Pirate Neutral Newbie October 9, 2015 Share October 9, 2015 Need some advice from experienced bro.I experienced this problem once when I can't start my Altis. .Batt was ok so the mechanics suspected spark plug.Changed that but didn't solve and they discover that the "pump" is not pumping petrol to the engine so got they changed as well.Initially it was ok. But now it will usually take me 3 attempts before it get started.Any idea what is the possible causes? And if want to fix, how much will it cost?Considering whether to expand coe or scrap so want to have a feel of what is the repair cost likely to be to help make the decision.Thanks in adv. ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 10, 2015 Share October 10, 2015 check your throttle body Link to post Share on other sites More sharing options...
WoeiSongKeh 5th Gear October 10, 2015 Share October 10, 2015 Throttle Body or it may be a case of your key issue (Happen to mine and heard its rare) Good luck Link to post Share on other sites More sharing options...
Airwaver 4th Gear October 10, 2015 Share October 10, 2015 (edited) Need some advice from experienced bro. I experienced this problem once when I can't start my Altis. . Batt was ok so the mechanics suspected spark plug. Changed that but didn't solve and they discover that the "pump" is not pumping petrol to the engine so got they changed as well. Initially it was ok. But now it will usually take me 3 attempts before it get started. Any idea what is the possible causes? And if want to fix, how much will it cost? Considering whether to expand coe or scrap so want to have a feel of what is the repair cost likely to be to help make the decision. Thanks in adv. Did your mechanic check the starter? Edited October 10, 2015 by Airwaver Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 10, 2015 Share October 10, 2015 Did your mechanic check the starter? starter usually yes/no not in between or a few try Link to post Share on other sites More sharing options...
Optramagnum 6th Gear October 10, 2015 Share October 10, 2015 (edited) To solve the problem with starting up, the repair cost usually won't cost a bomb, more importantly to find actual cause. It could be faulty starter motor, cam sensor, fuel pump, corroded battery terminal, and many more. Good luck bro!! Edited October 10, 2015 by Optramagnum Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 10, 2015 Share October 10, 2015 if the engine cranks, nothing is wrong with starter motor. 2 Link to post Share on other sites More sharing options...
Latio2005A Turbocharged October 10, 2015 Share October 10, 2015 It could be the starter motor or the coil. But if it cranks, it could be battery. Link to post Share on other sites More sharing options...
Kb27 Supersonic October 10, 2015 Share October 10, 2015 (edited) Initially it was ok. But now it will usually take me 3 attempts before it get started. 2 problems due to "no start" 1. Engine turnover - battery, wiring/terminal, starter motor 2. Engine firing - air, fuel, ignition, compression If your case is no. 2, then you have to check for: 1. Air - blockage due to idling control, dirty throttle body 2. Fuel - fuel pump, fuel pressure, fuel injectors 3. Ignition - spark plug, spark plug cables, ignition coils Edited October 10, 2015 by Kb27 2 Link to post Share on other sites More sharing options...
Watwheels Supersonic October 10, 2015 Share October 10, 2015 This issue usually is battery fault. First thing to do is do a battery test. Not many workshops know how to do a proper test to see if the battery is good. It's to test to see CCA not the voltage. If there's not enough CCA in the battery your car will have a problem starting. Other parts not getting enough power it will not work so previously whatever you had replaced the parts could still be working. Those inexperienced ppl could have replaced it for no good reason. Link to post Share on other sites More sharing options...
WoeiSongKeh 5th Gear October 10, 2015 Share October 10, 2015 Try and use your other spare key and see if it solve your issue first. I have this problem few mths ago and it solve after I use another key. Link to post Share on other sites More sharing options...
flashbang Turbocharged October 10, 2015 Share October 10, 2015 Did the mechanic check for fuel pressure? Try turning the key to the ON position and waiting while the fuel pump pressurizes the system, then crank when it's done. Link to post Share on other sites More sharing options...
Zhngmycar 1st Gear October 10, 2015 Share October 10, 2015 the best solution is change your mechic.. 1 Link to post Share on other sites More sharing options...
Pirate Neutral Newbie October 10, 2015 Author Share October 10, 2015 Haha. Any good and experienced mechanic to recommend? Want to do a general health check too before confirm renewal. Don't want wait sekali 1 problem after another. If the cause is what bro mentioned above, what is the repair cost like? Link to post Share on other sites More sharing options...
Beregond Supersonic October 10, 2015 Share October 10, 2015 Need some advice from experienced bro. I experienced this problem once when I can't start my Altis. . Batt was ok so the mechanics suspected spark plug. Changed that but didn't solve and they discover that the "pump" is not pumping petrol to the engine so got they changed as well. Initially it was ok. But now it will usually take me 3 attempts before it get started. Any idea what is the possible causes? And if want to fix, how much will it cost? Considering whether to expand coe or scrap so want to have a feel of what is the repair cost likely to be to help make the decision. Thanks in adv. if your car cannot start and your mech replace the spark plug for u , u really can change mech, in any case, u can alway question him back, why after replacement of parts, still got problem? Link to post Share on other sites More sharing options...
flashbang Turbocharged October 10, 2015 Share October 10, 2015 2 problems due to "no start" 1. Engine turnover - battery, wiring/terminal, starter motor 2. Engine firing - air, fuel, ignition, compression If your case is no. 2, then you have to check for: 1. Air - blockage due to idling control, dirty throttle body 2. Fuel - fuel pump, fuel pressure, fuel injectors 3. Ignition - spark plug, spark plug cables, ignition coils Follow this advice, it's good. 3 basic things needed for ignition are listed, typically the problem comes from either fuel or ignition. Your spark plugs are replaced and you can start the engine, so likely that spark plugs are good. Fuel pressure is actually a likely candidate as I faced the same issue last time. There was a leak in a breather hose which made it harder to start the engine, but once started it runs perfectly. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 10, 2015 Share October 10, 2015 clean throttle body first say for second time half hr 30$ job Link to post Share on other sites More sharing options...
Kengheng450 2nd Gear October 10, 2015 Share October 10, 2015 clean throttle body first say for second time half hr 30$ job Check this it could be it. ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
