Pss2 2nd Gear June 18, 2016 Share June 18, 2016 My aircon circulation will turn off by itself at times. When weather is cooler like rainy days, it will keep turning off even i turn it on and it will turn off by itself 5 mins later. Anyone experience same? ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 18, 2016 Share June 18, 2016 Most Conti cars like this...My Kia also the same. Link to post Share on other sites More sharing options...
So_nice 6th Gear June 18, 2016 Share June 18, 2016 Erm..my Mitsubishi has the same problem. Is there a way to fix this shit? Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 18, 2016 Share June 18, 2016 Erm..my Mitsubishi has the same problem. Is there a way to fix this shit? Can,seal up the fresh air intake... 2 Link to post Share on other sites More sharing options...
Amazon777 3rd Gear June 18, 2016 Share June 18, 2016 Both my expired E60 and current W204 all like that, but I remember bimmer can be programmed to always on i.e outside exhaust air cannot comes in. Are you driving any of these 2 popular make in SG? Or you driving Jag, Bentley etc.? Link to post Share on other sites More sharing options...
BenTong Turbocharged June 18, 2016 Share June 18, 2016 Set your air con temperature to 21 degree celcius.. And voila.. Link to post Share on other sites More sharing options...
Ct3833 Supersonic June 18, 2016 Share June 18, 2016 It is programmed that way. My car will open up air vent after 30min(if i remember the timing correctly), and if the outside temperture is lower than inside, the vent will also open up to avoid fogging. But in sgp we have never had the opportunity to experience this. Link to post Share on other sites More sharing options...
flashbang Turbocharged June 19, 2016 Share June 19, 2016 I think it depends on the car. Mine has an auto mode but if I override it, it will stay on recirculate all the way. Else by default auto mode puts it on fresh air intake. Link to post Share on other sites More sharing options...
macrosszero Turbocharged June 19, 2016 Share June 19, 2016 Locate and unplug the air vent motor. Of course, you would have made sure that the vent was in the closed position in the first place. Link to post Share on other sites More sharing options...
Nzy Twincharged June 19, 2016 Share June 19, 2016 Mine can turn off that feature so that it will remain in the re-circulation mode. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged June 19, 2016 Share June 19, 2016 Can,seal up the fresh air intake... Yup, Many Malaysian aircon workshop do this. The last round when I replace my cooling coil. the guy ask me wheher to permenantly seal it off... After thinking twice, I think better keep it optional, just in case I need fresh air if there is any foul smell in car. 10 Link to post Share on other sites More sharing options...
zackie51 1st Gear June 19, 2016 Share June 19, 2016 What does the car's manual say? 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic June 19, 2016 Share June 19, 2016 Ask your dealer whether they can program it to deactivate it. Most likely can. Anyway the purpose of letting in outside air is to dilute the carbon dioxide in the cabin. Carbon dioxide will make you sleepy, nausea and whatever aka uncomfortable. Link to post Share on other sites More sharing options...
Achtung 6th Gear June 19, 2016 Share June 19, 2016 Some say its a safety feature leh..... scared we die of carbon monoxide. Ask your dealer whether they can program it to deactivate it. Most likely can. Anyway the purpose of letting in outside air is to dilute the carbon dioxide in the cabin. Carbon dioxide will make you sleepy, nausea and whatever aka uncomfortable. Link to post Share on other sites More sharing options...
Pss2 2nd Gear June 20, 2016 Author Share June 20, 2016 Set your air con temperature to 21 degree celcius.. And voila.. i usually set 20. What's with 21? Some say its a safety feature leh..... scared we die of carbon monoxide. I heard of this before too. I guess i will just leave it since most conti i see people post here same problem (or maybe its programmed this way.) Link to post Share on other sites More sharing options...
BenTong Turbocharged June 20, 2016 Share June 20, 2016 (edited) i usually set 20. What's with 21? I heard of this before too. I guess i will just leave it since most conti i see people post here same problem (or maybe its programmed this way.) Think it's Programmed that way for most cars Conti Brands and some jap models. Keep the temperature 21 and below and the auto circulation thingy will stay. If above 21 May alternate b/w internal circulate and drawing air from outside when air con on auto. Edited June 20, 2016 by BenTong Link to post Share on other sites More sharing options...
Achtung 6th Gear June 20, 2016 Share June 20, 2016 i usually set 20. What's with 21? I heard of this before too. I guess i will just leave it since most conti i see people post here same problem (or maybe its programmed this way.) My Merc does that. When I smell fumes, I know it's turned off. Link to post Share on other sites More sharing options...
Jtb 6th Gear June 20, 2016 Share June 20, 2016 if there is a feature "Auto" definitely it turns it off and temp will not be accurate as car gets older due to the senor being stained with dirt. If there is a manual to switch over, can try hopefully it will not turn off unless thermostat is not working well now ↡ Advertisement Link to post Share on other sites More sharing options...
Car air-con
Car air-con
Home Aircon
Home Aircon
Addtional pusher fan in front of the air con condenser
Bad Auto Dealer - Salesman!
