Samdo1978 Neutral Newbie November 27, 2015 Share November 27, 2015 Hi all; just bought a toyota wish 2.0aa reg dat 2010 with 77k mileage. Engine sounds good.Pick up is good.However the fuel consumtion with eco mode on is at 9km/L. Is this normal? New eo;spark plug and atf fluid.Please advise which workshop is reliable for this kind if issue ↡ Advertisement Link to post Share on other sites More sharing options...
nazerath Turbocharged November 27, 2015 Share November 27, 2015 What is your type of driving? Maybe you are heavy footed. I am heavy footed and my average is only 7. 2 on a 2 L car. Maybe the oil you used is thicker. 1 Link to post Share on other sites More sharing options...
Imac 5th Gear November 27, 2015 Share November 27, 2015 Hi all; just bought a toyota wish 2.0aa reg dat 2010 with 77k mileage. Engine sounds good.Pick up is good.However the fuel consumtion with eco mode on is at 9km/L. Is this normal? New eo;spark plug and atf fluid.Please advise which workshop is reliable for this kind if issue That is quite bad FC. My friend 1.8L Wish is clocking 14-15km/L. 70% highway. Link to post Share on other sites More sharing options...
Baal Supersonic November 27, 2015 Share November 27, 2015 What eo using n the weight of oil.? U do 70% city n neighbourhood roads? I drove altis 1.6. 2003 model about 11km/litre. Tyre n rim size width? 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 27, 2015 Share November 27, 2015 Check tyres pressure. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic November 27, 2015 Share November 27, 2015 Just bought only mah. After 3 full tank dan see how it goes. You never say what your travel pattern is like...is it 90% city? You do calculation by looking at the trip computer? What tires are you using? Are they stock size or over size? If no check engine light or whatever obvious issues you bring to workshop they will just chuck it one side. Unless you instruct them what to do they will not do anything. What for? 1 Link to post Share on other sites More sharing options...
Optramagnum 6th Gear November 27, 2015 Share November 27, 2015 Is your rear brakes drum? If so maybe it's jammed inside.. Link to post Share on other sites More sharing options...
Samdo1978 Neutral Newbie November 28, 2015 Author Share November 28, 2015 hi all.. it is 50% highway 50% start stop traffic...normal footing.RPMis <2k rpm currently using 5w40. anyone using 0w30 by amsoil for their wish? thank you all for the reply i will get it check 1) jammed rear brake 2)thick engine oil 3)dirty fuel filter Link to post Share on other sites More sharing options...
Kteokteo 1st Gear November 28, 2015 Share November 28, 2015 hi Samdo1978 Part of the reason why the fuel consumption for you 2.0 Wish is not so impressive is because: 1) This is the Borneo motor 2.0 litre Wish, it is still using an old engine (used in previous Picnic 2.0). I don't see your fuel consumption (even light footed) will be extremely good. Engine number is 1AZ-FE if i recalled correctly. Same engine also used on Camry 2.0 and RAV4 2.0. 2) If i also recall correctly, this 2.0 litre Wish is still using 4 speed automatic gearbox. 2) The 1.8 Wish (JDM version) which Borneo bought it later has better fuel economy. Gearbox is CVT and usually gears towards better fuel consumption too. Is your rim on 16' or 17" ? Overall like other bros mentioned here, thinner oil used, driving pattern, tyre pressure etc. do help a bit. Nevertheless the old 1AZ-FE is a very robust engine. :) 2 Link to post Share on other sites More sharing options...
renhau 3rd Gear November 28, 2015 Share November 28, 2015 9km/l for 2.0L car is quite common. I am light footed n drive carefully, tyre pressure 260 psi. I've got ard 10.5km/l 60H/40C drive. Link to post Share on other sites More sharing options...
