Kb27 Supersonic April 15, 2016 Share April 15, 2016 does it really helps? I tried doing wheel arch, nothing impressive. only dead weight, somemore its 2 layer.. I ever tried undercarriage painting, prevent rust and kinda sound proofing. this did ease the noisiness.. nothing too special. Many yeas ago, I diy on my car, wheel arch, floor and doors. I did a very thorough job, spending many weekends on it. Imo, there is only so much you can do. Sound insulation, sheet panel dampening, they do cut down vibration noise and radiant noise to a certain degree. However, just get one bad tyre making noise and all your insulation will appear not to work anymore. You may have to put 20 layers of sound insulation on the wheel arch just to tone it down a bit. There is a limit, up to where more insulation has a negative returns. So, you need to modify your expectations. The best way of cuz is to get rid of the noise generator, in this case, the tyre. ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic April 15, 2016 Share April 15, 2016 There are generally 2 ways to reduce noise in a car. 1. Dampening - sheet metal flex and vibrate making noise, you put dampening material to reduce the flex and vibration 2. Absorption - sound absorbing material such as foam is used to absorb noise For those who wants to diy a bit and not too costly on the wheel arch: 1. Get a 3m undercoating or rubberised spray. You can find some similar spray in hardware shops. This is the dampening part. 2. For sound absorption part, you may stick some hard foam on the wheel arch. Bear in mind, it may drop off, if you don't stick it securely. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 15, 2016 Share April 15, 2016 This might very well be a thing of the past since now that high end cars have active noise cancelling in their audio system. I think very soon aftermarket audio head units will come up with similar technology. No more adding unnecessary sound deadening mats which are so heavy. Link to post Share on other sites More sharing options...
Littledemon 1st Gear April 15, 2016 Share April 15, 2016 Finally finish my 5 sheets.. wah full car 5 sheets is not enough. Will be ordering again.. I only manage to cover 2 doors and my boot (Im driving a mini van lol). Now is dunno how to isolate the engine noise. Some say firewall.. some say front flooring.. i also dunno which... Bro, Can share which vendor you buy from Taobao? I also searching there, but the shipping rates really qite high. Do you use air or sea shipment? Link to post Share on other sites More sharing options...
Sdf4786k Twincharged April 13, 2017 Author Share April 13, 2017 can try to inquire from here http://www.hardwareonline.com.sg/sound-barrier-1-8m-x-3-4m-grey.html?___SID=U ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Petrol Discounts in Singapore
Need advice: cheapest car replacement route?
2025 Mitsuoka M55
2025 Mitsuoka M55
