Atrecord Supersonic October 5, 2016 Share October 5, 2016 Just give them a yoke. Pull to accelerate. Pull and hold to maintain speed. Release to slow down / stop. Yoke only operate with two hands on it. No more handphone or handjob driving = no more handgun. Or can learn from the m113 that i had in NS. Sure won't mix up cos there's only 1 pedal, the accelerator. Step if you want to move forward. There are also 2 vertical levers that control the 2 tracks (or wheels if applied here): pull them if you want either/both sides to brake. This means if you want to move forward, don't pull the brake levers at all, and step on the pedal. If you want to turn right, pull the right lever while stepping on the pedal. If you want to turn left, pull the left lever while stepping on the pedal. If want to brake, pull both levers together, and let go pedal. If like this also cannot, suggest the cab drivers change job go do something else... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged October 6, 2016 Share October 6, 2016 The buzz word in my office is AGILE. If 1 is not agile, 1 is OUT. It clear shows that taxi driver in Sg is NOT agile. Agile is a methodology. Agile used wrongly in the office will result in a outcome of cheaper better faster safer.. Which will result in a thought process of adding value by working longer hours instead of working better to deliver the right results 1 Link to post Share on other sites More sharing options...
Stooky 6th Gear November 29, 2016 Author Share November 29, 2016 Another suspected case of SUA. Taxi driver claimed his sonata suddenly surged forward after dropping passenger off Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 29, 2016 Share November 29, 2016 (edited) I am curious, while the electronics may cause a car to surge forward suddenly, cant the driver step hard on the brake which is mechanically controlled to stop the car from further movement or at least to slow down the forward speed? The taxi in this accident seemed to have gone wild for extended distance. Anyone who have the knowledge in this area may want to shed some light on how to handle such situations? Edited November 29, 2016 by Ct3833 Link to post Share on other sites More sharing options...
Mustank Hypersonic November 29, 2016 Share November 29, 2016 yes, the habit is baffling. I was once in a Prius and the cabbie decided to rev the engine very hard in the Ion drop off driveway. never understood why, just paid my fare and left. Phoon orh yen Link to post Share on other sites More sharing options...
Blueray Hypersonic November 29, 2016 Share November 29, 2016 Phoon orh yen Boss, Prius boh orh yen one. But seriously, I fail to understand why taxis like to rev hard in drop off driveways, MSCPs ... Link to post Share on other sites More sharing options...
flashbang Turbocharged November 29, 2016 Share November 29, 2016 I am curious, while the electronics may cause a car to surge forward suddenly, cant the driver step hard on the brake which is mechanically controlled to stop the car from further movement or at least to slow down the forward speed? The taxi in this accident seemed to have gone wild for extended distance. Anyone who have the knowledge in this area may want to shed some light on how to handle such situations? http://www.popularmechanics.com/cars/how-to/a5206/4344079/ In short 1. Step on brake pedal hard and don't release it, else you won't be able to brake again 2. shift to neutral 3. Shut off engine Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 29, 2016 Share November 29, 2016 http://www.popularmechanics.com/cars/how-to/a5206/4344079/ In short 1. Step on brake pedal hard and don't release it, else you won't be able to brake again 2. shift to neutral 3. Shut off engine Thanks for sharing. maybe the quickest solution would be to turn off engine. Any concerns? Link to post Share on other sites More sharing options...
Vinceng Turbocharged November 29, 2016 Share November 29, 2016 Another suspected case of SUA. Taxi driver claimed his sonata suddenly surged forward after dropping passenger off Taxi fitted with China made Westlake tyres. http://www.cbsnews.com/news/importer-recalls-chinese-made-tires/ Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 29, 2016 Share November 29, 2016 Thanks for sharing. maybe the quickest solution would be to turn off engine. Any concerns? That is the best,but,when the Car started to lose control,most Driver will be too shock to do this. 1 Link to post Share on other sites More sharing options...
Nlatio Turbocharged November 29, 2016 Share November 29, 2016 No, taxi driver will come out to protest if it is change to MT..... fatigue, difficult to drive as main reason..... the unspoken reason.... they cannot use the excuse that their taxi ki siao and any how cheong.... they will lost their deposit... 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 29, 2016 Share November 29, 2016 No, taxi driver will come out to protest if it is change to MT..... fatigue, difficult to drive as main reason..... the unspoken reason.... they cannot use the excuse that their taxi ki siao and any how cheong.... they will lost their deposit... Basing on the Mandarin narrative, the taxi driver claimed that he did not step on the accelerator. 1 Link to post Share on other sites More sharing options...
Nlatio Turbocharged November 29, 2016 Share November 29, 2016 Basing on the Mandarin narrative, the taxi driver claimed that he did not step on the accelerator. ya.... with $2k deposit at stake, I will say the same thing. 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 29, 2016 Share November 29, 2016 Easy to blame it on the car when it's just an item. 东西是死的,人是活的。 1 Link to post Share on other sites More sharing options...
Dark 5th Gear November 30, 2016 Share November 30, 2016 Thanks for sharing. maybe the quickest solution would be to turn off engine. Any concerns? Don't ever do that. There was once my car stalled while going down the car park ramp. The steering become heavy and the brakes become hard as both power steering and brake pump not functioning. I was lucky that the lot right in front of the ramp was empty and I barely stopped the car in time. That was quite scary. 2 Link to post Share on other sites More sharing options...
13177 Supersonic November 30, 2016 Share November 30, 2016 Sonata taxi still have so many problems?! But this taxi should be dying off soon for another 1-2 years liao. Link to post Share on other sites More sharing options...
therock Supersonic November 30, 2016 Share November 30, 2016 It used to be the Crown, the Wish,then the Sonata and Renault. What's the next car to be used? 1 Link to post Share on other sites More sharing options...
Mkl22 Twincharged November 30, 2016 Share November 30, 2016 http://www.popularmechanics.com/cars/how-to/a5206/4344079/ In short 1. Step on brake pedal hard and don't release it, else you won't be able to brake again 2. shift to neutral 3. Shut off engine I guess it's easy to say. Most will panick and only slam the brakes but not hard enough or if the power is too great overwhelm the brakes. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
Chinese flying taxi maker EHang sells autonomous passenger drone for US$332,000 on Taobao as nation’s low-altitude economy takes off
