites More sharing options...
dcb Turbocharged August 5, 2016 Share August 5, 2016 Anyone used the spare double side tape for the holder yet? Gotta replace a crack windscreen tomorrow and hope the installer can change the double sided tape for me after the new solar film is pasted. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear August 5, 2016 Share August 5, 2016 I just installed the V9 with the white security LED. thought something was wrong when i exit the car and the camera flash like nobody's business, then i walked away it started scrolling left to right. I have used the Itonics ITB-100HD for many years, and cameras have always been hot. It is recording, the chip is processing, the memory card is writing/reading, sure produce heat. My old car I set the camera to turn off when the ignition off cos the Power Magic Pro works like a fish out of water. Hope the voltage cut off works good (current setting 12.3V, cos OPC, use on weekends only). Havent tried to experiement if the parking recording can be turned off. Also haven updated firmware. Hope to see something good after updating. The LED flashing is normal la. Meaning it detect motion. I dont think V9 can disable the parking. Link to post Share on other sites More sharing options...
Layang99 1st Gear August 5, 2016 Share August 5, 2016 i am currently on v7 iroad. This is merely sharing my experience with v7. At first, I have bunch of craps from V7, such as shut down frequently, annoying instruction, beeping noise, and power cut off after 2 hours in parking mode...da** frustrating. But everything started to become better, after i learn from the manual and setting it right. I changed 16gb memory to 64 gb, format every 3 weeks, setting wake up voltage to 12.7v and sleep voltage at 12v. I also do cable check occasionally, especially the cable links to rear cam. Now everything in order!!! Hi I am given a v7 on my new ride. Sleep voltage means that the cam will pwr off automatically when car batt voltage is dip to 12V right ? The installer set for me 11.8V. Am i right to say that 12V is safer ? Any recommendation for the sensitivity setting ? My default is low for both parking and motion. Link to post Share on other sites More sharing options...
Axeman24 2nd Gear August 6, 2016 Share August 6, 2016 Just an update of my IRoad V9. Have been using for the last 1 month plus. So far so good, with no issues. The voltage cut of works fine for me as I was traveling for the last 2 weeks. After reaching home, I when to check on my car and find that the camera has turn itself off. When I start the car, I do not have any problems as well. In summary, I am very happy with this camera. Link to post Share on other sites More sharing options...
Layang99 1st Gear August 7, 2016 Share August 7, 2016 Just an update of my IRoad V9. Have been using for the last 1 month plus. So far so good, with no issues. The voltage cut of works fine for me as I was traveling for the last 2 weeks. After reaching home, I when to check on my car and find that the camera has turn itself off. When I start the car, I do not have any problems as well. In summary, I am very happy with this camera.Hi Can share what is your sleep and wake up voltage settings? Link to post Share on other sites More sharing options...
Axeman24 2nd Gear August 7, 2016 Share August 7, 2016 Hi Can share what is your sleep and wake up voltage settings? I didn't check, but I remember the installer set it at 12.5V. Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear August 7, 2016 Share August 7, 2016 Hi Can share what is your sleep and wake up voltage settings? I set mine to 11.5v and it's still on the next day. U guys can get the Samsung evo + sd card from q0010. Sometimes there's a time sale and you can get a 64gb for $29.90. I just got one and inserted into the v9 then powered it on. The cam formatted the sd card. It started recording after less than 5mins. Link to post Share on other sites More sharing options...
Jq1988 4th Gear August 8, 2016 Share August 8, 2016 Hi I am given a v7 on my new ride. Sleep voltage means that the cam will pwr off automatically when car batt voltage is dip to 12V right ? The installer set for me 11.8V. Am i right to say that 12V is safer ? Any recommendation for the sensitivity setting ? My default is low for both parking and motion. best to adjust to 12v as for safety precaution. In case, morning wake up, car cannot start. Spoil the day. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Marbella DashCam Users
Car camera recommendation
Wifi IP CCTV
Wifi IP CCTV
Huawei Mate 20 Pro / Leica Camera
