elmoguy 2nd Gear December 21, 2015 Share December 21, 2015 How do you all actually mount your GPS in your car? I wonder how this work, as I don't think any mounting device is that strong. I tried many but most cannot make it and not able to hold the device's weight. This actually block the front view. During the night, the display will be reflected onto the front windows at night. This resulted in poor vision. This device is not reliable and will drop off when you made a sharp turn. Cabling also an issue. This will cause "condensation" on your device and also block the air flow from the AC. Your solar film will left with mark with this mounting method. Yet to try this magnetic device. But don't think it can hold the weight. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Yewheng Twincharged December 21, 2015 Share December 21, 2015 I use this, it's heavy at the base, put at dashboard is quite stable, best is no need scared the suction cap came loose and dropped off or leave permanent suction cap mark if stick to the windscreen under hot sun for too long. 1 Link to post Share on other sites More sharing options...
elmoguy 2nd Gear December 21, 2015 Author Share December 21, 2015 I tried this but doesn't work as it is not firm and stable enough. I actually wanted to try this but too expensive. Wanted to clip it here... not sure will it hold... It will not block air flow from AC and will not have reflection on the front glass. Link to post Share on other sites More sharing options...
Kb27 Supersonic December 21, 2015 Share December 21, 2015 i drill 2 holes on the stand onto the dashboard and put 2 screws. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic December 22, 2015 Share December 22, 2015 http://www.amazon.com/gp/product/B004M8ST36 I'm using this. It's the best I find so far coz with the 80mm big suction cup it can take a lot of tablet & smartphone weight. Leaving a mark on the solar film is no big deal. Just spray some water and wipe it off with a microfiber cloth. It comes with 4 x short claws and 4 x long claws you can mix and match to suit your device. It can hold my 7" tablet with the casing attached and cover flipped to the back. It can also hold my iphone6 with a charging case. It's quite heavy with the charging case. Not once did it drop or become detached over time. I bought it since 2014 Dec. 1 Link to post Share on other sites More sharing options...
Furrynadz 5th Gear December 22, 2015 Share December 22, 2015 (edited) i use the pack of 3 anti slip homeproud mat at ntuc put the gps on it and tilt it prop in between centre console and gear lever, works if your car gear lever and centre console just nice got the small space and angle to tilt there aircon control is automatic, block it a bit wont harm http://performancedrive.com.au/wp-content/uploads/2014/07/2015-Volkswagen-Passat-gear-lever.jpg $1 dollar solution Edited December 22, 2015 by Furrynadz 1 Link to post Share on other sites More sharing options...
elmoguy 2nd Gear December 22, 2015 Author Share December 22, 2015 I actually like this but it is for tablet. I tried other brand which is for Phone and GPS, but cannot make it. The suction cup will not stick. i use the pack of 3 anti slip homeproud mat at ntuc put the gps on it and tilt it prop in between centre console and gear lever, works if your car gear lever and centre console just nice got the small space and angle to tilt there aircon control is automatic, block it a bit wont harm http://performancedrive.com.au/wp-content/uploads/2014/07/2015-Volkswagen-Passat-gear-lever.jpg $1 dollar solution You are very creative. Link to post Share on other sites More sharing options...
inlinesix Supersonic December 22, 2015 Share December 22, 2015 This is the best mount for phone for MINI Link to post Share on other sites More sharing options...
Weez911 Supersonic December 22, 2015 Share December 22, 2015 Hi TS, a good solution is to get a car with GPS for your new car. No more wires and mount! Link to post Share on other sites More sharing options...
inlinesix Supersonic December 22, 2015 Share December 22, 2015 Hi TS, a good solution is to get a car with GPS for your new car. No more wires and mount! That's the most waste $$$ suggestion. Every map update is about $1k. MSM is for free. 1 Link to post Share on other sites More sharing options...
elmoguy 2nd Gear December 22, 2015 Author Share December 22, 2015 Hi TS, a good solution is to get a car with GPS for your new car. No more wires and mount! My car has GPS system and it display is below the AC. This is a stupid design whereby the display screen is not a eye level. Every year needs to pay subscription fee. Resolution is lousy as Garmin max is 800 x 400 and in order to blow up to the screen entirely, they just extrapolate and look damn ugly. The map is Garmin and it is the basic range and cannot make it. Garmin system now has voice command, 3D Buildings, 3D terrain, Traffic system, etc. and the map is Free for Life Time, if not MSM or Malsing. Link to post Share on other sites More sharing options...
Weez911 Supersonic December 22, 2015 Share December 22, 2015 My car has GPS system and it display is below the AC. This is a stupid design whereby the display screen is not a eye level. Every year needs to pay subscription fee. Resolution is lousy as Garmin max is 800 x 400 and in order to blow up to the screen entirely, they just extrapolate and look damn ugly. The map is Garmin and it is the basic range and cannot make it. Garmin system now has voice command, 3D Buildings, 3D terrain, Traffic system, etc. and the map is Free for Life Time, if not MSM or Malsing. Sorry I meant if you are getting a new car. Most new cars' GPS should have these features you mentioned, more or less at eye level. Some workshops sell "subscription" or annual map update at $50 per year. Sorry for being OT here, I understand you are looking for GPS mount. There are some Garmin mounts out there... Link to post Share on other sites More sharing options...
Kklim Supercharged December 22, 2015 Share December 22, 2015 This might fit: http://www.ebay.com/itm/Useful-CD-Player-Slot-Phone-Car-Auto-Mount-Holder-Cradle-Universal-/262130736911?hash=item3d08359f0f:g:1F0AAOSwu-BWPIS6 I have one. Using Sygic for navigation. Link to post Share on other sites More sharing options...
elmoguy 2nd Gear December 22, 2015 Author Share December 22, 2015 Sorry I meant if you are getting a new car. Most new cars' GPS should have these features you mentioned, more or less at eye level. Some workshops sell "subscription" or annual map update at $50 per year. Sorry for being OT here, I understand you are looking for GPS mount. There are some Garmin mounts out there... Hi Weez911. No need for sorry, we are here for discussion. I valued your input too. Have a great day. 2 Link to post Share on other sites More sharing options...
Sp4wn Turbocharged December 22, 2015 Share December 22, 2015 im using the iottie one touch .. http://www.iottie.com/Product/Series/OneTouch/Car-Mount bought 1.5 years ago ... has not dropped once. bought for my dad last year after those regular ones dropped with his phone in it, while he was driving. even his has never dropped off after that ... probably one of the best dash holders i've ever used ... 1 Link to post Share on other sites More sharing options...
elmoguy 2nd Gear December 22, 2015 Author Share December 22, 2015 In fact, I love this one. But it doesn't stick to my dashboard. Money spent wasted. Link to post Share on other sites More sharing options...
elmoguy 2nd Gear December 24, 2015 Author Share December 24, 2015 Anyone tried this? Link to post Share on other sites More sharing options...
7hm Turbocharged December 25, 2015 Share December 25, 2015 i'm using two solutions... one is a strong, sturdy GPS/tablet/phone holder that sits inside a cup holder. Very sturdy construction and of course, cannot drop since it's held by the cup holder. Due to my odd situation with my phone model I use one of those windshield clamp types (similar to DashCrab FX) that in turn grips my actual phone cradle. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
