Loud sound when engaging reverse gear (CVT)
Clement
Mitsubishi ASX with CVT (3 months)
Got this problem in the mornings when engaging the reverse gear after the car is parked overnight on a level ground.
It only happens when shifting from "P" to "R" where a loud sound (like something grinding or cracking) is heard and the car reverses normally.
In "D" mode everything is normal and no noise is heard.
Only happens like once or twice in a month, puzzling.
Anyone knows if this is a serious problem?
still under warranty, right?
go back to dealer soonest, nothing can do yourself
Ok, next time try put the gear in neutral before you pull the handbrake, then put to park.
This method like manual transmission to me. Lol.
die liao... it's your engine head gasket blown  [bounce1]
just joking  [:p] , but seriously, your car still under warranty but rather trust a bunch of strangers on some internet forum to diagnose your car?
  • Praise 3
Hypersonic
Do you shift to P after you parked, release the brakes then pull handbrake? If so, it might have cause this sound.
Next time try shift to P after you parked, pull handbrake then release the brakes.
yeah... should try this. If you shift to P then release brakes before pulling handbrake, a lot of the stress gets applied to the parking pawl, which can then cause noise when shifting out of P later on
Hypersonic
Yes yes, that's what I meant. The load of the car will be on the gearbox. I don't know how to describe it exactly but I hope TS know what we meant and give it a try.
All the best!
Aiya, after raining the brake rotors have a layer of rust. So when you shift from P to R you control your brakes to reverse. The contact between brake pad and rotor will have grinding noise. You first time driving?
Alright, seems that I am parking the car the wrong way.
Always put gear in P, then pull handbrake.
For those seeking for a possible solution,
found this on an American Nissan Versa Forum:
"You are causing excess wear, tear, and strain on your
transmission and need to change the way you park
immediately.
The parking pawl inside the transmission is not made to
hold the weight of the car, they are made simply to
prevent the car from rolling on a level surface. ANY
TIME You park a vehicle on an inclined surface you need
to use the parking brake. That is why they still exist in
every vehicle whether its an auto or manual they
are designed to hold the weight of a vehicle.
When you park your vehicle on your driveway, BEFORE
you put it in park while still holding the brake, you need
to pull your parking brake handle. Then, put it in park
and turn it off.
When you go to leave for work or
whatever, start your car, put your foot on the brake,
release the parking brake and then put it in reverse.
When you do this, you will no longer hear that loud pop
when putting it in gear. This is how to correctly park on
steep grades and prevents wear and possible failure of
the parking pawl which is inside your transmission and
will require disassembly to replace.
My driveway is very steep and I have to do it everyday."
LOL, am not a first time driver, am aware of the rusting problem.
No, it is not brake grinding noise, it is like a loud popping kind of sound.
Sort of like a small explosion, hard to describe the noise.
So have you tried it and solve your "sound" problem?
Yes, have tried it last night, no noise this morning.
Have to monitor and see if it comes back.
The strange thing is that my previous car also using CVT, does not have such a problem!
Have u check ur tire pressure?
Yes, tyre pressure is within the recommended spec.
Using TPMS so tyre pressure data is always displayed.
Yes, but this noise only appears once / twice a month.
Go to workshop got no noise, so hard for them to troubleshoot.
Yes, the first part is what I do!
The second part should be as follows:
- shift to N after parking
- pull handbrake
- shift to P
- release brake
- off the engine.
This is supposed to be the 'correct' way to park the car.
- pull handbrake
- shift to P
- release brake
- off the engine.
There is no supposed to be the correct way to park.  It all depends on how much u love your car.
Your order a bit not so correct aslo
- release brake: To release load from GB
- pull handbrake
- shift to P
- off the engine.
I usually off engine before shift to P as P has a locking mechanism.  But my current car does not allow me to off engine in N.
my sequence at parking lot:
- keep foot brake depressed
- shift to N
- apply park brake / pull handbrake
- release foot brake to allow vehicle minor movement before stop due to possible road surface inclination (may not need if pull handbrake much harder)
- shift to P
- off engine
may not apply to those with electronic park brake in recent new cars.
