Cheefarn 5th Gear October 5, 2016 Share October 5, 2016 just sharing my exp after brief test drive last week - - ride is reasonably comfortable on 15" alloys (test drive being standard model) do note turning radius is different for 15" & 16"; one at 5.3m & another 5.7m respectively - if ladder chassis means riding on stilts, then i believe sienta is not this type, but it is 25mm higher than jdm sienta - not sure what steering sienta was on, but didnt feel like i gotta turn alot; typical toyota car character - easy to handle - current sienta on cvt wc i believe at 100kph will be around 2k rpm (even my current korean 4at "only" 2.5k rpm at 100kph) avanza is one very backward tech model based on tractor / pickup.. bm should have nvr brought in this model. if i own avanza sure very hard to sell due to a backward model wc prev cost 120k at high coe era.. https://www.youtube.com/watch?v=-IiQFiraqPU since on this topic of steering , just sharing.. ok back to sienta The Sienta chassis is 100% car based, although I couldnt quite tell from which mainstream Toyota model. Could be the current Vios/Yaris The increased ride height was needed to clear the often neglected road conditions of Indonesia. The JDM Sienta would prob get stuck in many of their deep potholed roads LOL But I think any Sienta owners can undo the ride height changes quite easily. Toyota may had just used spacers to prop up the front and rear suspension parts... If we can just remove these spacers... ↡ Advertisement Link to post Share on other sites More sharing options...
Spring Moderator October 5, 2016 Share October 5, 2016 (edited) The Sienta chassis is 100% car based, although I couldnt quite tell from which mainstream Toyota model. Could be the current Vios/Yaris The increased ride height was needed to clear the often neglected road conditions of Indonesia. The JDM Sienta would prob get stuck in many of their deep potholed roads LOL But I think any Sienta owners can undo the ride height changes quite easily. Toyota may had just used spacers to prop up the front and rear suspension parts... If we can just remove these spacers... Noob question but why would u want to lower the car? I can only think it gives better stability n handling esp at corners? But this is an MPV afterall which is taller so I don't think it makes much difference? Edited October 5, 2016 by Spring 3 Link to post Share on other sites More sharing options...
Cheefarn 5th Gear October 5, 2016 Share October 5, 2016 Noob question but why would u want to lower the car? I can only think it gives better stability n handling esp at corners? But this is an MPV afterall which is taller so I don't think it makes much difference? Yup, you are correct there... To add on - A lowered car will always look much better than one whose tire to fender gap is so large that a cat can climb in and sleep... - A lowered stance will make the wheels looked bigger to a certain degree - A better chance to pick up SYTs - Becos you are an ah beng Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 5, 2016 Share October 5, 2016 Yup, you are correct there... To add on - A lowered car will always look much better than one whose tire to fender gap is so large that a cat can climb in and sleep... - A lowered stance will make the wheels looked bigger to a certain degree - A better chance to pick up SYTs - Becos you are an ah beng I'm past the age of wanting a lowered ride, not to mention the impracticality when on bumpier roads. lol I'm thinking of downsizing to 15" alloys with slight thicker rubber if next bigger size. Cos now I appreciate SUV height clearance a lot. Link to post Share on other sites More sharing options...
Matrix0405 5th Gear October 5, 2016 Share October 5, 2016 Anyone book Sienta w/ BM over last 2 weekend? Just launched and likely BM will bid aggressively to put some units on the road. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 5, 2016 Share October 5, 2016 (edited) just sharing my exp after brief test drive last week - - ride is reasonably comfortable on 15" alloys (test drive being standard model) do note turning radius is different for 15" & 16"; one at 5.3m & another 5.7m respectively - if ladder chassis means riding on stilts, then i believe sienta is not this type, but it is 25mm higher than jdm sienta - not sure what steering sienta was on, but didnt feel like i gotta turn alot; typical toyota car character - easy to handle - current sienta on cvt wc i believe at 100kph will be around 2k rpm (even my current korean 4at "only" 2.5k rpm at 100kph) avanza is one very backward tech model based on tractor / pickup.. bm should have nvr brought in this model. if i own avanza sure very hard to sell due to a backward model wc prev cost 120k at high coe era.. update on my observations of diff between ad n pi sienta - - the obvious being 2NR-FE vs 2NR-FKE (latter being atkinson iirc) - another obvious being front dash design - third obvious being color choice (e.g. super white vs pearl white) - front driver no armrest vs 1 armrest for driver - floor shift w handbrake vs dash shift w footbrake - 4 disc vs 2 disc + 2 drum (a bro mentioned pi oso have 4 disc) brakes - no footrest vs carpet shaped "footrest" - 2nd row seat traversing distance 5-6cm vs 8-9cm - less 3rd row legroom vs more (somehow oso felt more headroom for pi one at 3rd row) - higher ground clearance vs lower - 3 airbags vs 2 Edited October 5, 2016 by Fuelsaver 2 Link to post Share on other sites More sharing options...
