raymonnnn 1st Gear May 27, 2016 Share May 27, 2016 I am unable to link WAZE to HU too, not as easy to link mobile phone or connect usb as i thought.Me too. Anyone know how to link it? If we can use google map on this head unit I think it's the best ↡ Advertisement Link to post Share on other sites More sharing options...
rabindek Neutral Newbie May 29, 2016 Share May 29, 2016 Hi all, I just got this player yesterday and it's been pretty difficult so far. I can't connect my Samsung S7 Edge to it, keeps prompting me that it's an "Incompatible USB." I've also tried updating the firmware by connecting a thumbdrive formatted to FAT32 with the update file in it, as instructed, and it says "Incompatible USB" as well. Any one facing the same issue and has resolved it? Link to post Share on other sites More sharing options...
ILGTCA Neutral Newbie May 29, 2016 Share May 29, 2016 (edited) http://www.cnet.com/roadshow/news/unlock-full-android-app-mirroring-on-your-dashboard-with-this-appradio-hack/ Anyone with Android phone tried this? Hi all, I just got this player yesterday and it's been pretty difficult so far. I can't connect my Samsung S7 Edge to it, keeps prompting me that it's an "Incompatible USB." I've also tried updating the firmware by connecting a thumbdrive formatted to FAT32 with the update file in it, as instructed, and it says "Incompatible USB" as well. Any one facing the same issue and has resolved it? http://appradioworld.17289.n7.nabble.com/AVH-X5500BHS-Help-quot-Incompatible-USB-quot-td341.html Try above? Edited May 29, 2016 by ILGTCA Link to post Share on other sites More sharing options...
rabindek Neutral Newbie May 29, 2016 Share May 29, 2016 http://www.cnet.com/roadshow/news/unlock-full-android-app-mirroring-on-your-dashboard-with-this-appradio-hack/ Anyone with Android phone tried this? http://appradioworld.17289.n7.nabble.com/AVH-X5500BHS-Help-quot-Incompatible-USB-quot-td341.html Try above? Thanks for your quick reply. First suggestion not applicable as I'm not using a rooted phone, second suggestion doesn't help :( Link to post Share on other sites More sharing options...
raymonnnn 1st Gear May 29, 2016 Share May 29, 2016 Thanks for your quick reply. First suggestion not applicable as I'm not using a rooted phone, second suggestion doesn't help :(Did you set the smartphone setting to other phone rather than "iPod/iPhone"? I'm using iPhone and there's no issue so far with the usb connection. But I reckon I'll use the usb often as Bluetooth is more convenient. Link to post Share on other sites More sharing options...
rabindek Neutral Newbie May 29, 2016 Share May 29, 2016 Did you set the smartphone setting to other phone rather than "iPod/iPhone"? I'm using iPhone and there's no issue so far with the usb connection. But I reckon I'll use the usb often as Bluetooth is more convenient.Yup I did. I tried both USB option and Appradio one too but it keeps saying Incompatible USB. Link to post Share on other sites More sharing options...
raymonnnn 1st Gear May 29, 2016 Share May 29, 2016 Yup I did. I tried both USB option and Appradio one too but it keeps saying Incompatible USB.Did you use the original Samsung USB cable? Perhaps you should bring the car back to the place you install the head unit to ask them why it doesn't work Link to post Share on other sites More sharing options...
rabindek Neutral Newbie May 30, 2016 Share May 30, 2016 Yes, original cables. It says the same thing even when I plug in a thumbdrive. Yup I'll be doing that later. Link to post Share on other sites More sharing options...
Kangs Neutral Newbie July 1, 2016 Share July 1, 2016 just installed this HU. however, when I tried to play avi files via USB, it keeps saying unplayable file. anyone has the same problem?I just changed my HU to 5850 and I cant play any clips/movies using USB. Have you found a solution for this?Got this Hu recently, playing movies on it is a pain.Exactly! Tried converting the movies to lower resolution but also can't play. I used the exact original MP4 movie and play the USB in my friend's 8750, no problem at all. Link to post Share on other sites More sharing options...
