nazerath Turbocharged December 1, 2015 Share December 1, 2015 Such product is most useful if it's designed for tube-fitted tyre as the messy stuff will then be contained within inside the inner tube w/o messing with the rims. Unfortunately, I doubt that it's designed for use on inner tube. Otherwise, it will be a ideal product for motorcross/scrambler bikes. Ya I tried on inner tubes, not as effective, won't suddenly burst but still flatten. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 2, 2015 Share December 2, 2015 There are actually oem tires with this stuff coated inside straight out of factory However available tire profiles are extremely limited and very costly as these tires are specified by the car maker for some of their models. I guess tire manufacturers are reluctant to add this to all their tyres as it certainly will affect their top lines Link to post Share on other sites More sharing options...
Enye Hypersonic December 3, 2015 Share December 3, 2015 yes have seen those tire with black sticky glue applied inside the tire (mainly standard original tire for VW Passat / Scirocco) sad to discover many of these car owners are not aware that their car are fitted with this kind of tire after they took over his New car and after they change new tire (VW Sales Rep and Tire or workshop never highlight ) My knowledge about this Seal tire is it decelerate the punctured leak (not Leak proofed) as compared to normal tire thus it allows driver to have more time and longer distance to ask for help ,and this car generally will equipped with TPMS (tire pressure monitoring system) to alert driver of the tire pressure lost . according to instruction this tire has the ability of self seal after the nail is removed (not 100%) just my sharing i think when these oem tires are due for replacement, i would ask the tire shop to put a nail through them to test their effectiveness Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 4, 2015 Share December 4, 2015 (edited) i think when these oem tires are due for replacement, i would ask the tire shop to put a nail through them to test their effectiveness yes Good idea. share us the result I thot tire shop only repair puncture not puncture tire Edited December 4, 2015 by Roberttan Link to post Share on other sites More sharing options...
Furrynadz 5th Gear December 5, 2015 Share December 5, 2015 (edited) i think when these oem tires are due for replacement, i would ask the tire shop to put a nail through them to test their effectiveness no need try i can tell u i kanna b4, no leak south east just remove the nail and internal patch within Edited December 5, 2015 by Furrynadz 3 Link to post Share on other sites More sharing options...
Enye Hypersonic December 5, 2015 Share December 5, 2015 no need try i can tell u i kanna b4, no leak south east just remove the nail and internal patch within Yours conti or Pirelli? What is the tyre size? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear December 5, 2015 Share December 5, 2015 Yours conti or Pirelli? What is the tyre size? 235/40/18 pirelli p7c seal inside Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 7, 2015 Share December 7, 2015 no need try i can tell u i kanna b4, no leak south east just remove the nail and internal patch within may be very HENG . not everyone same just like some Driver always mount curb and tire no problem some not HENG little impact tire burst Link to post Share on other sites More sharing options...
Alphas 2nd Gear December 25, 2015 Share December 25, 2015 so how much to puncture proof 4 tires? 1 Link to post Share on other sites More sharing options...
lausai88 Hypersonic December 26, 2015 Share December 26, 2015 235/40/18 pirelli p7c seal inside You use this tire for how long already? I have been using the same pirelli 235/40/18 seal inside tire for more than 2 years now.see picture. few months ago, 2 tires keep leaking and i need to pump air every 3 days. Tire shop finds no fault and i have to replace the 2 tires. May be tire sealant has reached end of life. You have the same issue? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear December 26, 2015 Share December 26, 2015 (edited) You use this tire for how long already? I have been using the same pirelli 235/40/18 seal inside tire for more than 2 years now.see picture. few months ago, 2 tires keep leaking and i need to pump air every 3 days. Tire shop finds no fault and i have to replace the 2 tires. May be tire sealant has reached end of life. You have the same issue? IMG_1733.JPG IMG_1734.JPG 17 inch ver used abt 1 yr + swap out to upsize 18 18 one also abt 1 yr + then swap to ps3 didnt encounter any issue leh what rim u on, issit possible its a rim or a valve problem there is no such thing as the sealing patch become end of life the way it works is like sticking a scotch tape on a balloon u pierce it and then pull out the scotch tape will still hold the hole if your whole tyre/rim is leaking air, 100% chance its not the tyre if u have it on TWO tyres, cos air wont leak that fast through tyres unless u really got a lobang there more likely its a valve or rim problem which tyre shop u go? suggest u change one, they more like smoke u sell new tyre Edited December 26, 2015 by Furrynadz Link to post Share on other sites More sharing options...
