Wormee 5th Gear September 4, 2016 Share September 4, 2016 I shall be offensive and say that the Avanza is simply crap. Even if they don't bring in Sienta, they should still stop selling it. I previously shared on the Avanza thread that you still need to pinch the radio antenna out of the A-pillar. http://www.mycarforum.com/topic/2688217-toyota-avanzas-price-benchmarked-against-vw-touran/page-11?do=findComment&comment=5822117 Other cons can be forgiven for the price owners paid. (Frankly speaking 100k+ is consider cheap for a MPV during this era when COE is these kind of price.) What is ridiculous is the metal pinch out antenna from the A pillar. Really speechless... ↡ Advertisement Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear September 4, 2016 Share September 4, 2016 Hi Sienta owners, how is the aircon for those on 2nd row and 3rd row... sufficient? 1 Link to post Share on other sites More sharing options...
Mkl22 Twincharged September 4, 2016 Share September 4, 2016 Why no one mention the Indo Sienta central console plastic looks alot cheaper than JDM Sienta... esp that new climate control housing. Lots of shiny, brittle looking plastic there And the Indo Sienta climate control has no heater inside...unlike JDM version. And no inbuilt Panasonic Nanoe air purifier inside. Does it matter if there is no heater? Anyway the Indonesia engine is catered for poorer fuel quality in the region. If you frequent Thailand then it makes a diff. 1 Link to post Share on other sites More sharing options...
Amoslowlc 5th Gear September 4, 2016 Share September 4, 2016 Hi Sienta owners, how is the aircon for those on 2nd row and 3rd row... sufficient?Put fan speed at 6 and above, thr 3rd row can feel it.Install solar film to the max legal limit will help. 1 Link to post Share on other sites More sharing options...
Eeee78 Neutral Newbie September 5, 2016 Share September 5, 2016 Hi Sienta owners, how is the aircon for those on 2nd row and 3rd row... sufficient? No complains from my passenger. 1 Link to post Share on other sites More sharing options...
Wormee 5th Gear September 6, 2016 Share September 6, 2016 No complains from my passenger.Same here. Had Vkool for the whole car and passenger say can feel aircon with fan speed at 4 with blower facing up. 1 Link to post Share on other sites More sharing options...
JuzFXT 2nd Gear September 17, 2016 Share September 17, 2016 BM bringing in this to replace their wish~ Link to post Share on other sites More sharing options...
Raubern 6th Gear September 17, 2016 Share September 17, 2016 Heard BM Sienta will be assembled in Indonesia. Really? Link to post Share on other sites More sharing options...
X18 2nd Gear September 17, 2016 Share September 17, 2016 Heard BM Sienta will be assembled in Indonesia. Really? Yes. The Sienta model brought in by BM is assembled in Indonesia. It is using an older 1.5l engine however with the advantage of a top mounted cooler for the rear passengers. BM will launch the Sienta in October. Link to post Share on other sites More sharing options...
jasonkstan Clutched September 17, 2016 Share September 17, 2016 The Sienta that BM going to bring in is using 2NR-FE engine which is same as the Avanza (current version). 2NR-FEA 1.5 (1496 cc) variant of the NR series engine. First introduced in Q4 of 2010 for the Toyota Etios. It is the first new engine Toyota developed for over 8 years without VVT-i. Done to reduce cost for the low-cost Toyota Etios. A new innovation that made its introduction on this engine is the integration of the exhaust manifold into the cylinder head to reduce emissions. A Dual VVT-i equipped version was first used in Toyota Avanza. Technical specifications of the engine: Displacement: 1496 cc Bore x Stroke: 72.5 mm × 90.6 mm (2.85 in × 3.57 in) Max. Output:66 kW (90 PS) at 5600 rpm (w/o Dual VVT-i) 79 kW (108 PS) at 6000 rpm (with Dual VVT-i) Max. Torque:132 N·m (97 lbf·ft) at 3000 rpm (w/o Dual VVT-i) 139 N·m (103 lbf·ft) at 4200 rpm (with Dual VVT-i) Compression Ratio: 11.5:1 Idling speed: 500 rpm Redline: 5,850 rpm Applications: Toyota Avanza (w/Dual VVT-i) Toyota Etios Toyota Etios Cross Toyota Sienta (w/Dual VVT-i) Toyota Vios (w/Dual VVT-i) Toyota Yaris (w/Dual VVT-i) Link to post Share on other sites More sharing options...