Francis247 Neutral Newbie July 1, 2016 Share July 1, 2016 I am facing the same problem too when using USB to play video files. Keep getting "Unplayable File" message. Anyone got this problem also? Link to post Share on other sites More sharing options...
Francis247 Neutral Newbie July 2, 2016 Share July 2, 2016 I just changed my HU to 5850 and I cant play any clips/movies using USB. Have you found a solution for this? Exactly! Tried converting the movies to lower resolution but also can't play. I used the exact original MP4 movie and play the USB in my friend's 8750, no problem at all. I solved my problem using the Xilisoft Video Converter. But the videos are a bit lagging. But better than nothing. Link to post Share on other sites More sharing options...
raymonnnn 1st Gear July 3, 2016 Share July 3, 2016 I solved my problem using the Xilisoft Video Converter. But the videos are a bit lagging. But better than nothing. What is the video format you convert to? I changed the file from MP4 to mkv which should be compatible but still can't play on the headunit... By right they only can play mpeg4, mkv and another video format which I forgot. PS: Mpeg4 and MP4 is different file format. Link to post Share on other sites More sharing options...
Francis247 Neutral Newbie July 3, 2016 Share July 3, 2016 What is the video format you convert to? I changed the file from MP4 to mkv which should be compatible but still can't play on the headunit... By right they only can play mpeg4, mkv and another video format which I forgot. PS: Mpeg4 and MP4 is different file format. Hi Raymonnn, I am using MPEG-4. MP4 and MPEG-4 are different. Other usable formats include DIVX, AVI. Still have not try WMA yet. So far I think MPEG-4 format has lesser lag as compared to DIVX and AVI. My Video ratio is 640 x 360. I observed that the higher the video ratio, it become more lag. Link to post Share on other sites More sharing options...
Gtsr Neutral Newbie September 19, 2016 Share September 19, 2016 anyone using appradio live waze and using the radio at the same time? now i can only choose 1 of the above. cannot run concurrently Link to post Share on other sites More sharing options...
deqwan Neutral Newbie September 29, 2016 Share September 29, 2016 i already install avh x5850bt... the problem is why every i turn off engine.. and turn on back... the player need to setup back... Language, date and time... Link to post Share on other sites More sharing options...
macrosszero Turbocharged September 29, 2016 Share September 29, 2016 anyone using appradio live waze and using the radio at the same time? now i can only choose 1 of the above. cannot run concurrently App side issue. Update your app and you should be able to enjoy both.i already install avh x5850bt... the problem is why every i turn off engine.. and turn on back... the player need to setup back... Language, date and time...Seems that the backup battery in your HU is dead. If it is a newly bought unit go back to installer. Link to post Share on other sites More sharing options...
Bluestarz2 Neutral Newbie October 31, 2016 Share October 31, 2016 Hi, like to find out can pioneer head unit connect to Alphine 701 processor? Because I will be getting new car and transferring my car audio into the new car and plan to replace the stock head unit. My new car is Toyota wish,not sure how good is the stock head unit ? Link to post Share on other sites More sharing options...
azaouogh 2nd Gear January 8, 2017 Share January 8, 2017 Hello everyone. I plan to purchase this head unit however it appears that this head unit cause alot of problems, no? ↡ Advertisement Link to post Share on other sites More sharing options...
[Seek experts' views] Pioneer Z9250BT vs stock HU
Car immobiliser and GPS tracker recommend?
Is Standalone GPS obsoleting?
Dashcam with GPS
Dashcam with GPS
Car Accessories Workshop in West Area
pioneer sda-835 tab
pioneer sda-835 tab
Pioneer z9250bt keep losing GPS after sometimes.
Needs comment for HU - Pioneer AVH-Z5050BT
