  • Search this thread
  • Reply to this topic
35 replies to this topic | 45 praises
#1
Posted 02 December 2016 - 01:19 PM
Hummer
  • THREAD STARTER
  • Premium member
    Hummer
    3rd Gear
    Author Image
    355
So I had a wheel alignment issue where the car was drifting to the left. Decided to send it in for wheel alignment and all was well after that.
But noticed a new issue where I was travelling at speeds of about 95 to 100kmh where the steering wheel was vibrating rather strongly. It starts to vibrate at speeds from about 80 onwards. Vibration is most strongly felt at about 100kmh where I can see my watch vibrating.
Proceeded to do high speed wheel balancing where all 4 wheels/tires were done but seems like no difference.
Any idea what else is wrong?
Didn't get any vibration before wheel alignment.
#2
Posted 02 December 2016 - 01:49 PM
ahcang
  • ahcang
    Clutched
    Author Image
    29
Check your tires? I used to have similar issue but the moment I change to a set of new tyres all is well.
#3
Posted 02 December 2016 - 02:18 PM
Ct3833
  • Ct3833
    6th Gear
    Author Image
    4,405
you can swap the two rear wheels(with rims) to the front , if the problem goes away, it is likely one of the front tyres that you have moved to the back.
#4
Posted 02 December 2016 - 02:40 PM
Ahgong
  • Premium member
    Ahgong
    Author Image
    8,123
vibration is usually a tire problem. try Ct3833 method.
if swapping the tires doesn't help, it could be a bearing problem.
that one is major repair if it is. hope it is not.
do update if you manage to find the cause of the vibration. good opportunity to learn for everyone.
#5
Posted 02 December 2016 - 03:11 PM
Hummer
  • THREAD STARTER
  • Premium member
    Hummer
    3rd Gear
    Author Image
    355
I just wanted to add during the wheel alignment process, the mech swapped my front wheels L-R and R-L as there was uneven wear/tear due to alignment issues. This was when the vibration started. My front tires are new, having run for about 7,000km only.
Rear tires are old, probably left 40% thread and also uneven wear tear.
Thinking if I move the back to front and front to back will resolve the issue.
Replacing rear tire is an option but I am not sure it will resolve or I want to try that as it is expensive and not due yet.
#6
Posted 02 December 2016 - 03:15 PM
Aaronlkl
  • Premium member
    Aaronlkl
    2Fast2Furious
    Author Image
    53,096
U need to balance ur wheels.
If u are on low profile tires and frequent Bolehland,
Ur wheels may be warped.
Basic wheel balancing usually solves this prob.
Newbie26 praised this
"If in doubt, Flat out!"
#7
Posted 02 December 2016 - 03:28 PM
Hummer
  • THREAD STARTER
  • Premium member
    Hummer
    3rd Gear
    Author Image
    355
Already did high speed wheel balancing.
Like I mentioned, it was OK before I did wheel alignment.
Tires definitely not low profile. 235/55/19
#8
Posted 02 December 2016 - 03:29 PM
Aaronlkl
  • Premium member
    Aaronlkl
    2Fast2Furious
    Author Image
    53,096
Did u rotate tyres?
#9
Posted 02 December 2016 - 03:55 PM
Neutrino
  • Neutrino
    Supercharged
    Author Image
    5,916
For me whenever I've had a wheel alignment (car pulling slightly one way or another ) or a wheel balancing ( vibration felt through steering wheel ) issue I will have the wheels aligned and balanced at the same time.
Alignment and balancing aren't something which requires regular work unless hit kerb or skid.
There is no law without enforcement
#10
Posted 02 December 2016 - 03:58 PM
Luckcent
  • Premium member
    Luckcent
    6th Gear
    Author Image
    4,678
I was told to put new tyres at the back and not in the front, if changing only 2 tyres.
Failure is not defeat unless you stop trying
#11
Posted 02 December 2016 - 04:02 PM
Neutrino
  • Neutrino
    Supercharged
    Author Image
    5,916
Funny.
Wouldn't you want new tyres at the place where they'd have most effect, steering and braking.
