Jackwolf 1st Gear May 31, 2017 Share May 31, 2017 most likely his rear camera is spoilt / not working. Mine rear camera seen like spoilt as the video is not clear at all after 1.3 years of using. Going to the Corvit to get it check soon.did your check your rear windscreen is clean and clear enough...? wahaha.. ↡ Advertisement Link to post Share on other sites More sharing options...
Azhiwen 3rd Gear June 1, 2017 Share June 1, 2017 Did a search through the thread and many are using the V9S2. Anyone using the Q9? How does it compare to the the V9S2 other than pricing and dimensions? From what I see on the Corvit website, it seems that both models are very similar. Any comments? Link to post Share on other sites More sharing options...
Leo72 6th Gear June 1, 2017 Share June 1, 2017 did your check your rear windscreen is clean and clear enough...? wahaha.. Confirm the rear windscreen is clean and clear enough.. the rear camera video is with green shadow / lots of green line as in video term (video out of sync). Link to post Share on other sites More sharing options...
Dscheng 3rd Gear June 7, 2017 Share June 7, 2017 https://www.youtube.com/watch?v=hQAWce2MFhI&feature=youtu.be Anyone encounter the video speed to be lagging? I suspect is my sandisk class 10 microSD card. I do not have this problem if i am using Samsung Evo microsd card. Link to post Share on other sites More sharing options...
Daniu82 Supercharged June 7, 2017 Share June 7, 2017 Just to inform those who are interested in V9, I think the model cannot stand heat when car is parked under the sun. When I got the camera, after 1 mth then the front cam recordings became cloudy. I went back to exchange and they told me this particular batch got this problem then they helped me change another batch but the same thing happened again. My conclusion is the problem is the V9 cam cannot stand heat and not problem with that batch. Most likely changing to another brand soon. Waste my money. Link to post Share on other sites More sharing options...
zipping Supersonic June 7, 2017 Share June 7, 2017 https://www.youtube.com/watch?v=hQAWce2MFhI&feature=youtu.be Anyone encounter the video speed to be lagging? I suspect is my sandisk class 10 microSD card. I do not have this problem if i am using Samsung Evo microsd card. IMHO, although the sdcard states class 10 but u need to also chk e read/write speed of e said sdcard, they are not all created equally. Class 10 is just a general yardstick that require e sdcard to a minimum sequential write speed of 10MB/s 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 7, 2017 Share June 7, 2017 Yah, must see the write speed too. Link to post Share on other sites More sharing options...
Titanium 4th Gear June 7, 2017 Share June 7, 2017 IMHO, although the sdcard states class 10 but u need to also chk e read/write speed of e said sdcard, they are not all created equally. Class 10 is just a general yardstick that require e sdcard to a minimum sequential write speed of 10MB/s I using this for my v9, so far so good! Link to post Share on other sites More sharing options...
Kzone 3rd Gear June 7, 2017 Share June 7, 2017 Just to inform those who are interested in V9, I think the model cannot stand heat when car is parked under the sun. When I got the camera, after 1 mth then the front cam recordings became cloudy. I went back to exchange and they told me this particular batch got this problem then they helped me change another batch but the same thing happened again. My conclusion is the problem is the V9 cam cannot stand heat and not problem with that batch. Most likely changing to another brand soon. Waste my money. Yeah, if its a known batch problem then they should simply get rid of that batch fm circulation. I also wanted to get the V9 but I think I will hold on to my Yi cam for awhile. Link to post Share on other sites More sharing options...
Stitch Neutral Newbie June 7, 2017 Share June 7, 2017 Hi Does anyone know why my recording file is in "impact" mode instead of "motion" mode? Thanks in advance for advice. Link to post Share on other sites More sharing options...
FinalNitro 2nd Gear June 7, 2017 Share June 7, 2017 Hi Does anyone know why my recording file is in "impact" mode instead of "motion" mode? Thanks in advance for advice. Impact is when driving, then the camera detects a spike in movement with it's g-sensor. AKA, accident. Thats why it records as impact. You'll also see the red light on your camera flashing and hear a beeping sound. But singapore roads, mine active impact mode by itself when I drive over uneven roads. Motion is when during parking mode, the camera sense motion infront of your vehicle, aka motion sensor, should be pretty self-explanatory. In this car, the front "security" led of your camera will switch from left right sweep to constant fast blinking. Link to post Share on other sites More sharing options...
FinalNitro 2nd Gear June 7, 2017 Share June 7, 2017 https://www.youtube.com/watch?v=hQAWce2MFhI&feature=youtu.be Anyone encounter the video speed to be lagging? I suspect is my sandisk class 10 microSD card. I do not have this problem if i am using Samsung Evo microsd card. Check your recording settings. Is it record in 30fps? Link to post Share on other sites More sharing options...
Dscheng 3rd Gear June 8, 2017 Share June 8, 2017 Check your recording settings. Is it record in 30fps? Yes it is 30 FPS. Sometime will lag, sometime it is ok. I also puzzled. not sure if it is the SD card or my recorder spoil. BTW i am using this type of SD card. Link to post Share on other sites More sharing options...
Stitch Neutral Newbie June 8, 2017 Share June 8, 2017 Hi FinalNitro ok noted thanks. Link to post Share on other sites More sharing options...
yokechye 4th Gear June 10, 2017 Share June 10, 2017 Just to inform those who are interested in V9, I think the model cannot stand heat when car is parked under the sun. When I got the camera, after 1 mth then the front cam recordings became cloudy. I went back to exchange and they told me this particular batch got this problem then they helped me change another batch but the same thing happened again. My conclusion is the problem is the V9 cam cannot stand heat and not problem with that batch. Most likely changing to another brand soon. Waste my money.I changed 3 times already. But it is only affecting the front cam. The rear is still very clear. Link to post Share on other sites More sharing options...
Derevor 1st Gear June 10, 2017 Share June 10, 2017 I changed 3 times already. But it is only affecting the front cam. The rear is still very clear.i changed 3 times too, mine both affected. the last time i changed i requested wshop to give me s2 version or change brand and top up accordingly or full refund, he gave without top up. no problems after that. still monitoring, 3rd mth now so far so good. frustrating indeed but what the heck, just change while still in wty and thankfully it's acknowledged and fuss free quick change. it's a known lens issue. Link to post Share on other sites More sharing options...
yokechye 4th Gear June 10, 2017 Share June 10, 2017 i changed 3 times too, mine both affected. the last time i changed i requested wshop to give me s2 version or change brand and top up accordingly or full refund, he gave without top up. no problems after that. still monitoring, 3rd mth now so far so good. frustrating indeed but what the heck, just change while still in wty and thankfully it's acknowledged and fuss free quick change. it'sâ a known lens issue. I changed my 3rd last month and still monitoring. Hopefully can last. Praying hard. Previous ones can't last 3mths. Haiz Link to post Share on other sites More sharing options...
EdwinZhangxiaoxing Neutral Newbie June 11, 2017 Share June 11, 2017 Hi all bros, recently my front cam also suddenly very blur, bought 6months ago, rear cam still very sharp and good. Haix why like that. im using v9 too. ↡ Advertisement Link to post Share on other sites More sharing options...
Marbella DashCam Users
Car camera recommendation
Wifi IP CCTV
Wifi IP CCTV
Huawei Mate 20 Pro / Leica Camera
