  • Search this thread
  • Reply to this topic
165 replies to this topic | 466 praises
#1
Posted 28 November 2015 - 12:05 PM
Kurty
  • THREAD STARTER
  • Premium member
    Kurty
    Author Image
    9,787
As many are considering to renew their ride for the next 10 years.
Was wondering, should we consider to place those important components of a car?
I know, the golden rule if it aren't spoiled, don't bother.
However, replacing them may helps to minimise the downtime and without a mode of transport.
I had a couple of bad incidents whereby the fuel pump went down as at 2nd day of cny. Carless and helpless for the next 5 days as most workshop are closed.
And recent, alternator went dead. Glad it was done in a couple of hours.
I read there isn't any hard rules on their lifespan.
Fuel pump can be prevented if tank is left half at most day to lubricate the pump.
Water pump is encourage to change upon the changing of belt.
What's your view on this?
bluey Tiko Ranger
I have a pen, I have an apple..
#2
Posted 28 November 2015 - 01:21 PM
Solar
  • Premium member
    Solar
    NOS-ed
    Author Image
    13,249
It's called preventive maintenance.
Yes, u can change them out earlier before they spoil.
But some items can show symptoms before they spoil, u need not change them if they don't.
#3
Posted 28 November 2015 - 04:55 PM
Meanmachine
  • Premium member
    Meanmachine
    6th Gear
    Author Image
    4,918
My 0.02cts is if it a conti car, better to have to check and rectify prior to extension of COE.
If it's a BNB, you can take chances coz sushi or kimchi still can ' Tahan ' a bit as parts are easily available and most mechanic can handle BNB cars. [drivingcar]
Kurty, Latio2005A, Showster, Blueray and 1 Anonymous member praised this
Disclaimer: Some content may not be accepted by all as we are not trained counseller / adviser, we seek your tolerant. My advice is based on experiences / exposure/s committed to give an honest & direct answer, no profanity & accusation to be taken of any kind, in an event that it misfired, it should be taken as a pinch of salt. Thank you !
#4
Posted 28 November 2015 - 05:46 PM
serenade
  • Premium member
    serenade
    5th Gear
    Author Image
    2,046
You know your own car and the ownership condtions best. If you have been doing regular maintenance, changing fluids and lubes at specified intervals, your car should be in good condition except for wear and tear parts after 10 years.
Once you have decided to renew COE, might as well do a major overhaul of worn parts or those likely to fail. As you have mentioned, they are : water pump, alternator, power steering pump, fuel pump. Other things to replace are engine mountings, shock absorbers & mountings, drive shafts and/or bellows, brake pads & disc. Air con compressor and evaporator too may need an overhaul especially if odours are present.
If your car has been subjected to mainly outdoor conditions, then the door seals may have to be changed too. Consider to give yourself a treat and have the car fully resprayed and theseat leather reconditioned. Your relatives will be impressed with the new looks and ride comfort
Do all these and you have given yourself a "new" car ready to be enjoyed again for at least next 5 years. At a fraction of the cost of a new car.
Kurty, Benarsenal, Showster, Blueray, polarusbearus67 and 2 Anonymous members praised this
#5
Posted 28 November 2015 - 05:50 PM
Mkl22
  • Mkl22
    Author Image
    8,689
For fuel pump, it's very difficult to tell. Those who claim they can tell, i salute you. Also I don't think it matters if you leave half a tank of gas inside or pump when empty. The fuel pump will also happy happy just give up.
Water pump is easier. Most of the time it is the bearing that is worn causing leaks. Or the blades of the pump, but this is rare If you use coolant and not tap water. The blades won't really wear with coolant. Only the bearing.
Alternator you can somewhat tell. But there are also cases where it just dies with some minutes of warning. The battery hopefully should last you till you reach workshop. Listen for unusual noises when it spins or burnt smells.
It's part and parcel of driving. Sending a car for servicing doesn't mean that the fuel pump, alternator won't suddenly die the next day.
Albeniz and 1 Anonymous member praised this
#6
Posted 28 November 2015 - 08:19 PM
Tommisan
  • Premium member
    Tommisan
    4th Gear
    Author Image
    596
Your first paragraph about refueling at 1/2 or near empty making no difference to the lifespan of fuel pump is incorrect.
