AltisOwner Turbocharged September 9, 2016 Share September 9, 2016 1. Yes the rear plate very filmsy as only secure by two screws at the top. I use double sided tape and tape the lower part of the number plate. Now very good. 2. Yes steering Wheel vibrate when idle and notice its at 740RPM. A bit too low in my opinion. Not sure if can adjust higher during next service? Another point to share: During pumping of petrol till "auto stop" , the fuel meter barely "touch" Full Tank. Brought it up during my 1st 1000Km service and they check with their "meter" and now every time I pump petrol till "auto stop" its shows above Full Tank now. Good!!!! Not sure what they did, when I asked them they just said, We cannot calibrate but only check and test. Was done at Toyota Sin Ming. Above just FYI Normally the steering wheel should not be vibrating when idle. Most likely the rpm is a bit low, the best is get it adjust to 800rpm the vibration would be solved. ↡ Advertisement Link to post Share on other sites More sharing options...
tenyawph Turbocharged September 9, 2016 Share September 9, 2016 Just want to share some points i noticed with others who may be considering the camry: 1. Suspension is definitely stiffer then previous camry (2006). But i actually like this suspension set up. I drove the 2002-2006 Camry and it is more comfortable compared to the current Camry in the sense that you don't feel the minor bumps on the road. With the new 2015 Camry, the suspension has been made stiffer than the 2002-2006 version, so now you get more of the 'road feel', and hence the more 'bumpy' feeling. I am not used to it in the beginning; it took me quite a while to get used to this feeling. Btw, the Camry which we bought comes with the Bodycare service (only available at Pandan Crescent branch) to be claimed within 1-year of owning the car. Apparently, Borneo has waived the $60 deductible for each small scratch / chip. It is now FOC to re-spray up to 2 panels, to be claimed within 1 year. Both my left and right door panels have scratches. The right door panel has 1 long vertical, and 2 tiny ones. See picture below. FYI, you cannot book an appointment thru' the phone. I drove to Pandan Crescent and got the technical adviser to take a look at my car. I booked the earliest possible date available: 8 Dec 2016. It will take 5 days, i.e. 13 Dec to collect my car back. The backlog is 3 months now. Lastly, the roof-top of the car is very prone to water marks. Less on the bonnet and the top of the car boot section. Link to post Share on other sites More sharing options...
AltisOwner Turbocharged September 9, 2016 Share September 9, 2016 I drove the 2002-2006 Camry and it is more comfortable compared to the current Camry in the sense that you don't feel the minor bumps on the road. With the new 2015 Camry, the suspension has been made stiffer than the 2002-2006 version, so now you get more of the 'road feel', and hence the more 'bumpy' feeling. I am not used to it in the beginning; it took me quite a while to get used to this feeling. Btw, the Camry which we bought comes with the Bodycare service (only available at Pandan Crescent branch) to be claimed within 1-year of owning the car. Apparently, Borneo has waived the $60 deductible for each small scratch / chip. It is now FOC to re-spray up to 2 panels, to be claimed within 1 year. Both my left and right door panels have scratches. The right door panel has 1 long vertical, and 2 tiny ones. See picture below. Vertical Scratch IMG_5576.JPG FYI, you cannot book an appointment thru' the phone. I drove to Pandan Crescent and got the technical adviser to take a look at my car. I booked the earliest possible date available: 8 Dec 2016. It will take 5 days, i.e. 13 Dec to collect my car back. The backlog is 3 months now. Lastly, the roof-top of the car is very prone to water marks. Less on the bonnet and the top of the car boot section. wah! backlog 3 months and it take 5 days to collect back..........eerrrrrrrrrrr they sold so many cars that's the result :) Thanks for the info. Link to post Share on other sites More sharing options...
A3DI Neutral Newbie September 9, 2016 Share September 9, 2016 I drove the 2002-2006 Camry and it is more comfortable compared to the current Camry in the sense that you don't feel the minor bumps on the road. With the new 2015 Camry, the suspension has been made stiffer than the 2002-2006 version, so now you get more of the 'road feel', and hence the more 'bumpy' feeling. I am not used to it in the beginning; it took me quite a while to get used to this feeling. Btw, the Camry which we bought comes with the Bodycare service (only available at Pandan Crescent branch) to be claimed within 1-year of owning the car. Apparently, Borneo has waived the $60 deductible for each small scratch / chip. It is now FOC to re-spray up to 2 panels, to be claimed within 1 year. Both my left and right door panels have scratches. The right door panel has 1 long vertical, and 2 tiny ones. See picture below. Vertical Scratch IMG_5576.JPG FYI, you cannot book an appointment thru' the phone. I drove to Pandan Crescent and got the technical adviser to take a look at my car. I booked the earliest possible date available: 8 Dec 2016. It will take 5 days, i.e. 13 Dec to collect my car back. The backlog is 3 months now. Lastly, the roof-top of the car is very prone to water marks. Less on the bonnet and the top of the car boot section. Wah the scratch looks deep.. What happen? Stone chip? Heard from SE that they no longer offer the bodycare service because a lot ppl complain about bad workmanship. Anyway i noticed the door panel beside the front seat is not covered like it was in the older camry. Was wondering if this is normal? I remember seeing it being covered in other countries. Link to post Share on other sites More sharing options...
