  • Search this thread
  • Reply to this topic
27 replies to this topic | 35 praises
#1
Posted 24 September 2016 - 09:16 AM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
I have experience lost of hydrophobic effect on a 6 months coating due to the amount of dirt and dust trapped on the surface and only used of iron removal then I am able to recover it..You will be surprise parking under a tree during heavy rain will leave a thick layer of bad elements on the surface.
So what is the best cleaning solution to use weekly or bi-weekly as a maintenance for PPS to lift off the dirt? Shampoo? plain water? etc?
Detailers would advise only wash with water after PPS, waxing or sealant or the most a PH neutral shampoo..
I did a small test to see how much water, shampoo and a solution O( I shall not name the product as this is not a sponsored thread) lift the dirt and clean surface.. The pictures are taken with handphone..Pardon me for the lousy pictures.
The car roof surface are marked with solution 0, water and shampoo.
Next I prepared a capful of shampoo, a capful of solution in the grit guard bucket and water in another bucket
2 clean wash mitt, one for solution O, one side for water, another side for shampoo on second wash mitt..
Some visible soiled watermarks on every surface before wash
I soaked the wash mitt into every solution, squeeze some water out of it..
Surface washed using the wash mitt with the respective solution.
Sorry to be continue later, going for my hobby...
Edited by Maddriver, 24 September 2016 - 07:51 PM.
WebsiteDuragloss Car Care products
WebsiteOptimum Car Care products
Contact : Call / SMS / WhatApps 93387370 Benny
#2
Posted 24 September 2016 - 01:54 PM
flashbang
  • Premium member
    flashbang
    NOS-ed
    Author Image
    11,092
Waiting for the rest of your story  :mellow:
Maddriver praised this
#3
Posted 24 September 2016 - 05:06 PM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
Ah gong tell story sibo...haha
#4
Posted 24 September 2016 - 05:14 PM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
Using a drying towel to wipe dry the surface
Did a visual check on each surface after drying..
Some visible water stains on the surface washed with water..For surface washed with solution O and shampoo, there are no visible stain from soil marks.
All 3 surfaces feel the same..
Edited by Maddriver, 24 September 2016 - 05:20 PM.
#5
Posted 24 September 2016 - 05:40 PM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
So how do I know which cleans better..Here are the wash mitt used.
I am not surprise that water don't clean and the shampoo do lift up some dirt..The solution 0 lift off the most dirt..
The surface are randomly pick. I do not know which is dirtier or cleaner..I presume they are the same since under one roof.
The next time if you feel your PPS or any sealant losing its effect..Try doing some claybaring, it helps but most important is using the right cleanser..A good Paint coating are suppose to be chemically resistance..if it cant even take a shampoo, I feel is not worth at all..
If you wish to know what solution I used to maintain my PPS? You can ask me here..http://www.mycarforu...27#entry5938816
Above are just a simple test for sharing..If you happy washing with water, shampoo or any solution..just continue to do so..
Edited by Maddriver, 24 September 2016 - 07:18 PM.
Hamburger, Mercury1 and flashbang praised this
#6
Posted 24 September 2016 - 07:21 PM
Wongcl
  • Premium member
    Wongcl
    3rd Gear
    Author Image
    296
Hi, just wanna ask, did u flush the surface with enough of the any of the solution (water, shampoo or solution O) so that they flow away from the surface? It looks like using solution O, a lot of dirt is still left on your bonnet and so when u wipe with cloth, it is the most dirty. On the other hand, if u flush with sufficient water and the dirt has been washed off, then it is reasonable to have little dirt on your cloth.
#7
Posted 24 September 2016 - 07:37 PM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
Hi..
I believe the surface are equally dirty since under one roof..No rinsing of any solution on surface. 2 white wash mitt for washing and yellow cloth for drying..I soak wash mitt in each solution and wash the each surface..Just 2 wipes on each surface then wipe dry using the yellow cloth to observe the surface for any water spot.. The 2 white wash mitt show how much dirt each solution lift..
Edited by Maddriver, 24 September 2016 - 08:02 PM.
#8
Posted 24 September 2016 - 07:45 PM
Wongcl
  • Premium member
    Wongcl
    3rd Gear
    Author Image
    296
Am I right to say if the towel is not dirty, then the dirt has been rinsed off the surface. that means PPS is working in containing the dirt
#9
Posted 24 September 2016 - 07:55 PM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
You mean the dry towel? Cant really tell if the dirt been rinse off from drying..is only when you have a white wash mitt during washing, probably can tell how much dirt is on surface with the right cleanser
Edited by Maddriver, 24 September 2016 - 08:01 PM.
#10
Posted 24 September 2016 - 09:01 PM
Wongcl
  • Premium member
    Wongcl
    3rd Gear
    Author Image
    296
yup..the white wash mitt is cleaner on the water and the shampoo side...which indicates that the dirt has been rinsed off earlier...while on the solution O side, it stays...so solution O seems to not help the PPS in clearing the dirt.
btw what is solution O?
#11
Posted 24 September 2016 - 09:21 PM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
We normally determine how much cleaning properties one has by looking at how dirty the mitt or the applicator,  similarly using a foam applicator with an AIO and a foam application with a wax working on a similar panel..you see how much cleaning properties has for an AIO but the wax has none..
Edited by Maddriver, 24 September 2016 - 09:28 PM.