Alheych 6th Gear September 18, 2016 Share September 18, 2016 The Sienta that BM going to bring in is using 2NR-FE engine which is same as the Avanza (current version). 2NR-FEA 1.5 (1496 cc) variant of the NR series engine. First introduced in Q4 of 2010 for the Toyota Etios. It is the first new engine Toyota developed for over 8 years without VVT-i. Done to reduce cost for the low-cost Toyota Etios. A new innovation that made its introduction on this engine is the integration of the exhaust manifold into the cylinder head to reduce emissions. A Dual VVT-i equipped version was first used in Toyota Avanza. Hopefully consumers band together and make sure it goes the same way as the Thai HRV... giving us lower tech just because they are the AD simple isn't acceptable anymore. Link to post Share on other sites More sharing options...
inlinesix Supersonic September 18, 2016 Share September 18, 2016 Hopefully consumers band together and make sure it goes the same way as the Thai HRV... giving us lower tech just because they are the AD simple isn't acceptable anymore. TMAP will not care whether you gonna band together. Singapore is such a small mkt as compared to MY, TH & ID. Link to post Share on other sites More sharing options...
Amoslowlc 5th Gear September 18, 2016 Share September 18, 2016 TMAP will not care whether you gonna band together. Singapore is such a small mkt as compared to MY, TH & ID.Yes. You and all potential customers can DONT BUY. 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged September 18, 2016 Share September 18, 2016 TMAP will not care whether you gonna band together. Singapore is such a small mkt as compared to MY, TH & ID. agree we r small market, but then wat makes kah get jap spec vezel? Link to post Share on other sites More sharing options...
inlinesix Supersonic September 18, 2016 Share September 18, 2016 agree we r small market, but then wat makes kah get jap spec vezel? TMAP is importer of Toyota in Sg. BM is juz AD. Since JDM Sienta is designated as JDM, TMAP will not bother with what's consumer here thinks. If not, why do you think they bring in Avanza? Rather than JDM Sienta Link to post Share on other sites More sharing options...
Alheych 6th Gear September 18, 2016 Share September 18, 2016 agree we r small market, but then wat makes kah get jap spec vezel? Yes, that's why don't underestimate the power of banding together. Cases in point: 1. KM having to import Japanese spec Vezel as the HRV to replace the Thai variant beacuse they are losing too much to PI. 2. BM finally importing the Wish after 3 years of head start by PI. TMAP may not care but BM will make noise if they lose out. 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged September 18, 2016 Share September 18, 2016 TMAP is importer of Toyota in Sg. BM is juz AD. Since JDM Sienta is designated as JDM, TMAP will not bother with what's consumer here thinks. If not, why do you think they bring in Avanza? Rather than JDM Sienta I'm asking about kah Link to post Share on other sites More sharing options...
Cheefarn 5th Gear September 19, 2016 Share September 19, 2016 TMAP is importer of Toyota in Sg. BM is juz AD. Since JDM Sienta is designated as JDM, TMAP will not bother with what's consumer here thinks. If not, why do you think they bring in Avanza? Rather than JDM Sienta SG is part of ASEAN. Part of the agreement was that we need to import a fair number of ASEAN assembled cars as part of the deal. For BM, most of their cars are already from Thailand. Fortuner used to be from Indonesia, latest model is back from Thailand again, and of cos we have the Hilux pickups, POS Avanza and Vios from Indonesia. Our Altis and Camries are from Thailand of cos. In today's world, it is normal for your products to be produced anywhere in the world. Made in Japan doesnt mean it is perfect. For Toyota, most of the models you guys are buying are already designed and built for ang moh markets... Eg.... Altis and Camries are not sold in JDM... too big and too American for those 60-70 yr old Japs folks.. See how the Axio is design and built and you have a good idea Toyota target audience are over there ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
