  • 1
  • Search this thread
  • This topic is locked This topic is locked
No replies to this topic | 0 praises
Posted 16 November 2016 - 11:50 AM
  • LifePro_Tips
More power – more fun to drive! The CITYBUG2S has been designed for people with an athletic bent who like to flit about without hassle. With his new powerful 48 V/350 W rear-wheel hub motor the electric scooter will lead you also on hilly roads. Different from Citybug2 the S-version accelerates easily after the kick-start with a thumb throttle used by your right hand. To slow down just
release the throttle and apply the supplementary E.A.B. (Electric Assist brake System) on the front wheel of the scooter. To stop the scooter completely, just press the fender brake. The CITYBUG2S can also be folded very small whenever you want to carry it or stow it away somewhere – pure, uncompromising compactness with an outstanding design!
Press the Start button and off you go. Then just kick-start the Citybug2S with one Foot so the motor will turn over. To speed up, use the thumb throttle with your right hand and rely on your intuition to experience a carefree, enjoyable ride on your new CITYBUG2S. Having reached the desired speed, you can slow down by releasing the throttle and apply the supplementary E.A.B.
For us, safety always comes first. All our CITYBUG2S models are therefore equipped with two braking systems that work independently of each other. Both can be operated intuitively.
With the new supplementary “Electric Assist brake System” called E.A.B. you can decelerate your Citybug2S gradually. So you always have full control about the speed. This special brake is located on the front wheel of the scooter and slows down the support of the electric motor.
The second method of braking your scooter is the fender brake – a robust rear-wheel brake that you can operate with your foot to immediately bring your CITYBUG2S to a full halt.
No emissions – good for your environment! The CITYBUG2S produces no CO2 pollution whatsoever. Combined with green energy from your power supply company, the sophisticated battery technology, which ensures maximum intervals between charging, means that your actual carbon footprint becomes smaller every day.
No noise pollution – The CITYBUG2S is a lightweight electric vehicle that moves through the city without generating any noise. Enjoy the feeling of discovering your city on the quiet.
Press the Start button and jump on
Accelerate up to 5 km/h by kicking off with your foot until the electric drive starts up
Speed up until 22km/h by using the thumb throttle with your right hand
Once you have reached your desired tempo just enjoy your ride
To reduce your speed, release the throttle and apply the supplementary E.A.B. to slow down the motor
To stop immediately, step on the rear-wheel brake/on the mudguard
Press the Start button and jump on and kick-start your Citybug2S. To accelerate use the smooth and easy going throttle with your right thumb until you reached your wished speed. You then travel at constant speed. To slow down release the throttle and use the supplementary E.A.B. System. Rely on your intuition to experience a carefree, enjoyable ride.
Arrived at your destination? The CITYBUG2S can be carried effortlessly or parked in a small space practically anywhere:
1. Pull the lever on the bottom side of the handlebar
2. Fold your CITYBUG2S until you hear a slight click
3. Now, you can take it wherever you want to go
4. Reverse the process and drive somewhere else
Once folded, the CITYBUG2S is smaller than a folding bicycle. It is light enough to carry up several flights of stairs and small enough to take with you on public transportation or even stow under a shopping cart.
It is a well-known fact that it is often the little things that make all the difference. You can park your CITYBUG2S anywhere you want, without having to look for a wall or fence to lean it against. All you have to do is release the fold lever and pull on the handlebar until the underside of the footboard comes into contact with the ground. Elegantly parked, your CITYBUG2S then sits there, waiting for your next ride.
Product dimension - 986 x 335 x 1081 mm (Unfolded)
Weight - 13.5 kg
Driving distance - Approx. 18 km (80kg rider)
Max speed - 22 km/h (limited)
Motor - 350 w
Torque - 17 NM
Battery - Li-Ion 48 V 4.4 AH
Charging - 2A charger, charging time 2.2hrs
Riding Control - Thumb Throttle
Rear Brake - Fender + Electric Assist Brake
Wheel - Front: 8" Air Tire, Rear Wheel: 7.2" Hollow Rubber
Front Light - Integrated LED + Reflector
Rear Light - Integrated LED + Brake LED
Trimen Ventures Pte Ltd
31 Bukit Batok Cresent #01-13 The Splendour Singapore, Singapore 658070
Phone: 67343111
Website: www.facebook.com/TrimenVentures/timeline
  • 1
Back to Lite & EZ  ·  Non-Car Related Top
Tags: scooter, electric, lta approved and 1 more...
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