#12
Posted 24 September 2016 - 09:32 PM
Optivax
  • Optivax
    Sponsor
    Author Image
    634
Sorry is more appropriate to use my nick Optivax for the content below..
Something to share, Interesting writeup from Dr David G the CEO/chemist for Optimum U.S. I copy and paste from another website..This is one reason I did a small test..
Before this article, A few of my customers told me they added ONR into shampoo and works very very well. They find that the surface are extremely clean compared using shampoo standalone..
"From the keyboard of David Ghodoussi, when asked to describe ONR VS soap. good information to know and share with your customers.
Soap is a blend of surfactants that are designed to emulsify (dissolve)
oils into water. There is nothing in soap to help with dirt removal.
Foam is a by product of soap and it is caused by entrapment of air in
soap and water. People perceive foam to create lubricity and correlate
it to concentration and cleaning ability of soap. In fact, manufacturers
add foamers to increase foam to capitalize on these misconceptions.
No Rinse is based on reactive polymers that have the ability to bond to surfaces as well as dirt or oily particles. These polymers have much greater lubricity than soap and form a film around the particles as well as paint to protect from marring. The concentration of these polymers is very high which is why only 1 oz. per wash is needed. In fact, when people use 3-4 oz., they complain about the excess lubricity and streaking! If anyone washes half their car with no rinse and the other half with soap, over time, they will see marring on the soap side only!
That is why many add no rinse to their soap bucket before washing which
works well. However, because of the nature of these reactive polymers,in concentrated form, they react with soap and foaming agents to form a gel (you can try this by mixing soap concentrate with no rinse). That is why we can not add foaming agents to no rinse!
The Water softening ability of ONR comes from bonding and removing minerals from water which takes place by the polymers in No Rinse in the same way as it bonds to dirt or other surfaces. The polymers remove minerals from water by bonding and trapping them similar to how they remove dirt particles and drop them down to the bottom of solution. There is nothing in soap that has that ability hence dirt or contaminants float in the solution. The reactivity of the polymers come from having both negatively charged and positively charged groups in the polymer which
gives it a zwitterionic character. It can therefore bond with any particle whether they are anionic or cationic in nature.
With the new no rinse wash and wax, we have further increased the
lubricity, gloss, and protection. There is no product out there that can
match the performance of these products."
Edited by Optivax, 24 September 2016 - 09:36 PM.
Website: www.optivax.com.sg
Contact: Benny @ 93387370 Call / SMS / Whatapps
Check out our Super Deal.
#13
Posted 24 September 2016 - 10:01 PM
flashbang
  • Premium member
    flashbang
    NOS-ed
    Author Image
    11,092
He didn't rinse the surface before washing
#14
Posted 26 September 2016 - 04:07 PM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
Here are some pictures on 2 different brand new cars which is less than a week.. There are some elements that are not easily remove by polishing, shampoo etc..
Is very obvious on white..I recommend to use every 6mths for any colour to remove iron from your surface..Is an iron x removal (please note not all iron x are safe for painted surface) please check first..As far as I know, the one I am using does not remove my car paint coating but I am not sure for the rest..
Edited by Maddriver, 27 September 2016 - 04:41 AM.
AltisOwner praised this
#15
Posted 02 October 2016 - 08:15 AM
7hm
  • Premium member
    7hm
    NOS-ed
    Author Image
    10,844
Maddriver, is "Solution O" a kind of quick detailer, or a waterless wash liquid?
I am interested in possibly starting to use waterless wash solutions on my PPS coated paint, but as you might imagine there aren't a lot of clear comparisons.
Driving car, not funny, bid for car with COE, ERP, road tax, PARF until you want to barf
Dabbler in digital graphics, computer assembly, tech and photography.
「さぁ、今、手を伸ばして 」
#16
Posted 02 October 2016 - 08:27 AM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
Hi 7hm, yes it is the optimum no rinse wash and shine.. for duragloss they have the no rinse with aquawax and optimum with no rinse wash n shine or no rinse wash n wax.. some call them waterless..basically all this products uses very little water..i was skeptical until i use them..
7hm praised this
#17
Posted 02 October 2016 - 08:31 AM
7hm
  • Premium member
    7hm
    NOS-ed
    Author Image
    10,844
Based on your test, would you recommend waterless saving wash solutions such as ONR over the classical shampoo or plain-water methods for PPS coated vehicles?
「さぁ、今、手を伸ばして 」
#18
Posted 02 October 2016 - 01:51 PM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
I would recommend onr for pps coated. Occasionally shampoo to remove oil film from surface.. i do mix both together at time..
Edited by Maddriver, 02 October 2016 - 01:54 PM.
#19
Posted 02 October 2016 - 02:07 PM
flashbang
  • Premium member
    flashbang
    NOS-ed
    Author Image
    11,092
The iron X removal looks good, but how to tell if it removes the coating? By the time you realise, it's too late...
#20
Posted 02 October 2016 - 06:48 PM
Maddriver
  • THREAD STARTER
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,403
Flashbang, i am not sure if ferrex will remove other coatings but it should not be. It does remove waxes tho.. haha.. u can use it to test your coating..
Checkout the optimum forum http://optimumforums...ic=51483&page=1 . They mentioned will not remove optigloss coat..
I experienced loss of water beading after parking under a tree and was raining heavily..is confirm that surface was covered with extreme dirt n shampoo cant recover it until i used iron x.
Back to Detailing  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: paint coating, pps, shampoo and 4 more...