ClearVision Clutched September 9, 2016 Share September 9, 2016 There is no tel button on the steering wheel. Besides touching the MediaScreen, is there any other way to pick up and answer tel calls? Any info appreciated. Thanks Link to post Share on other sites More sharing options...
csf 2nd Gear September 9, 2016 Share September 9, 2016 1. Yes the rear plate very filmsy as only secure by two screws at the top. I use double sided tape and tape the lower part of the number plate. Now very good. 2. Yes steering Wheel vibrate when idle and notice its at 740RPM. A bit too low in my opinion. Not sure if can adjust higher during next service? Another point to share: During pumping of petrol till "auto stop" , the fuel meter barely "touch" Full Tank. Brought it up during my 1st 1000Km service and they check with their "meter" and now every time I pump petrol till "auto stop" its shows above Full Tank now. Good!!!! Not sure what they did, when I asked them they just said, We cannot calibrate but only check and test. Was done at Toyota Sin Ming. Above just FYI My fuel gauge starts to drop after 40+ km from full, and drop to 3/4 at about 100km. When warning light comes on, distance traveled is 540km. Since the tank is 70 litre, there should still be 20 litre left. in my old 2005/6 camry, needle started to drop after 100km from full and can travel 500+ km with fuel gauge at 1/4. I think my fuel gauge is not correctly calibrated but service center at ubi said it's normal. What you owners think? Link to post Share on other sites More sharing options...
teomingern 6th Gear September 10, 2016 Share September 10, 2016 The remaining mileage reflected on the trip computer depends on your fuel consumption. It's calculated based on how many km per litre you can achieve averaged over the whole tank of fuel. As time pass, you will get a more stable figure. Link to post Share on other sites More sharing options...
vslingam Neutral Newbie September 12, 2016 Share September 12, 2016 There is some news that an all-new (not face-lifted) Camry 2.0 may be coming sometime in 2017. It is supposed to have completely new body shape, bigger windows. new light weight chassis, and perhaps turbo with CVT. Any info? Link to post Share on other sites More sharing options...
Variodical 2nd Gear September 12, 2016 Share September 12, 2016 (edited) Yes, that's the new Camry on the TNGA platform, with a low sill and large greenhouse.It will be launched in US market first and local model probably coming in 2018. The 2.0 turbo is meant to replace the 3.5 V6 over there while the new Camry 2.0 will likely use the current 2.0's NA 6AR-FSE engine. Maybe they will put the 2.0 turbo as a higher end model, like the Civic Turbo. Edited September 12, 2016 by Variodical Link to post Share on other sites More sharing options...
A3DI Neutral Newbie September 13, 2016 Share September 13, 2016 Yes, that's the new Camry on the TNGA platform, with a low sill and large greenhouse.It will be launched in US market first and local model probably coming in 2018. The 2.0 turbo is meant to replace the 3.5 V6 over there while the new Camry 2.0 will likely use the current 2.0's NA 6AR-FSE engine. Maybe they will put the 2.0 turbo as a higher end model, like the Civic Turbo. Would be interesting if we will have the US Camry. Still not sure if they will bring in the US version one though. Their version of camry and ours seems to be quite different. Link to post Share on other sites More sharing options...
Nonewposts 4th Gear September 13, 2016 Share September 13, 2016 Would be interesting if we will have the US Camry. Still not sure if they will bring in the US version one though. Their version of camry and ours seems to be quite different. Asian market will get a different model Link to post Share on other sites More sharing options...
teomingern 6th Gear September 15, 2016 Share September 15, 2016 Asian markets will always get a different model from the US unless there's a global model. But the Camry is such an important seller in the US, that alone ensures that it will be tweaked just for the US market and usually is exclusive to that market. It's quite often the case for the mid-sized car segment in the US. Link to post Share on other sites More sharing options...
Ct3833 Supersonic September 22, 2016 Share September 22, 2016 Would be interesting if we will have the US Camry. Still not sure if they will bring in the US version one though. Their version of camry and ours seems to be quite different. Have been taking uber hybrid camry between san fran downtown and milbrea these few days, i thought their camry looks quite similar to ours. By the way did KM stop selling 2.0L camry ? No more price list. Link to post Share on other sites More sharing options...
L23 6th Gear September 22, 2016 Share September 22, 2016 Have been taking uber hybrid camry between san fran downtown and milbrea these few days, i thought their camry looks quite similar to ours. By the way did KM stop selling 2.0L camry ? No more price list. Since when KM is selling Camry ? Link to post Share on other sites More sharing options...
13177 Supersonic September 22, 2016 Share September 22, 2016 Since when KM is selling Camry ? Thats why cant find camry on KM price list lo. Lol. 1 Link to post Share on other sites More sharing options...
Nonewposts 4th Gear September 22, 2016 Share September 22, 2016 Have been taking uber hybrid camry between san fran downtown and milbrea these few days, i thought their camry looks quite similar to ours. By the way did KM stop selling 2.0L camry ? No more price list. They want to push for the 2.5 sales Link to post Share on other sites More sharing options...
Heman75 Supercharged September 22, 2016 Share September 22, 2016 Have been taking uber hybrid camry between san fran downtown and milbrea these few days, i thought their camry looks quite similar to ours. By the way did KM stop selling 2.0L camry ? No more price list. A spy who got his AD boss mixed up... Link to post Share on other sites More sharing options...
lun71 2nd Gear September 22, 2016 Share September 22, 2016 Seems BM no longer selling the 2L camry? ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
2024 camry
2024 camry
Toyota Corolla Cross
