Matrix0405 5th Gear August 11, 2018 Share August 11, 2018 Very good sharing. Looks like the easiest monitoring solution is the $3 ciggy plug voltage indicator. When you realised need more than 1 crank to get the car started. It's time to plug in this voltage indicator, turn on the electricity (but don't crank/start the car and let the alternator kick in) and see the reading. If voltage is less than 12v, its near EOL for the battery. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 11, 2018 Share August 11, 2018 So tempted to disconnect the negative polarity of my battery and try to jump start the car with my new jumper toy. Is there other way to do it? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear August 11, 2018 Share August 11, 2018 So tempted to disconnect the negative polarity of my battery and try to jump start the car with my new jumper toy. Is there other way to do it? can try at the expense of retune radio settings. Link to post Share on other sites More sharing options...
Othello Supersonic August 12, 2018 Share August 12, 2018 can try at the expense of retune radio settings.What do the pros use to save the settings? Some OBD tool? Link to post Share on other sites More sharing options...
inlinesix Supersonic August 12, 2018 Share August 12, 2018 What do the pros use to save the settings? Some OBD tool?Buy German car Link to post Share on other sites More sharing options...
Pocy Hypersonic August 13, 2018 Share August 13, 2018 So tempted to disconnect the negative polarity of my battery and try to jump start the car with my new jumper toy. Is there other way to do it? Post your HP number here ...... Link to post Share on other sites More sharing options...
Othello Supersonic August 13, 2018 Share August 13, 2018 Buy German car ð Ermmm, you drive British car leh Link to post Share on other sites More sharing options...
inlinesix Supersonic August 13, 2018 Share August 13, 2018 Ermmm, you drive British car leh Link to post Share on other sites More sharing options...
Kb27 Supersonic August 13, 2018 Share August 13, 2018 So tempted to disconnect the negative polarity of my battery and try to jump start the car with my new jumper toy. Is there other way to do it? Leave your lights on overnight to drain the battery. Room light, hazard light will work. Some cars may not allow you to leave the main headlight on when the ignition is off, for those that can, leave the main headlight on, when the ignition is off. Link to post Share on other sites More sharing options...
Kb27 Supersonic August 13, 2018 Share August 13, 2018 What do the pros use to save the settings? Some OBD tool? There are various methods. You can use OBD connector or the DC socket to connect to a secondary battery. But you need to watch for current pull from that socket bcuz the current is limited or it may melt fuse and plastics. On cars with front jump points like BMW, Merz or Audi, I prefer to connect a battery there. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear August 13, 2018 Share August 13, 2018 What do the pros use to save the settings? Some OBD tool? yup ODB tool. Link to post Share on other sites More sharing options...
inlinesix Supersonic August 14, 2018 Share August 14, 2018 There are various methods. You can use OBD connector or the DC socket to connect to a secondary battery. But you need to watch for current pull from that socket bcuz the current is limited or it may melt fuse and plastics. On cars with front jump points like BMW, Merz or Audi, I prefer to connect a battery there. For BMW, Merc or Audi, keys has all the setting. Link to post Share on other sites More sharing options...
Angcheek Hypersonic August 16, 2018 Share August 16, 2018 For BMW, Merc or Audi, keys has all the setting. know any good WS to change the batt ? how muchie ? 1 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear August 19, 2018 Share August 19, 2018 Today, did a check today, 12.7V seems OK for a near 1 year old stock battery. Did it because my neighbour's car cannot start lor, 10.5V. His car 24/7 Dashcam lor. Link to post Share on other sites More sharing options...
jumpwarrior September 11, 2018 Share September 11, 2018 All these ICE really take up a lot of battery power eh. 24/7 dashcam will definitely kill the battery quicker than normal. I was looking at some new batteries - Lithium-iron batteries, have y'all heard of them before? Quite impressive leh. Anyone know where to get? TIA Link to post Share on other sites More sharing options...
inlinesix Supersonic September 11, 2018 Share September 11, 2018 All these ICE really take up a lot of battery power eh. 24/7 dashcam will definitely kill the battery quicker than normal. I was looking at some new batteries - Lithium-iron batteries, have y'all heard of them before? Quite impressive leh. Anyone know where to get? TIA For dashcam, just install a battery to power lo. For Lithium ion battery, I think only high end super car use it. Link to post Share on other sites More sharing options...
Kusje Supersonic September 11, 2018 Share September 11, 2018 For dashcam, just install a battery to power lo. For Lithium ion battery, I think only high end super car use it. dash cam either get an external battery or have a cut off switch to cut off the cam if voltage falls below a certain number. Link to post Share on other sites More sharing options...
ElyasCham September 17, 2018 Share September 17, 2018 Honestly, I see only the age of battery ... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
My EV journey to the i4
Fatty Kim going crazy again
Battery Voltage up & down
Hdb flat renovation
Hdb flat renovation
Request for dark mode
The Electric Vehicle Charging Problem
Going to Polyclinic
Going to Polyclinic
