  • Search this thread
  • Reply to this topic
23 replies to this topic | 41 praises
#1
Posted 18 August 2016 - 02:25 PM
Bossbthk
  • THREAD STARTER
  • Premium member
    Bossbthk
    1st Gear
    Author Image
    62
I recently changed a set of rims from a workshop.
i was assured that the set of rims i have chosen PCD 5 x 113 are able to fit my ride of PCD 5 x 112
after which after fixing, i felt the right front wobbling ... despite wobble nuts and fitting center ring...
#2
Posted 18 August 2016 - 02:30 PM
Strat
  • Premium member
    Strat
    6th Gear
    Author Image
    3,104
you kenna con by workshop...different pcd how to fit.
better go back to workshop and ask for refund or correct size PCD..
Beregond praised this
#3
Posted 18 August 2016 - 03:01 PM
UncleAtas
  • Premium member
    UncleAtas
    Supercharged
    Author Image
    7,135
Conversion plates.
Refer to signature guidelines
#4
Posted 18 August 2016 - 04:45 PM
Wallaw819
  • Premium member
    Wallaw819
    4th Gear
    Author Image
    546
So far never come across 5 x 113 before. Sure the pcd is correct?
Thaiyotakamli praised this
#5
Posted 18 August 2016 - 05:57 PM
Raychay
  • Premium member
    Raychay
    5th Gear
    Author Image
    1,431
114.3 is it?
#6
Posted 18 August 2016 - 06:16 PM
Bossbthk
  • THREAD STARTER
  • Premium member
    Bossbthk
    1st Gear
    Author Image
    62
114.3 is it?
pcd 5 x 113... because it is a new type of RIM manufactured to fit 112 and 114.3
The thing is ... the left front felt planted. But the right on speed 70, 80 and 90km/h has slight and numb vibration on the steering wheel
#7
Posted 18 August 2016 - 07:02 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    50,209
Edited. Actually different PCD cannot fit properly. Best is to avoid.
Edited by Watwheels, 18 August 2016 - 07:16 PM.
#8
Posted 18 August 2016 - 07:14 PM
Bossbthk
  • THREAD STARTER
  • Premium member
    Bossbthk
    1st Gear
    Author Image
    62
hmmm offset and all pretty decent. just that i was explained by them on the PCD would not make a significant difference.
Balancing & alignment all okie. hence i don't understand why only the right front vibrates instead of both the front vibrating.
left front is good.
Pardon me i can't mention the workshop name. i don't want to discredit them also. Just the ding dong is bit irritating.
i may ask them to replace me a set of rim with the right PCD. Just that i have to forego the chosen design.
Just want to raise this in forum to see if anyone has similar issue and solution.
They are quite good chaps also. willing and patience to rectify my problem.
Thanks fellow chaps for the inputs.
Regards,
#9
Posted 18 August 2016 - 07:43 PM
Thaiyotakamli
  • Premium member
    Thaiyotakamli
    2Fast2Furious
    Author Image
    55,592
left front is good.
Regards,
Please share with me the name, at least i know where to avoid
Pcd small diff also cannot. Unless stated in manual book
Beregond and Volvobrick praised this
Dont get confused between my personality & my attitude...
My personality is who I am...
My attitude depends on who you are...
#10
Posted 18 August 2016 - 08:00 PM
Raychay
  • Premium member
    Raychay
    5th Gear
    Author Image
    1,431
Never heard of such a thing!
My 1st 2nd hand car which had new rims and tyres also had vibrations at 80-90km/h.
Brought it to a tyre shop and found out that the car dealer used wrong PCD 4x100 instead of the correct 4x98, which was hard to find.
#11
Posted 19 August 2016 - 12:22 AM
Juzzme
  • Premium member
    Juzzme
    4th Gear
    Author Image
    521
Wobble bolts are quite commonly used overseas. I've run these for years without issues. 1mm correction is well within limits. But I used quality wobble bolts from BBS. Of the 5 holes, one is fitted with a normal bolt. The other 4 are wobble bolts, each tightened to the exact same torque.
