  • 1
  • Search this thread
  • Reply to this topic
10 replies to this topic | 25 praises
#1
Posted 12 December 2016 - 08:48 PM
dreamyxq
  • THREAD STARTER
  • dreamyxq
    Author Image
    22
How sensitive should the brakes be? I feel like my new mazda 3's brake is not very sensitive compared to my friend's car. Not sure if it's a defect or normal.
I have to depress the brakes for at least 5-7cm before the braking power kicks in. The starting few cm does nothing at all to stop the car.
Edited by Lightsabre, 19 December 2016 - 09:15 AM.
#2
Posted 12 December 2016 - 09:46 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    46,562
Not sure dan if I tell you will you understand what I'm saying? You got to at least know where to look otherwise go straight to a mechanic.
First to check.
1) Brake fluid level. Is it within the min-max level? If you don't see any brake fluid most likely a lot of air is in the system giving you the lousy brake feel.
2) What colour is the brake fluid?
- Black (replace it)
- clear (good)
3) Visually inspect the brake pads.
Use a torchlight to peer at the side of the brake caliper assembly. Compare the thickness with your friend's. Are the brake pads wearing thin?
lausai88 and Emils praised this
#3
Posted 13 December 2016 - 12:01 AM
Phang
  • Premium member
    Phang
    5th Gear
    Author Image
    2,227
new car?
try bleeding the brakes and bedding in the pads
#4
Posted 13 December 2016 - 09:09 AM
UncleAtas
  • Premium member
    UncleAtas
    6th Gear
    Author Image
    3,168
I think your leg not long enough. try doing jumping jacks more often.
Wyfitms praised this
Refer to signature guidelines
#5
Posted 13 December 2016 - 09:22 AM
Samwng
  • Premium member
    Samwng
    3rd Gear
    Author Image
    340
It's normal, brake pad & rotor both are brand new.
Need to run in, drive slow. It should get better over the first 1-1.5k mileage clock in.
I don't think you need to worry about it for now. [;)]  Enjoy your new ride. [rolleyes]
#6
Posted 13 December 2016 - 01:02 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    30,769
Get your brake system bleed first.
Muser praised this
#7
Posted 13 December 2016 - 03:18 PM
dreamyxq
  • THREAD STARTER
  • dreamyxq
    Author Image
    22
First to check.
- clear (good)
Checked all. Shldn't be a problem, it's a new car.
Currently on 1.2k, still feels the same. I'll wait at see.
I'm having my 1k servicing tmr, should I point this out to the dealer workshop?
#8
Posted 13 December 2016 - 04:04 PM
Ichibawa
  • Premium member
    Ichibawa
    5th Gear
    Author Image
    2,302
You should point out all your findings to the workshop. You paid so much for that car, better make sure its worthwhile to part with the amount.
Daniu82 praised this
#9
Posted 13 December 2016 - 06:09 PM
Muser
  • Premium member
    Muser
    4th Gear
    Author Image
    544
Is your friend also driving a Mazda 3 of the same generation?
How would you compare your current brakes to other cars you've driven?
The reason I'm asking is that everyone has different standards for what constitutes normal braking. For example, if you're used to BMW and Honda stock brakes, you may very well find that other brands can't make it. For example, I find that the first few cms of brake pedal on stock Subaru brakes don't do much to stop my Legacy too. Then again, I'm quite demanding when it comes to brakes, and my benchmark is BMW and Honda, which is arguably unreasonable since BMW stock brakes are some of the best.
One thing that doesn't do any harm is a brake system bleed/flush, regardless of how new your car is. If I were you, I'd insist on a brake system flush, FOC. Because it can't hurt, you may find it solves your problems, and at the very least you will have eliminated one potential cause of your complaints. Always eliminate the easiest potential causes first, and ruling out your brake fluid should be top of the list cuz it's easy.
#10
Posted 13 December 2016 - 08:29 PM
dreamyxq
  • THREAD STARTER
  • dreamyxq
    Author Image
    22
Ya my friend's a Honda. Sure, I understand that logic. Which is why I'm here, asking if it's normal or something is very wrong. Brakes are very important to me, my life literally depends on it.
I'll point it out on my 1k servicing, just afraid that they'll write it off as normal for Mazdas or because its a new car thus havent break it.
If I ask them to bleed for me or full flush, will I be charged? I have 3 year or 60k free servicing.
#11
Posted 13 December 2016 - 10:03 PM
Muser
  • Premium member
    Muser
    4th Gear
    Author Image
    544
Based on what you've shared so far, there's still no red flag that indicates for certain that something's wrong. So best to start eliminating possibilities. Try bedding in your brakes. Bleed or, better yet, flush your brake system. Get your system checked for leaks. And if after all that you still can't find a problem and your braking stays the same (doesn't fluctuate or, worse still, deteriorate), then perhaps you expect more from your brake system than it can provide, like me. In which case your only options will be to change car or upgrade your brakes. But we're not there yet, so one step at a time.
There's actually a good chance your pads still aren't bedded properly because your car is so new.
You should definitely flag it at your 1k servicing tomorrow to ensure it's on record. Whether or not it's written off by your dealer as a no-issue usually depends on how much of a fuss you politely make. When it matters, I make one hell of a fuss until it's more worthwhile to give me what I want than to refuse me.
As for whether or not you'll be charged, it depends on your dealer and you. I would refuse to pay. If I felt my brand new car brakes can't make it, I'd demand a full flush for free and would bang table until I got it. Cuz it my life and my family's. But it's your call.
  • 1
Dynamics Mechanic Pte Ltd
3 Motorwerkz
3 Motorwerkz  |  Rating   Submit Review
Reviewed by Andyl28  |  Neutral Newbie
My car couldn't start last night so I contacted Joe. He responded quickly despite it is already late at night. My problem solved within an hour, it is my battery has up the lorry.
Good Service !!!
Will be sending my car to you soon for next servicing. » Read More
Han Revolution
Han Revolution  |  Rating   Submit Review
Reviewed by choroniclesmu  |  Neutral Newbie
Have my vehicle towed to the shop itself. The engineers straight away start with diagnose on the car problem itself. The person recommend me to change the battery as it is not good. Going on with the checking and found out that the one of the spark plug has spoilt and recommend me to change all 4 of it. Decide to go on with it. The quote for it is okay being 150/piece b... » Read More
Related Motor Directory search on sgCarMart.com : Handling & Safety
Quick Reply
Tags: brake, sensitivity, mazda and 1 more...
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