Heartbreakid 6th Gear October 5, 2016 Share October 5, 2016 Based on some mentioning that the ride height (ground clearance) of Indonesia made Sienta is higher than JDM, from the brochure I got from Borneo Motors, either it is printed wrongly or sg specs Sienta actually set the same clearance as JDM model at 155mm. Whereas in Indonesia or Msia, their clearance is at 170mm range. I won't be surprised that sg specs Sienta have the same ground clearance as JDM model because our road conditions are good hence do not need the higher clearance. Link to post Share on other sites More sharing options...
alphard96 6th Gear October 5, 2016 Share October 5, 2016 Yup, you are correct there... To add on - A lowered car will always look much better than one whose tire to fender gap is so large that a cat can climb in and sleep... - A lowered stance will make the wheels looked bigger to a certain degree - A better chance to pick up SYTs - Becos you are an ah beng Classic example is Toyota Estima (PI) vs Toyota Previa (from Agent). Look at the rear, try park side by side. The Previa rear is higher, Estima lower, nothing to do with sports version (Aeras or non Aeras). For these cars, Estima look and handle better. Link to post Share on other sites More sharing options...
inlinesix Supersonic October 6, 2016 Share October 6, 2016 update on my observations of diff between ad n pi sienta - - the obvious being 2NR-FE vs 2NR-FKE (latter being atkinson iirc) - another obvious being front dash design - third obvious being color choice (e.g. super white vs pearl white) - front driver no armrest vs 1 armrest for driver - floor shift w handbrake vs dash shift w footbrake - 4 disc vs 2 disc + 2 drum (a bro mentioned pi oso have 4 disc) brakes - no footrest vs carpet shaped "footrest" - 2nd row seat traversing distance 5-6cm vs 8-9cm - less 3rd row legroom vs more (somehow oso felt more headroom for pi one at 3rd row) - higher ground clearance vs lower - 3 airbags vs 2 Read my previous post. atkinson cycle is used for hybrid only. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 6, 2016 Share October 6, 2016 Read my previous post. atkinson cycle is used for hybrid only. don't think so.. https://en.wikipedia.org/wiki/Toyota_Sienta https://en.wikipedia.org/wiki/Toyota_NR_engine#2NR-FKE update on my observations of diff between ad n pi sienta - - the obvious being 2NR-FE vs 2NR-FKE (latter being atkinson iirc) - another obvious being front dash design - third obvious being color choice (e.g. super white vs pearl white) - front driver no armrest vs 1 armrest for driver - floor shift w handbrake vs dash shift w footbrake - 4 disc vs 2 disc + 2 drum (a bro mentioned pi oso have 4 disc) brakes - no footrest vs carpet shaped "footrest" - 2nd row seat traversing distance 5-6cm vs 8-9cm - less 3rd row legroom vs more (somehow oso felt more headroom for pi one at 3rd row) - higher ground clearance vs lower - 3 airbags vs 2 - 2nd row a/c or blower vs front a/c vents only - spare wheel vs tyre repair kit w e-pump SE updated me on sienta elegance 110k vs wish 111k (but dunno elegance / classic).. if not desiring more head room, "modern" design, LED lamps n higher tech display / HU, more rational / practical to opt for wish for more airbags, better performance, more space n better ergo / seating comfort. Link to post Share on other sites More sharing options...
Sugimoto 6th Gear October 6, 2016 Share October 6, 2016 Read my previous post. atkinson cycle is used for hybrid only. Both hybrid 1NZ-FXE & petrol 2NR-FKE engines are using Atkinson cycle. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 15, 2016 Share October 15, 2016 Mitw sienta. Jap specs but w handbrake n 1.8l engine fr wish. Oso have rear ac blower Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 23, 2016 Share October 23, 2016 Just a quick check - anyone got the bm sienta, though I think most / all should've booked wish at with such pricing. Link to post Share on other sites More sharing options...
Zfuyuan 1st Gear October 24, 2016 Share October 24, 2016 Just a quick check - anyone got the bm sienta, though I think most / all should've booked wish at with such pricing. Neither.. if u are looking at cost saving, get PI Sienta, rather than Wish.. Link to post Share on other sites More sharing options...
Matrix0405 5th Gear October 26, 2016 Share October 26, 2016 More and more Uber Sienta on the roads. Can the PI Sienta really hit close to 20km/L? Link to post Share on other sites More sharing options...
Kteokteo 1st Gear October 26, 2016 Share October 26, 2016 this is a guide. tested in japan. take this as a guide +/- some owner can indeed achieved it here, both hybrid and petrol variant. Fuel consumption==============Highwayhybrid clocks 20.9km/lpetrol clocks 19.7km/lSuburban roadHybrid clocks 23.1km/lPetrol clocks 15.2km/lCityHybrid clocks 21.1km/lPetrol clocks 12.6km/lOverall MixedHybrid clocks 21.5km/lPetrol clocks 15.5km/l http://autoc-one.jp/nenpi/2454182/ Link to post Share on other sites More sharing options...
Adipedia Neutral Newbie November 19, 2016 Share November 19, 2016 (edited) Yes, Toyota Sienta became global car as Indo also received the car Source 1 : http://www.jakartatoyota.net/harga-mobil-toyota/harga-mobil-sienta/ Source 2 : http://www.jakartatoyota.net/harga-mobil-toyota/ Edited November 19, 2016 by Adipedia Link to post Share on other sites More sharing options...
Amoslowlc 5th Gear November 24, 2016 Share November 24, 2016 More and more Uber Sienta on the roads. Can the PI Sienta really hit close to 20km/L?Sienta hybrid can reach average 20km/l. Sienta fuel is about 15 ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
