Mnns 4th Gear October 28, 2016 Share October 28, 2016 (edited) yup! So anyone here using? any user reviews?i did google hor hahahaha..am seeking feedback How about just going for Hue / Lightify? Change bulb only provided your hall area lights accepts e27 bulbs. I'm using those for my dining and balcony. Edited October 28, 2016 by Mnns ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Count-Bracula Twincharged October 28, 2016 Share October 28, 2016 Learn from Skywalker and no need for all these gadgets 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic October 28, 2016 Share October 28, 2016 If you want just auto light switch, without fancy wifi or whatever, you can do this: 1. Install a cheap PIR switch like this one. https://www.aliexpress.com/item/New-240V-Outdoor-180-Degree-50Hz-Security-PIR-Motion-Movement-Sensor-Detector-Switch-PIR-Infrared-Motion/32696299412.html?ws_ab_test=searchweb0_0,searchweb201602_2,searchweb201603_3&btsid=23f9253c-1a68-488d-ab35-54ba01c71e9a You can adjust lighting and timing. 2. Connect to the lights you want to switch on. You need to do wiring. I use cheap Ikea wall lamp with LED bulbs. 2 Link to post Share on other sites More sharing options...
Ender Hypersonic October 29, 2016 Share October 29, 2016 Anyone see this? Saw in qoo, not that expensive http://www.domotics.sg/review-broadlink-rm2-infrared-blaster/ Link to post Share on other sites More sharing options...
Ysc3 Twincharged October 29, 2016 Share October 29, 2016 (edited) i have wanted to fix these wifi switches before i went overseas previously ... but after reading sme unfavourable comments, i decided not to. one main problem is the connectivity ... unless you using VPN, else its 50/50 you can get a WAN connection. At home with wifi is still ok but when you go outdoors, then see how liow. I don't really know how it works but that's the feedback i read. however, if you have $23 to spare, then get a Orbivo to try out and see if it works for you. Edited October 29, 2016 by Ysc3 Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 29, 2016 Share October 29, 2016 Ah this is what the HDB used in corridors or some staircases. If you want just auto light switch, without fancy wifi or whatever, you can do this: 1. Install a cheap PIR switch like this one. https://www.aliexpress.com/item/New-240V-Outdoor-180-Degree-50Hz-Security-PIR-Motion-Movement-Sensor-Detector-Switch-PIR-Infrared-Motion/32696299412.html?ws_ab_test=searchweb0_0,searchweb201602_2,searchweb201603_3&btsid=23f9253c-1a68-488d-ab35-54ba01c71e9a You can adjust lighting and timing. 2. Connect to the lights you want to switch on. You need to do wiring. Link to post Share on other sites More sharing options...
Kb27 Supersonic October 29, 2016 Share October 29, 2016 (edited) Ah this is what the HDB used in corridors or some staircases. The PIR switch works very well. I have 2 of them. Installed in the living room: 1. Anyone who opens the door will trigger the light. Since it's LED bulb, you can turn on as long as you want without consuming much power. Also acts as a security. A thief who tries to come in will be surprised by the light going on and may just leave if he's not sure what other traps lay before him. 2. On the stairwell: Lights up for safety in the darkness. 3. You can also install in the bathroom, if you just want to pee in the middle of the night for 1-2 mins, without fumbling for a light switch. And they are cheap. But need a bit of work to run the wires or you can pay an electrician to install them. Edited October 29, 2016 by Kb27 Link to post Share on other sites More sharing options...
Blueray Hypersonic October 30, 2016 Share October 30, 2016 can you all dun be so lazy? and stand up and go on/off the light lah maybe TS is a busy person, cannot afford time on mundane tasks like pressing light switches ... ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Car Remote Control Key - Any lobang
Airalo
Airalo
Wifi IP CCTV
Wifi IP CCTV
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
