Ronnieseah 1st Gear July 17, 2015 Share July 17, 2015 anyone here has use those flat tire repair kit that come in a spray can? if encounter a flat, just connect into the valve and spray into the tire. want to know whether this work? as I feel getting this is better than having a spare tire. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
lausai88 Hypersonic July 17, 2015 Share July 17, 2015 check this out. https://www.youtube.com/watch?v=82dB4XfUc-o anyone here has use those flat tire repair kit that come in a spray can? if encounter a flat, just connect into the valve and spray into the tire. want to know whether this work? as I feel getting this is better than having a spare tire. 1 Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 17, 2015 Share July 17, 2015 waste time only it destroy ur rim internally with all the gum and u need buy new rim just buy a 12v air pump, inflate it, drive to tyre shop dont cheapskate buy 10$ sealant and cost u a brand new rim and tyre 5 Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 18, 2015 Share July 18, 2015 waste time only it destroy ur rim internally with all the gum and u need buy new rim just buy a 12v air pump, inflate it, drive to tyre shop dont cheapskate buy 10$ sealant and cost u a brand new rim and tyre My Dear Furrynadz after shooting the gum inside your flat tyre with this bottle(shown in the pic) it does 99% help to stop the leak temporary which allow continue your journey and look for shop to fix the flat tyre ( do remember only internal repair is recommended for this case and please tell the shop you had chemical inside so they can take precaution while remove the tyre from rim which they may charge you $ for cleaning and dry the tyre before repair can be done) you can continue use your rim after properly repair procedure. they are kind of chemical shoot inside to prevent puncture I will not recommend because it may cause vibration and rim corrosion if you doesn't mind. 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 18, 2015 Share July 18, 2015 full size spare tyre is still the bestest! 2 Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 18, 2015 Share July 18, 2015 full size spare tyre is still the bestest! fully agreed but sometime situation dont allow you change spare tyre 1 Link to post Share on other sites More sharing options...
Wishxsr 2nd Gear July 18, 2015 Share July 18, 2015 Spare tire still recommended. But Its still ok to keep a bottle in the car just in case of emergency for ppl who travel up north to MY land often. 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 18, 2015 Share July 18, 2015 Spare tire still recommended. But Its still ok to keep a bottle in the car just in case of emergency for ppl who travel up north to MY land often. just for your information many new cars now don't come with spare tyre (not even donut) Do remember to check when you are collecting your new car (please don't mistaken as they steal your spare , it is the car don't equipped with spare . for those car Originally come fitted with runflat tyre , you will not have ant spare tyre too Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 18, 2015 Share July 18, 2015 Tyre repair kit and inflator is the bestest best! 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 18, 2015 Share July 18, 2015 Tyre repair kit and inflator is the bestest best! take some muscle but still is the best solution and of course....cheapest. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 18, 2015 Share July 18, 2015 seriously just buy one inflator 12v so many folks call me for roadside assistance liao faster response time than AAS 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 18, 2015 Share July 18, 2015 (edited) take some muscle but still is the best solution and of course....cheapest. Yep, definitely need some muscle. Bestest and cheapest. I also got a portable jack and 12V impact wrench to remove the wheel nuts. Edited July 18, 2015 by Fcw75 Link to post Share on other sites More sharing options...
lausai88 Hypersonic July 18, 2015 Share July 18, 2015 (edited) seriously just buy one inflator 12v so many folks call me for roadside assistance liao faster response time than AAS you provide "free" roadside assistance - can I have your mobile number? Edited July 18, 2015 by lausai88 1 Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 18, 2015 Share July 18, 2015 you provide "free" roadside assistance - can I have your mobile number? Link to post Share on other sites More sharing options...
Robin 4th Gear July 18, 2015 Share July 18, 2015 (edited) my car comes with tire sealant & 12v inflator but no spare tyre.. i,m not keen on using the sealant i'm looking for a spare donut tyre if u have one donut with pcd 5 x 112, i'm keen to buy anyone here has use those flat tire repair kit that come in a spray can? if encounter a flat, just connect into the valve and spray into the tire. want to know whether this work? as I feel getting this is better than having a spare tire. Edited July 18, 2015 by Robin Link to post Share on other sites More sharing options...
Ronnieseah 1st Gear July 18, 2015 Author Share July 18, 2015 can recommend the 12v compressor brand? 1 Link to post Share on other sites More sharing options...
Tenghock 2nd Gear July 18, 2015 Share July 18, 2015 waste time only it destroy ur rim internally with all the gum and u need buy new rim just buy a 12v air pump, inflate it, drive to tyre shop dont cheapskate buy 10$ sealant and cost u a brand new rim and tyre 12V air pump is indeed most useful in most cases. Please be reminded not to pull out the screw or nail or the pressure won't hold. The temporarily pumped up tyre will allow you to drive to tyre shop or at least take you to a safer place to change into your spare. Remember a heated up rim is extremely difficult to remove! If the punctured is on the traffic side, please be absolutely careful!!! 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 18, 2015 Share July 18, 2015 can recommend the 12v compressor brand? BAL. Bought from Autobacs. Noisy but worked for me. Flat to 220kpa in about 5 mins. ↡ Advertisement Link to post Share on other sites More sharing options...
Hdb flat renovation
Hdb flat renovation
New Age Polish --> Volkswagen Portfolio
Please advise bodywork repair, spray painting workshop
Sealant or coating for vinyl wrap?
Do I need to change tire ?
IRoad X9 drains battery until it is flat
transfer of HDB flat ownership (non-sale)
