Enye Hypersonic August 10, 2016 Share August 10, 2016 Time flies! 2.5 years already. Biante is very hardy and sure look like can last 20 years if maintain properly. But don't think could resist temptation that long lah.your heart is with the sharan why search so desperately for another mpv to avoid it? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
MercutioV 1st Gear August 10, 2016 Share August 10, 2016 (edited) your heart is with the sharan why search so desperately for another mpv to avoid it? ð then engine oil also synthetic how? all engines of every brand will kena or not? ð Engine oil is not in contact with any Mechatronic unit. In the case of DSG the oil is in contact with the gb's MU. And the corrosion led the MU to short circuit. That was the essential problem of 7-speed DSG failures. Edited August 10, 2016 by MercutioV Link to post Share on other sites More sharing options...
Enye Hypersonic August 10, 2016 Share August 10, 2016 Engine oil is not in contact with Mechatronic unit.will corrode the engine? Link to post Share on other sites More sharing options...
Spring Moderator August 10, 2016 Share August 10, 2016 Engine oil is not in contact with Mechatronic unit. Sorry maybe I misunderstood. EO Can still use Synthetic but GB oil must use Mineral right? 3 Link to post Share on other sites More sharing options...
MercutioV 1st Gear August 10, 2016 Share August 10, 2016 (edited) Sorry maybe I misunderstood. EO Can still use Synthetic but GB oil must use Mineral right?The peculiar design of VW 7-speed DSG requires the use of mineral oil within the gb, yes. But different gb with different design will depend on each case. Cannot generalize.The peculiar design of VW 7-speed DSG requires the use of mineral oil within the gb, yes. But different gb with different design will depend on each case. Cannot generalize.To clarify: engine oil and gb oil are different issues. Let's not confuse. Edited August 10, 2016 by MercutioV Link to post Share on other sites More sharing options...
Lala81 Hypersonic August 10, 2016 Share August 10, 2016 Sorry maybe I misunderstood. EO Can still use Synthetic but GB oil must use Mineral right? yeah it's just the GB oil. Or else make whole of VW group cars come in for servicing every 5k, everyone already junk their VW liao Link to post Share on other sites More sharing options...
Spring Moderator August 10, 2016 Share August 10, 2016 (edited) The peculiar design of VW 7-speed DSG requires the use of mineral oil within the gb, yes. But different gb with different design will depend on each case. Cannot generalize. To clarify: engine oil and gb oil are different issues. Let's not confuse. Ok tks guys for the clarification, I'm not very technical so it's good learning process for me! yeah it's just the GB oil. Or else make whole of VW group cars come in for servicing every 5k, everyone already junk their VW liao Edited August 10, 2016 by Spring 5 Link to post Share on other sites More sharing options...
Enye Hypersonic August 10, 2016 Share August 10, 2016 the issue is the for 7sp dry dsg gb, the mu is not immersed in an oil bath and therefore prone to failure due to repeated heat cycles if what VW said about the synthetic gb oil is true, then the 6sp wet dsg gb should be the unreliable and problematic one because the mu is immersed in an oil bath for cooling purposes therefore it is known as wet dsg makes sense? Link to post Share on other sites More sharing options...
yokechye 4th Gear August 10, 2016 Share August 10, 2016 Ok tks guys for the clarification, I'm not very technical so it's good learning process for me!Bro, how's your ride so far? If the price was lower that time I would have went for 2GT. 1 Link to post Share on other sites More sharing options...
MercutioV 1st Gear August 10, 2016 Share August 10, 2016 the issue is the for 7sp dry dsg gb, the mu is not immersed in an oil bath and therefore prone to failure due to repeated heat cycles if what VW said about the synthetic gb oil is true, then the 6sp wet dsg gb should be the unreliable and problematic one because the mu is immersed in an oil bath for cooling purposes therefore it is known as wet dsg makes sense? ð The difference is that since the 6spd DSG is fully immersed in oil, it never gets as hot. 7spd DSG is partly dry clutch. As such it generates much more heat which causes the synthetic oil's sulphur additives to change their molecular structure and corrode the MU. 3 Link to post Share on other sites More sharing options...