Quoting directly from the website, http://www.agcoauto....2_articleid/195
"When the fuel level is low, the pump has to work much harder to produce the same pressure. This is because the reduced fuel weight no longer pushes fuel into the pump. Instead the pump must draw the fuel in. A low fuel level also means less fuel to dissipate heat and lubricate the pump. The combination of an overworked pump, reduced cooling and lubrication will likely damage the fuel pump."
The fuel pump in my previous ride failed simply because I almost always refuel after the low fuel indicator lights up. Now, I have changed my habit of refueling at 1/4 or 1/2 mark.
Albeniz and 2 Anonymous members praised this
What does not kill you only makes you stronger.
#7
Posted 28 November 2015 - 08:33 PM
Kurty
  • THREAD STARTER
  • Premium member
    Kurty
    Author Image
    9,787
Fuel pump, engine mounting and alternator replacement, I had experience before hence can share.
Fuel pump, difficult to explain.. basically the engine won't start.
Alternator, usually many would thought it's the car battery. Hence would ask for help to jump start, despite doing slow.. you will notice the fading of the battery life or speedo indicator.. then it's the alternator.
Engine mounting, in short, engine will vibrate vigorously
Hope can understand my poor but best explanations.
So based on what you mentioned, don't seem to be a need to change. Only the bearing.
Edited by Kurty, 28 November 2015 - 08:37 PM.
Meanmachine praised this
bluey Tiko Ranger
#8
Posted 28 November 2015 - 10:20 PM
Mkl22
  • Mkl22
    Author Image
    8,689
Well i choose not to believe. Not everything written on the Internet is correct. R&d engineers cannot be that stupid to not account for an empty tank all the time. That's what most will do. Anyway there is a small baffle that the fule pump sits in. So it is still cooled. Fuel pump will fail whenever they want to. Doesn't mean that you always do not let it go below 1/2 tank it will last longer. To each his own.
Othello praised this
#9
Posted 28 November 2015 - 10:57 PM
Othello
  • Premium member
    Othello
    2Fast2Furious
    Author Image
    39,091
since renewing, i would do
1. Suspension system (including engine mounts) - shocks, arms, link ends, bearings etc
2. cooling system - hoses, radiator, fans etc
3. all the belts. if timing belt about due, can also change together with water pump
the rest can wait till they break down.
Contax praised this
"O, devil, devil! If that the Earth could teem with woman's tears, Each drop she falls would prove a crocodile. Out of my sight!" (Act IV Scene I)
#10
Posted 28 November 2015 - 11:42 PM
Spinelli_ck
  • Premium member
    Spinelli_ck
    6th Gear
    Author Image
    3,360
most of the time, alternator or starter motor can be serviced or repaired without replacing the entire unit.
check the aircon magnetic clutch. if it is already worn and fails to engage the compressor, verify if it can be replaced without replacing the entire compressor.
parts like engine mounting, wheel bearings, serpentine belt etc should be replaced as and when symptoms like excessive vibrations, whining or creaking noises appear.
#11
Posted 29 November 2015 - 01:07 AM
Kippei
  • Premium member
    Kippei
    3rd Gear
    Author Image
    361
I dismantle my fuel pump b4. Its warm to hot to touch. However for 1/4 tank. There is enough to cool the outer casing of the pump.
I believe is the heat that destroy fuel pump.
#12
Posted 29 November 2015 - 09:49 AM
Solar
  • Premium member
    Solar
    NOS-ed
    Author Image
    13,249
I agree. I have been advised and also read before, it's a rule of thumb no-no to drive the car till the last drop of fuel. Fuel pump lifespan will reduce due to the heat. Fuel cools down the pump.
#13
Posted 29 November 2015 - 01:13 PM
flashbang
  • Premium member
    flashbang
    NOS-ed
    Author Image
    11,130
For this, I also don't know the answer. But recently I have also switched to filling up when fuel indicator says 2 bars. Low fuel light appears at 1 bar.
#14
Posted 29 November 2015 - 01:20 PM
SS316
  • Premium member
    SS316
    2nd Gear
    Author Image
    142
Well, if you upkeep the car, then do the critical change and do read the car manual for the understanding.
My car has more or less done all these with only 6 months left......
