  • 1
  • Search this thread
  • Reply to this topic
1 reply to this topic | 0 praises
#1
Posted 13 November 2015 - 10:07 AM
CeramicPROSingapore
  • THREAD STARTER
  • CeramicPROSingapore
    Sponsor
    Author Image
    12
post-115615-0-83128300-1446309417_thumb.
Ceramic PRO - Complete Surface Protection
A revolutionary surface protection for vehicles and also in construction, industrial & domestic uses.
Indecisive of which coating brand to choose? International brand or OEM product? With or without certification/lab test report? Ceramic nanotechnology or typical glass coating? Would you invest on Ceramic PRO which offers Multi-Layered coating system up to 10 layers OR a brand X’s single layer for a similar price range? It’s a simple math. With increasing number of layers of coating, it would lead to increment in coating overall thickness and achieving solid ceramic hardness of 9H. The unique formulation of MULTI-LAYERED by Ceramic PRO 9H can achieve Thicker coating, Stronger protection & Higher gloss level. Make every of your dollar worth.
www.CeramicPRO.com.sg
Tested Inspected Verified Certified by SGS | REACH
Ceramic PRO 9H can only be applied by Approved Applicators
SGS Tested and Certified | Multi-Layer and Thickness Tested | Permanent Chemical Bonding | Hardness above 9H - Scratch Resistance | Super Hydrophobic Effect | Anti-Graffiti | Advanced Chemical Resistance | Excellent Weather resistance | UV Protection | Oxidation and Corrosion Resistant | Temperature resistance | High Gloss | Colour renew | Self Cleaning Effect | Self-Healing Effect
Ceramic PRO Products:
·      Ceramic PRO 9H [Multi-Layering Ceramic Technology]
·      Ceramic PRO LIGHT [Up to 24 Months Durability]
·      Ceramic PRO RAIN [Glasses]
·      Ceramic PRO PLASTIC / RUBBER [Plastic & Rubber]
·      Ceramic PRO LEATHER [Leather Surface]
·      Ceramic PRO TEXTIE [Fabric/Soft top]
·      Ceramic PRO WHEEL & CALIPER [Rims and Calipers]
·      Ceramic PRO PPF & VINYL [Paint cleaner and Bonding Primer]
·      Ceramic PRO PPF & VINYL TOP COAT[Paint cleaner and Bonding Primer]
·      Ceramic PRO NANO POLISH [Paint cleaner and Bonding Primer]
·      Ceramic PRO TAG [Air Purification]
·      Ceramic PRO SPORT [Exterior Maintenance]
·      Ceramic PRO SHAMPOO [Highly Concentrate Cleaner]
·      Ceramic PRO STRONG [Heavy industrial]
·      Ceramic PRO YATCH [*to be release]
Technology: Ceramic PRO 9H isn’t typical 'glass coating/sealant/wax' available in the market. It's based on Ceramic Nanotechnology and progressively undergoing research & development in state-of- the-art research centre. Thus, not all the coating system are created equal and Ceramic PRO is the leading brand in the automotive industry
Durability - Some perceptions that in our humid tropical weather, no coating systems will effectively last longer than a year. Ceramic PRO 9H has proven it durability with not just a year or two but many years. Look for a quality coating system that would be give you a better run in our environment
Multi-Layered Coating System - As the old adage goes ‘action speaks louder than words’, it remains true until today. Ceramic PRO 9H unique formulation on Multi-Layered coating system are verified by SGS (World's Largest Inspection Body) and able to achieve Thicker coating layers, Stronger protection against environmental fallouts & Higher gloss level.
Certification: Look for one which has recognised certification (SGS) & published lab test report. All Ceramic Pro's product are tested, inspected, verified & certified by SGS (World's Largest Inspection Body)
Contactless coating process to ensure that the coating is applied evenly & uniform to the substrate on uneven surfaces/tight areas, a contour coat can be applied; a closed film can be achieved. The lack of a metering coating gap leads to a decreased sensitivity for coating defects and this could result in an overall improvement of quality.
Kindly drop us a message for price inquiry
Edited by AceGT_Grooming, 16 July 2018 - 10:10 AM.
Ceramic PRO Singapore
W - ceramicpro.com.sg
E - info@ceramicpro.com.sg
F - facebook.com/CeramicPROSG/
#2
Posted 13 November 2015 - 08:03 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    12
Our Research and Development Center Tour
  • 1
Back to Ceramic PRO  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: ceramicpro, paint, protection and 6 more...
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