Enye Hypersonic August 10, 2016 Share August 10, 2016 The difference is that since the 6spd DSG is fully immersed in oil, it never gets as hot. 7spd DSG is partly dry clutch. As such it generates much more heat which causes the synthetic oil's sulphur additives to change their molecular structure and corrode the MU.ok you can buy the 7 dsg with full confidence I'll prefer the 6dsg thank you Link to post Share on other sites More sharing options...
Carbon82 Moderator August 11, 2016 Share August 11, 2016 (edited) I don't think Toyota Triplet, Honda Stepwgn Nissan Serena are based on van platform. FYI, Toyota and Nissan also has commercial van based people carriers in the product lineup. Edited August 11, 2016 by Carbon82 3 Link to post Share on other sites More sharing options...
Lycanthrope 4th Gear August 11, 2016 Share August 11, 2016 test drove citan with 7 seater versions before .. the 1.5 liter turbo diesel engine has good pulling power for such heavy van , the 6 speed manual gb was smooth and not that jerky even for me ( been a auto driver for a long time) ..space was really good front , middle and back ... , ground clearance was quite high too , tall ride height ...handling was quite ok .. did a sharp turn ..surprisingly nimble , suspension feels quite stiff ... Aircon however seems quite weak , fit and finishes quite flimsy and interior very bland and basic ... overalll quite a good car ,,, Link to post Share on other sites More sharing options...
Xanavi 4th Gear August 11, 2016 Share August 11, 2016 test drove citan with 7 seater versions before .. the 1.5 liter turbo diesel engine has good pulling power for such heavy van , the 6 speed manual gb was smooth and not that jerky even for me ( been a auto driver for a long time) ..space was really good front , middle and back ... , ground clearance was quite high too , tall ride height ...handling was quite ok .. did a sharp turn ..surprisingly nimble , suspension feels quite stiff ... Aircon however seems quite weak , fit and finishes quite flimsy and interior very bland and basic ... overalll quite a good car ,,, You test drive the one at Repub***? 1 Link to post Share on other sites More sharing options...
Lycanthrope 4th Gear August 11, 2016 Share August 11, 2016 (edited) ya...very nice color.. have u tested it ? but did notice the panel board covering the back doors were bloated ... seems that water has seeped in and wet the board You test drive the one at Repub***? Edited August 11, 2016 by Lycanthrope 1 Link to post Share on other sites More sharing options...
Zafira18 1st Gear August 11, 2016 Share August 11, 2016 test drove citan with 7 seater versions before .. the 1.5 liter turbo diesel engine has good pulling power for such heavy van , the 6 speed manual gb was smooth and not that jerky even for me ( been a auto driver for a long time) ..space was really good front , middle and back ... , ground clearance was quite high too , tall ride height ...handling was quite ok .. did a sharp turn ..surprisingly nimble , suspension feels quite stiff ... Aircon however seems quite weak , fit and finishes quite flimsy and interior very bland and basic ... overalll quite a good car ,,, btw, citan is a French(Renault) with a german heart... 1 Link to post Share on other sites More sharing options...
Carbon82 Moderator August 11, 2016 Share August 11, 2016 btw, citan is a French(Renault) with a german heart...Should be French babe with German clothing. The diesel engine is also from Renault. 4 Link to post Share on other sites More sharing options...
Spring Moderator August 11, 2016 Share August 11, 2016 Bro, how's your ride so far? If the price was lower that time I would have went for 2GT. It's good!! The instant torque, good FC are the plus points. The no 3rd row air con is the downer and I suppose the auto start stop as well but that one u can off but must do each time. Overall happy with the car as it serves my needs though those who need a 7 seater most times should look elsewhere, cheers!! ↡ Advertisement 5 Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
