kopilim Clutched September 18, 2015 Share September 18, 2015 V-power in Malaysia is the best. Cheap & powderful. To restore power, no need this. Juz buy from either Mobil/Esso. Mobil 1 racing 2T. Use 100ml before any long drive. It is more ex than Mobil 1 engine oil Thank you. I don't believe in additives. But different strokes for different folks I guess. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic September 18, 2015 Share September 18, 2015 Thank you. I don't believe in additives. But different strokes for different folks I guess. Go & ask @babyblade. What is this. Link to post Share on other sites More sharing options...
Lanky 2nd Gear September 18, 2015 Share September 18, 2015 Just use recommended RON as specified in car manaul. Using higher grades will not improve FC or clean engine better. Only waste $$ and introduce more pollutants to the enviroment. All these are just marketing gimmicks from the oil companies.. https://www.youtube.com/watch?v=FPPkPAbzwbU&feature=share 2 Link to post Share on other sites More sharing options...
Swifter78 2nd Gear September 18, 2015 Share September 18, 2015 IMO, why spend the money to drink 100 Plus? Will fly? Drink water can liao lah. Link to post Share on other sites More sharing options...
inlinesix Supersonic September 18, 2015 Share September 18, 2015 (edited) Just use recommended RON as specified in car manaul. Using higher grades will not improve FC or clean engine better. Only waste $$ and introduce more pollutants to the enviroment. All these are just marketing gimmicks from the oil companies.. Totally disagree. Modern car uses some kind of valve timing system which is highly dependent on fuel RON. Of course, the higher RON will reduce the chances of retardation of valve timing system. IMO, why spend the money to drink 100 Plus? Will fly? Drink water can liao lah. 100 plus prevent fluid loss especially after hangover. Edited September 18, 2015 by Davidtch 1 Link to post Share on other sites More sharing options...
Mason016 Supersonic September 18, 2015 Share September 18, 2015 IMO, why spend the money to drink 100 Plus? Will fly? Drink water can liao lah. 100 plus is very useful when you have diarrhea. Link to post Share on other sites More sharing options...
CH_CO 6th Gear September 18, 2015 Share September 18, 2015 there is something more natural , it is called coconut water. 1 Link to post Share on other sites More sharing options...
Lanky 2nd Gear September 18, 2015 Share September 18, 2015 Totally disagree. Modern car uses some kind of valve timing system which is highly dependent on fuel RON. Of course, the higher RON will reduce the chances of retardation of valve timing system. 100 plus prevent fluid loss especially after hangover. Sure thing! Everyone is entitled to their opinions :) Using approriate RON as per car specifications is to prevent engine knocking, that's all to it. If you think pumping RON 98 is good for your car, it's your choice :) Just sharing the facts. 1 Link to post Share on other sites More sharing options...
Angcheek Hypersonic September 18, 2015 Share September 18, 2015 100 plus is very useful when you have diarrhea. its also very good after a hard Haysho Haysho workout ........... there is something more natural , it is called coconut water. coconut water drink too much will have Neng Ka hor kekeke 4 1 Link to post Share on other sites More sharing options...
Deckbuild 6th Gear September 18, 2015 Share September 18, 2015 IMO, why spend the money to drink 100 Plus? Will fly? Drink water can liao lah. Thats totally different, 100plus is consider isotonic, there are electrolytes in the drink which will help replenish body fluids. Link to post Share on other sites More sharing options...
Tohto Hypersonic September 18, 2015 Share September 18, 2015 Totally disagree. Modern car uses some kind of valve timing system which is highly dependent on fuel RON. Of course, the higher RON will reduce the chances of retardation of valve timing system. 100 plus prevent fluid loss especially after hangover. 100plus is also effective when have a fever... 1 Link to post Share on other sites More sharing options...
Holdenutessv Turbocharged September 18, 2015 Share September 18, 2015 Just use recommended RON as specified in car manaul. Using higher grades will not improve FC or clean engine better. Only waste $$ and introduce more pollutants to the enviroment. All these are just marketing gimmicks from the oil companies.. https://www.youtube.com/watch?v=FPPkPAbzwbU&feature=share Using bnb Cruze is just pointless. Higher grade suits high-powered/tuned cars better. https://www.youtube.com/watch?v=gQghB4asSnI 4 Link to post Share on other sites More sharing options...
Sunny Hypersonic September 18, 2015 Share September 18, 2015 change/add some addictives and call simi sai new improved name...have chance to price higher in future. si bey shiok for si hum 4 Link to post Share on other sites More sharing options...
Xanavi 4th Gear September 18, 2015 Share September 18, 2015 there is something more natural , it is called coconut water.Coconut water also not cheap hor. Link to post Share on other sites More sharing options...
Ake109 6th Gear September 18, 2015 Share September 18, 2015 As long as RON still 98, no diff even for TC cars. I want to try RON 100 Talking about RON, I understand CNG has the RON equilvalent of 120-130+. Does that mean if a turbo gasoline engine was converted to CNG, one could really tune the boost and ignition timing to beyond what normal premium pump gas can do? So far no one I talked to can answer. coconut water drink too much will have Neng Ka hor kekeke mmmmmm.. coconuts! 1 Link to post Share on other sites More sharing options...
flashbang Turbocharged September 18, 2015 Share September 18, 2015 Using bnb Cruze is just pointless. Higher grade suits high-powered/tuned cars better. Many people drive "normal" cars yet insist RON 98 gives them the best performance. Something interesting: Usually I fill up half a tank each time I put petrol. But recently I got a bunch of SPC vouchers that require minimum $50, so I put in $50 each time. My km/L has now improved by 5% for the last 2 tanks - I record the distance travelled and litres of petrol pumped each time and divide to get the figures. I am still using the same SPC 95 petrol and similar routes. Magic improvement, or just my imagination? Link to post Share on other sites More sharing options...
Jtb 6th Gear September 18, 2015 Share September 18, 2015 Many people drive "normal" cars yet insist RON 98 gives them the best performance. Something interesting: Usually I fill up half a tank each time I put petrol. But recently I got a bunch of SPC vouchers that require minimum $50, so I put in $50 each time. My km/L has now improved by 5% for the last 2 tanks - I record the distance travelled and litres of petrol pumped each time and divide to get the figures. I am still using the same SPC 95 petrol and similar routes. Magic improvement, or just my imagination? imagination Link to post Share on other sites More sharing options...
flashbang Turbocharged September 18, 2015 Share September 18, 2015 imagination Haha. Then I hope you don't believe that putting RON 98 gives you more "power" cos I don't... ↡ Advertisement Link to post Share on other sites More sharing options...
Shell x UOB Umbrella Redemption
Shell? Esso? Mobil? Caltex? SPC
Shell @ Yishun Ring Road is Closing Down
Join the Sgcarmart Stick It To Win It Contest now!
Shell x Monopoly 2021
Gas oil theft from Pulau Bukom refinery; ex-Shell officer jailed 29 years after masterminding S$129m gas oil theft from Pulau Bukom refinery
Overseas News: Shell Converts Gas Station Into EV Charging Hub