#15
Posted 29 November 2015 - 01:31 PM
Yewheng
  • Premium member
    Yewheng
    NOS-ed
    Author Image
    19,082
Of coz la, if most of the time refuel when fuel tank is very low or warning lights come on, it is very bad for fuel pump. Try to always pump petrol when fuel reaches 1/5 marks can already. As long as there is sufficient fuel and not too low, fuel pump will be good and can last more then 10 yrs.
#16
Posted 29 November 2015 - 01:43 PM
Yewheng
  • Premium member
    Yewheng
    NOS-ed
    Author Image
    19,082
That is why there is low fuel warning light comes on when fuel is super low. By right as a driver, we should not wait till fuel warning lights to turn on then start to look for petrol station. If we frequently wait till fuel lights come on and look for petrol station, it will really spoil the fuel pump at an accelerating rate. Fuel pump is able to last for a lifetime if it is well taken care of.
So for normal driving, I believe many people will not want to wait for fuel warning lights to come on then start looking for petrol station right? It is only for some drivers who always like to find out the extreme of what the car can do, or have the shiok feeling that yes I break my own record of reaching super low fuel and pump full tank, it can pump 50L where normally I can only pump 40L or somewhere along that line. These drivers are only testing out the limits on when the car will breakdown faster.
Edited by Yewheng, 29 November 2015 - 01:47 PM.
#17
Posted 29 November 2015 - 01:52 PM
Mkl22
  • Mkl22
    Author Image
    8,689
Those who engineer and design things will have this taken care off. If the pump really really need ls to be covered with fuel to work well, they will design it to take care of the lowest fuel level. It's the same as using 40wt engine oil when the manual specifies 20wt. I really wonder why we all want to be Kay khiang and second guess everything.
Anyway as I said to each his own.
Edited by Mkl22, 29 November 2015 - 01:57 PM.
#18
Posted 29 November 2015 - 05:43 PM
Throttle2
  • Throttle2
    2Fast2Furious
    Author Image
    37,625
Good advice
Targetting to truly retire by 2028
Give away my CPF
Travel the world and smoke those Cubans!
#19
Posted 29 November 2015 - 05:49 PM
Throttle2
  • Throttle2
    2Fast2Furious
    Author Image
    37,625
An in tank fuel pump is better kept submerged in fuel.
It is designed to be that way. And well perform best under those conditions.
The factory manual wont tell you that it will fail, it will just tell you to top up as soon as the light comes on.
No need to bleed your tank dry lah....heh heh
Give away my CPF
#20
Posted 29 November 2015 - 09:16 PM
Baal
  • Baal
    2Fast2Furious
    Author Image
    31,665
For Altis, I recall that it does say its good practice to refill no later than the 1/4 mark.
An article I read says that this 1/4 rule, is good, but especially applicable for DI engines.  Coz between MPI & DI, its the latter pump that deals with a lot more pressure.
But even for MPI its still good practice coz, the Altis manual says low levels may lead to misfiring.  My Ws says that if for some reason, say the petrol is swooshing around ......the pump coudnt suck up properly, will cause misfire.
Being OCD, I would like to add that many conti cars have easily 55-60 litre tanks.  So 1/4 means ~15L balance.  So in the case of small tanks....e.g.,  Honda Vez, Jz, City....with 40L tanks, best to keep it to min 1/3 tank.
Whoever fights monsters should see to it that in the process he does not become a monster. And if you gaze long enough into an abyss, the abyss will gaze back into you.
Friedrich Nietzsche
Dynamics Mechanic Pte Ltd
Dynamic Motoring Transmission Specialist Pte Ltd
Dynamic Motoring Transmission Specialist Pte Ltd  |  Rating   Submit Review
Reviewed by MisterTea  |  Neutral Newbie
Simply amazed at their workmanship, giving maintenance advises and good price. If you are looking for gearbox repair at a low reasonable price, do approach them
SgGarage Edwin
SgGarage Edwin  |  Rating   Submit Review
Reviewed by Hans912  |  Neutral Newbie
Knew Edwin through the FB, he is always kind and help to answer all of your questions. Still remember that we discussed about the vezel left side mirror regarding to how change to the same one as right side mirror. It is great talk even though it proved that very tough job to change it. 1st time to Edwin workshop is to install auto foldable function for the side mirror.... » Read More
Related Motor Directory search on sgCarMart.com : Repair & Servicing
Quick Reply
Tags: alfa romeo, car, maintainence and 3 more...
