Treycjq Neutral Newbie December 9, 2015 Share December 9, 2015 Just PM-ed you the solution. It works on my device, hope it works on yours too. Good luck. :) im having the same problem, my NaviOne has no map :( head unit serves only as a large screen dvd player now. ↡ Advertisement Link to post Share on other sites More sharing options...
cedrik100 Neutral Newbie December 9, 2015 Share December 9, 2015 Just PM-ed you the solution. It works on my device, hope it works on yours too. Good luck. :) Hi, could you advice me on the solution ? Hardly can find any maps for download :( Link to post Share on other sites More sharing options...
Robinchangks Neutral Newbie December 21, 2015 Share December 21, 2015 Hi, please help, I am having the same problem....Many thanks Link to post Share on other sites More sharing options...
MarcusYang December 29, 2015 Share December 29, 2015 Hiiiiii You will have to contact the vendors in order to get it installed in the perfect manner. You can also try out the cheap options available with major car grooming providers in order to upgrade to a better player without huge financial hiccups. http://www.sierraglow.sg/ Thanks Marcus Yang Link to post Share on other sites More sharing options...
Tyrrou Neutral Newbie December 29, 2015 Author Share December 29, 2015 Hi, please help, I am having the same problem....Many thanks Pls check ur PM :) Hi, could you advice me on the solution ? Hardly can find any maps for download :( Hi, Pls check ur PM ... :) Link to post Share on other sites More sharing options...
GotTurboInside Neutral Newbie January 2, 2016 Share January 2, 2016 can PM me? thanks! Link to post Share on other sites More sharing options...
LiuHung Neutral Newbie January 3, 2016 Share January 3, 2016 Hi, Same problem. Looking for NaviOne replacement. Million thanks if can PM me the solution. :) Link to post Share on other sites More sharing options...
herald29 Neutral Newbie January 5, 2016 Share January 5, 2016 Pls pm the solution..facing the same problem..thanks! Link to post Share on other sites More sharing options...
Jiex 2nd Gear January 5, 2016 Share January 5, 2016 can pm me too? Link to post Share on other sites More sharing options...
Robinchangks Neutral Newbie January 5, 2016 Share January 5, 2016 Pls pm the solution..facing the same problem..thanks! Hi, Pls check your PM Link to post Share on other sites More sharing options...
Timeline Neutral Newbie January 12, 2016 Share January 12, 2016 I using careland gps, unable to locate Singapore map. Hope any kind souls to help here. Link to post Share on other sites More sharing options...
Timeline Neutral Newbie January 12, 2016 Share January 12, 2016 Any kind bros to pm the steps to change the navione map to Singapore? Link to post Share on other sites More sharing options...
Tyrrou Neutral Newbie January 13, 2016 Author Share January 13, 2016 (edited) Since im getting quite a fair bit of PMs, i will post the steps here.... Anyway, this forum is all about sharing information... 1. D/L the content from here: https://www.dropbox.com/s/i3rgex5hcn8jaiz/M3PGS_PPGX8.5_800x480.zip?dl=0&preview=M3PGS_PPGX8.5_800x480.zip 2. Unzip the content and put it in ur DVD SD card 3. Power on your device, go to ur GPS settings, change the path for the executable file for the navigation software. (If i rem correctly, it should be Navi.exe) 4. Hit the "GPS" button on ur DVD player to start. With credits to: mousemmx Enjoy.... Edited January 13, 2016 by Tyrrou Link to post Share on other sites More sharing options...
zooz_elmahdy Neutral Newbie September 7, 2016 Share September 7, 2016 Hi. Pls check ur PM Cheers Hello, the same issue with me , can you give me the solution please thanks Link to post Share on other sites More sharing options...
Tyrrou Neutral Newbie September 8, 2016 Author Share September 8, 2016 Please see post #31 Note: Do it at your own risk : ) Hello, the same issue with me , can you give me the solution please thanks Link to post Share on other sites More sharing options...
th0mash82 Neutral Newbie December 2, 2016 Share December 2, 2016 Just PM-ed you the solution. It works on my device, hope it works on yours too. Good luck. :) could you assist me too? my player has built-in IGO GPS but is there anyway i can change to WAZE GPS ? Link to post Share on other sites More sharing options...
th0mash82 Neutral Newbie December 7, 2016 Share December 7, 2016 Hi there, I need urgent help... I tried to install waze.exe onto my sd card and try access from my car but it doesn't seem to work. I tried igo.exe also dun work... Link to post Share on other sites More sharing options...
DarrenPortelli Neutral Newbie May 30, 2017 Share May 30, 2017 Just PM-ed you the solution. It works on my device, hope it works on yours too. Good luck. :) Hi can you help me with mine ? im in Europe and the gps is chinese ! NaviOne ↡ Advertisement Link to post Share on other sites More sharing options...
Goodbye programmers: Team of AI bots develops software in 7 minutes instead of 4 weeks
Car immobiliser and GPS tracker recommend?
Is Standalone GPS obsoleting?
Dashcam with GPS
Dashcam with GPS
Taobao Headunits
Taobao Headunits
Car Accessories Workshop in West Area
Replacing fuel filter