Enye Hypersonic December 26, 2015 Share December 26, 2015 17 inch ver used abt 1 yr + swap out to upsize 18 18 one also abt 1 yr + then swap to ps3 didnt encounter any issue leh what rim u on, issit possible its a rim or a valve problem there is no such thing as the sealing patch become end of life the way it works is like sticking a scotch tape on a balloon u pierce it and then pull out the scotch tape will still hold the hole if your whole tyre/rim is leaking air, 100% chance its not the tyre if u have it on TWO tyres, cos air wont leak that fast through tyres unless u really got a lobang there more likely its a valve or rim problem which tyre shop u go? suggest u change one, they more like smoke u sell new tyre 17" version got no seal inside leh Only 18" version has 17" version only cpc2 conti seal You use this tire for how long already? I have been using the same pirelli 235/40/18 seal inside tire for more than 2 years now.see picture. few months ago, 2 tires keep leaking and i need to pump air every 3 days. Tire shop finds no fault and i have to replace the 2 tires. May be tire sealant has reached end of life. You have the same issue? IMG_1733.JPG IMG_1734.JPG You driving VW roc? Link to post Share on other sites More sharing options...
lausai88 Hypersonic December 26, 2015 Share December 26, 2015 17 inch ver used abt 1 yr + swap out to upsize 18 18 one also abt 1 yr + then swap to ps3 didnt encounter any issue leh what rim u on, issit possible its a rim or a valve problem there is no such thing as the sealing patch become end of life the way it works is like sticking a scotch tape on a balloon u pierce it and then pull out the scotch tape will still hold the hole if your whole tyre/rim is leaking air, 100% chance its not the tyre if u have it on TWO tyres, cos air wont leak that fast through tyres unless u really got a lobang there more likely its a valve or rim problem which tyre shop u go? suggest u change one, they more like smoke u sell new tyre I am using the tsw rim. saw the tire shop placed the tire under the water and cannot find any air leaking they changed the value but still leaks if rim problem, why use more than a year than leak thanks for the advise 17" version got no seal inside leh Only 18" version has 17" version only cpc2 conti seal You driving VW roc? no. i driving the accord Link to post Share on other sites More sharing options...
Enye Hypersonic December 26, 2015 Share December 26, 2015 I am using the tsw rim. saw the tire shop placed the tire under the water and cannot find any air leaking they changed the value but still leaks if rim problem, why use more than a year than leak thanks for the advise no. i driving the accord oic I thought that the tires were oem Did the tire shop recommend these tires when you changed rims? Link to post Share on other sites More sharing options...
lausai88 Hypersonic December 26, 2015 Share December 26, 2015 oic I thought that the tires were oem Did the tire shop recommend these tires when you changed rims? ya recommended by the boss. if it leaks again, need to find another tire shop. i dont trust him anymore. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear December 27, 2015 Share December 27, 2015 step 1 : www.google.com.sg step 2 : type in "tsw rim crack" step 3 : shit bricks and balls drop step 4 : find your balls first, it has more priority unless your ass tore really badly from the bricks step 5 : find a new tyre shop, this one obviously has sold u a shoddy brand and giving u excuses step 6: if ur name is really robert in nric better change it step 7 : if u have such a toy in the car better dispose it 1 Link to post Share on other sites More sharing options...
lausai88 Hypersonic December 28, 2015 Share December 28, 2015 dont find some old and bulls**t articles from the internet and start barking See these 30 reviews from mcfer bros,they are more trustworthy: http://www.sgcarmart.com/products/listing.php?BRSR=0&BRD=TSW 1 Link to post Share on other sites More sharing options...
Enye Hypersonic December 28, 2015 Share December 28, 2015 dont find some old and bulls**t articles from the internet and start barking See these 30 reviews from mcfer bros,they are more trustworthy: http://www.sgcarmart.com/products/listing.php?BRSR=0&BRD=TSW i didn't have good experiences with this tyre shop despite many good reviews ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Tourador Tyres
Tourador Tyres
Tyre puncture
Tyre puncture
Yokohama Advan Apex V601