#12
Posted 02 December 2016 - 04:23 PM
Jq1988
  • Premium member
    Jq1988
    5th Gear
    Author Image
    1,257
speed balancing is a waste of time and money...(Was experiencing same situation long time ago, only to discover the tyre shop only care for profit...not cheap too. Last resolve, tyre tak bagus, rim was not balanced properly) so please check your tyre and rims...not to forget to check your driving rod and bearing as well.
Edited by Jq1988, 02 December 2016 - 04:26 PM.
Hamburger praised this
Japanese girl is awesome!
#13
Posted 02 December 2016 - 05:12 PM
Jtb
  • Premium member
    Jtb
    6th Gear
    Author Image
    2,985
yes everybody knows how to replace tires and not everybody knows how to align and not everybody know tires need to be aligned after the change!
Tires are the most important part on any vehicle especially rainy days.
Edited by Jtb, 02 December 2016 - 05:17 PM.
#14
Posted 02 December 2016 - 06:35 PM
Nuahster1
  • Nuahster1
    1st Gear
    Author Image
    70
sharing my similar experience, for my case it was a hub centric ring or rim cone, can't exactly remember which as it was long ago, but it fell/came out from one rim when they were taken off for rotation & balancing,
The person/worker handling the wheel didn't notice or probably forgot to put it back when mounting the wheel. the result was heavy vibration felt in steering only at high speed above 90-100km/h.
spend $$ going for high speed balancing and realignment but didn't solve the issue, eventually when take off wheels to  rebalance, realised the missing piece in the wheel, replaced it and problem solved (at least in my case).
Apple-Tree, Blueray and TangoElite praised this
#15
Posted 02 December 2016 - 06:38 PM
Apple-Tree
  • Premium member
    Apple-Tree
    5th Gear
    Author Image
    1,808
Oh .... I know.
You need to do front wheel balancing lor.
Or tyres swollen lor.
Carbon82 praised this
#16
Posted 05 December 2016 - 01:58 AM
Dxyong
  • Premium member
    Dxyong
    3rd Gear
    Author Image
    495
You should go back to the tyre shop and recheck, last time I did wheel balancing, similar thing happen, apparently one of the weight on one of the wheel came off, they put it back and problem solved.
Apple-Tree and Blueray praised this
#17
Posted 05 December 2016 - 08:17 AM
Turboguy
  • Premium member
    Turboguy
    4th Gear
    Author Image
    934
vibration at 90kmh -100kmh, clearly is missing of the hub centric ring
#18
Posted 05 December 2016 - 08:24 AM
Yeshe
  • Premium member
    Yeshe
    NOS-ed
    Author Image
    19,874
Funny.
New tires at the back to prevent fish tail Or skid which often result in loss of control
#19
Posted 05 December 2016 - 11:54 PM
Hummer
  • THREAD STARTER
  • Premium member
    Hummer
    3rd Gear
    Author Image
    355
Are you using after market rims? Is the centre bore size the same
#20
Posted 06 December 2016 - 08:46 AM
Spinelli_ck
  • Premium member
    Spinelli_ck
    6th Gear
    Author Image
    3,272
usually due to unbalanced wheels or missing hub centric ring. when i changed to aftermarket rims, the tyre shop provided a set of customised hub centric rings.
Dynamics Mechanic Pte Ltd
Top93 Sports Rim
Top93 Sports Rim  |  Rating   Submit Review
Reviewed by Nivlek96  |  Clutched
Professional, accommodating and patient with customers. Experienced and knowledgeable. Ah Hua and Ah Yang ensures that you are well taken off and that your needs are satisfied.
Chip Soon Auto Pte Ltd
Chip Soon Auto Pte Ltd  |  Rating   Submit Review
Reviewed by Mcscot  |  5th Gear
Brought my W204 to Chip Soon to replace my brake pads and brake disc - checked several places for prices and found Chip Soon to be most reasonable.
Jason (technical in charge) was on hand to explain why the disc needed replacement and could not be skimmed.
I will be bringing my W204 to them for servicing in future! » Read More
Related Motor Directory search on sgCarMart.com : Tyres & Rims
Quick Reply
Tags: audi, audisteering wheel, vibrate and 6 more...
