  • 1
  • Search this thread
  • Reply to this topic
14 replies to this topic | 0 praises
#1
Posted 28 May 2016 - 10:39 PM
Keen
  • THREAD STARTER
  • Premium member
    Keen
    4th Gear
    Author Image
    501
Turn steering wheel, let go of wheel, car keeps turning - HELP
I went for wheel alignment, all is good. 2 reputable workshop can't find any solutions. 🙁
#2
Posted 29 May 2016 - 02:15 AM
JohnSHL
  • Premium member
    JohnSHL
    Supercharged
    Author Image
    6,386
u mean the steering wheel doesn't self-center after u release the steering wheel?
or steering wheel is straight but car turns? slight pull or very severe?
#3
Posted 29 May 2016 - 11:27 AM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    49,617
What has this got to do with wheel alignment? It's either the steering rack got problem or the front suspension struts got problem.
#4
Posted 29 May 2016 - 10:24 PM
Ct3833
  • Ct3833
    Supercharged
    Author Image
    7,119
If your car is a subaru , refer to this...
http://www.cnet.com/...teering-issues/
Otherwise, you may want to describe your situation more specifically.
#5
Posted 30 May 2016 - 08:14 PM
Count-Bracula
  • Premium member
    Count-Bracula
    2Fast2Furious
    Author Image
    28,033
Sounds like bumper car leh [laugh]  [:p]
Me Newcastle fan
#6
Posted 31 May 2016 - 02:11 PM
Keen
  • THREAD STARTER
  • Premium member
    Keen
    4th Gear
    Author Image
    501
Both workshop are not confident that after steering rack recondition/replace will definitely solve the problem. :(
At high speed, the steering wheel seem loose though and it's scary
Edited by Keen, 31 May 2016 - 02:12 PM.
#7
Posted 06 June 2016 - 10:40 AM
Passion
  • Premium member
    Passion
    Supercharged
    Author Image
    5,194
Can describe the problem more specifically? Like that how to troubleshoot?
You mean the steering wheel don't auto self centre?
#8
Posted 06 June 2016 - 10:47 AM
Pocus
  • Pocus
    NOS-ed
    Author Image
    14,129
I think I know why the workshops cannot solve the problem. Cos TS can't even describe the problem properly.
#9
Posted 06 June 2016 - 10:56 AM
Myxilplix
  • Myxilplix
    NOS-ed
    Author Image
    15,251
Check your caster angle lor.
A line of paint on a road holds more authority than I ever will.
#10
Posted 06 June 2016 - 11:02 AM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    49,617
I think he went to the wrong ppl to fix his steering issue. This common issue of cannot self center is either caused by the steering rack or the front suspension strut bearings. He has to go to a car mechanic. Going to a wheel alignment tire shop to check wheel alignment has already checked out ok. But solving the steering issue the tire shop ppl aren't confident is because they are not the right ppl to go to.
Edited by Watwheels, 06 June 2016 - 11:03 AM.
#11
Posted 06 June 2016 - 12:57 PM
Passion
  • Premium member
    Passion
    Supercharged
    Author Image
    5,194
I think so too.
If car can't go straight, there are many reasons. Alignment is just one of them. When steering wheel is fitted back without aligning properly after dismantling, the same can happen too. During alignment, steering wheel not straighten, and do alignment, the alignment also can be not accurate.
If steering cannot return, maybe power assisted steering gone also possible. Steering rack jam or gear broken also possible. Everything also can.
TS - If steering can't turn, go tyre shop no use. You should go to mechanic.
But I think, if you go, you sure kena carrot until.... cause you don't know what's wrong. They can just anyhow ketok you.
#12
Posted 07 June 2016 - 09:56 PM
Keen
  • THREAD STARTER
  • Premium member
    Keen
    4th Gear
    Author Image
    501
ok, maybe I did not explained it clearly. To be more precise, the steering wheel seem to slip when i turn 45 degres. it will slip and make a full lock unless I hold on to the steering wheel tightly.
Other then that, when on highway speed, a slight bump will cause the car to slightly lose traction.
At first I thought its alignment issue, which is why I went to alignment shop. afterwhich I went to 2 different workshop but none could pinpoint any problem.
Am at a lost now :(
#13
Posted 09 June 2016 - 11:23 AM
Passion
  • Premium member
    Passion
    Supercharged
    Author Image
    5,194
Am at a lost now :(
Check your steering rack. Got something like a gear in it. I think the gearing is gone. I guess it will only slip to one side?
#14
Posted 13 October 2017 - 02:50 PM
ismailmiller
  • ismailmiller
    Author Image
    2
Hi Guys,
I have a similar issue with my Corolla Altis, 2010 Model. Steering wheel alignment done but during driving when car is approaching uneven surface, for e.g a small bump on the road, car will drift to the left - Steering wheel turn left 15 degrees sharply(when front left wheel goes over the bump). Funny thing is when there is a right bump, the drifting is not observable. I went to 2 different car workshops and they cant diagnose it, except one workshop found one of my tire slightly worn out - just hit the safety line which I asked them to do tire rotation. Any recommended workshops before I go to Borneo Motors to resolve this issue?
Best Regards,
Mail
#15
Posted 20 October 2017 - 08:00 PM
Keen
  • THREAD STARTER
  • Premium member
    Keen
    4th Gear
    Author Image
    501
Hi Guys,
Best Regards,
Mail
"- Steering wheel turn left 15 degrees sharply(when front left wheel goes over the bump)"
This is exactly what I am facing and till date I still have not got the issue solved.
  • 1
Dynamics Mechanic Pte Ltd
CLH Tyres Trading
CLH Tyres Trading  |  Rating   Submit Review
Reviewed by Put8pit0  |  Clutched
Top notch service from their friendly mechanics who take pride in their work. They are very patient with me by explaining to me all the issues as i really asked a lot of questions. They give professional advice and not just hard sell their products to me. This is what i like the most!
Will definitely be a returning customer! Will be even better if they have another... » Read More
Sat Motors (Workshop)
Sat Motors (Workshop)  |  Rating   Submit Review
Reviewed by Alexanderegrt  |  Neutral Newbie
Brushed my car against the wall and was recommended by a friend to this Paintshop.
Best paintshop by far the price is very competitive and the down time for the car in the workshop is very Short. Good job to Jonathan & His team in Handling my car with car. Got it back like Brand new ! » Read More
Related Motor Directory search on sgCarMart.com : Repair & Servicing
Quick Reply
Tags: honda, wheel, keep turning, help and 5 more...