#12
Posted 19 August 2016 - 08:28 AM
Wallaw819
  • Premium member
    Wallaw819
    4th Gear
    Author Image
    546
Yup can use wobble nut for slightly different pcd (I think <2mm) but must remember to use hubcentric ring if the CB is not exactly the same.
#13
Posted 19 August 2016 - 09:30 AM
Bossbthk
  • THREAD STARTER
  • Premium member
    Bossbthk
    1st Gear
    Author Image
    62
oh crap ... they used all 5 ... basket ... but i can't explain why the front felt smooth ... while the front right has that irritating vibration through the steering wheel...
To further elaborate. Rear staggered, without wobble nuts.  they use it in the front to minimise the vibration
i have doubts with the center ring also ... but when i inspect... it seems fitting...
really scratching the head for an answer ..
#14
Posted 19 August 2016 - 04:16 PM
Williamhha
  • Williamhha
    2nd Gear
    Author Image
    198
Is all the 4 tires same size? If same size, than swap the front right with the rear right to see if it still have the vibration feel. if still the same than it might not be the rim liao. B'cos if vibration is due to PCD, than both front wheels should be vibrating not only 1 side.
#15
Posted 20 August 2016 - 09:30 AM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,749
wobble bolts is OK
BUT , it does not work on any wheels
only known brands using or approved to use wobble bolt is OZ / BBS (because is stated in their Product book/ box , and usually they will supply together with the wheels)
same applies to
I have seen online selling wobble bolts , they are selling you the product and will not care about what and how you use them and what the consequences.
be a smart Consumers
#16
Posted 20 August 2016 - 09:33 AM
Blueray
  • Blueray
    2Fast2Furious
    Author Image
    88,754
my simple mind tells me
112 means 112
113 means 113
just me.  [:)]
focus
#17
Posted 20 August 2016 - 09:37 AM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,749
5x113 is really something new here
wobble bolts is around for may be 5 years or longer
saw them from wheels like BBS and OZ  PCD 5x110/112  5x100/98 4x100/98
and these usually came complete with the new wheels from wheel manufacturer
It applied to the same for Wheel spacer which come complete or optional from wheels manufacturer (you are safe)
I will suggest the Said car owner go back the shop who sold you the 5x113 wheels for his Advice (because they are the seller supposed to take care of this issue) which they can refer it to their supplier or Manufacturer for further study
#18
Posted 29 August 2016 - 03:13 PM
Bossbthk
  • THREAD STARTER
  • Premium member
    Bossbthk
    1st Gear
    Author Image
    62
done ...case close ... fall back to a rim with 5x112.
instantly less vibration felt through the steering...
#19
Posted 05 July 2018 - 09:53 PM
Stooky
  • Stooky
    6th Gear
    Author Image
    3,578
Anyone installed 5x113.1 rims on car with pcd 5x114.3? Tyre shop told me 5x113.1 rims are design to fit 114.3 and 112. How does it work?
Edited by Stooky, 05 July 2018 - 09:54 PM.
#20
Posted 05 July 2018 - 10:16 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    85,127
It works by going to another shop. Period.
Doppel praised this
QUOTE
do to others what you want others to do to you......
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Kaizen Motors Pte Ltd
Kaizen Motors Pte Ltd  |  Rating   Submit Review
Reviewed by marcstar  |  Neutral Newbie
Hard to find a workshop to do my Mazda but manage to settle my start stop battery replacement at Kaizen Motors. All done up nice and neat! Highly recommended.
Huat Lee Batteries & Motor Service Pte Ltd
Huat Lee Batteries & Motor Service Pte Ltd  |  Rating   Submit Review
Reviewed by tanbb001  |  Neutral Newbie
Honestly i was puzzled about the installation of Alcades. Usually for any mod to a car will involve tons of tool to a car so when Nigel told me this mod do not involve even a screw i was in doubt. I am driving a Toyota Picnic though its a sturdy car but the FC is on the high side. Since my days of car mob is over and now my concern is only on FC i decided to give Alcade... » Read More
Related Motor Directory search on sgCarMart.com : Tyres & Rims
Quick Reply
Tags: mercedes-benz, pcd 5 x 113 and 3 more...