nazerath Turbocharged November 28, 2015 Share November 28, 2015 (edited) Anyone thinks in this type of case, cleaning the Maf sensor would help? Anyone seen the cleaning spray for sale? Thread starter, you pump 95 Ron? Think 1az fe is spec to run that. hi Samdo1978 Part of the reason why the fuel consumption for you 2.0 Wish is not so impressive is because: 1) This is the Borneo motor 2.0 litre Wish, it is still using an old engine (used in previous Picnic 2.0). I don't see your fuel consumption (even light footed) will be extremely good. Engine number is 1AZ-FE if i recalled correctly. Same engine also used on Camry 2.0 and RAV4 2.0. 2) If i also recall correctly, this 2.0 litre Wish is still using 4 speed automatic gearbox. 2) The 1.8 Wish (JDM version) which Borneo bought it later has better fuel economy. Gearbox is CVT and usually gears towards better fuel consumption too. Is your rim on 16' or 17" ? Overall like other bros mentioned here, thinner oil used, driving pattern, tyre pressure etc. do help a bit. Nevertheless the old 1AZ-FE is a very robust engine. :) Excellent info. Edited November 28, 2015 by nazerath Link to post Share on other sites More sharing options...
Solar Turbocharged November 28, 2015 Share November 28, 2015 Maybe pour a couple bottles of fuel system cleaner or techron? Link to post Share on other sites More sharing options...
Samdo1978 Neutral Newbie November 28, 2015 Author Share November 28, 2015 (edited) Thanks bro.. will take note hi Samdo1978 Part of the reason why the fuel consumption for you 2.0 Wish is not so impressive is because: 1) This is the Borneo motor 2.0 litre Wish, it is still using an old engine (used in previous Picnic 2.0). I don't see your fuel consumption (even light footed) will be extremely good. Engine number is 1AZ-FE if i recalled correctly. Same engine also used on Camry 2.0 and RAV4 2.0. 2) If i also recall correctly, this 2.0 litre Wish is still using 4 speed automatic gearbox. 2) The 1.8 Wish (JDM version) which Borneo bought it later has better fuel economy. Gearbox is CVT and usually gears towards better fuel consumption too. Is your rim on 16' or 17" ? Overall like other bros mentioned here, thinner oil used, driving pattern, tyre pressure etc. do help a bit. Nevertheless the old 1AZ-FE is a very robust engine. :) I am running on Ron95. Ron 98 does not make much different though. Ok will run through Caltex techron fuel system cleaner and update the development here My engine is not 1AZ-FE though. Thanks all for the advice Edited November 28, 2015 by Samdo1978 Link to post Share on other sites More sharing options...
Wishxsr 2nd Gear November 28, 2015 Share November 28, 2015 Used to drive a 1.8 wish 9 years back and the fuel comsumption is not really good as what ppl mention (13km -16km/L) Im not heavy footed and run 65% highway. Average I get is between 10km to 11.5km/L only. So for Tomyam 2 L Wish, I think that's quite ok. Link to post Share on other sites More sharing options...
Samdo1978 Neutral Newbie November 29, 2015 Author Share November 29, 2015 Hi All, Any recommendations for the CVT fluid? Can we use any other ATF fluid? Was contemplating using Mobil 0W30 4quarts and Redline Automatic Transmission Fluid for servicing. Link to post Share on other sites More sharing options...
Trex101 3rd Gear November 29, 2015 Share November 29, 2015 (edited) Hi All, Any recommendations for the CVT fluid? Can we use any other ATF fluid? Was contemplating using Mobil 0W30 4quarts and Redline Automatic Transmission Fluid for servicing. Your Toyota Wish are using CVT transmission or auto transmission? because both fluid are design for different transmission and are not interchangeable, your Wish should be CVT right? Edited November 29, 2015 by Trex101 Link to post Share on other sites More sharing options...
Samdo1978 Neutral Newbie November 29, 2015 Author Share November 29, 2015 CVT bro.. Understood ..Thanks for the heads up. Any good brands to look up for? Your Toyota Wish are using CVT transmission or auto transmission? because both fluid are design for different transmission and are not interchangeable. Link to post Share on other sites More sharing options...
Trex101 3rd Gear November 29, 2015 Share November 29, 2015 (edited) CVT bro.. Understood ..Thanks for the heads up. Any good brands to look up for? You will need a Toyota CVTF FE spec CVT fluid and Valvoline fully syn CVT fluid will meet your requirement, Redline D4 ATF is definably not suitable. Edited November 29, 2015 by Trex101 ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Is It Really Cheaper To own An EV Versus A Gas Car?
Toyota Corolla Cross
