Extremme 4th Gear December 25, 2016 Share December 25, 2016 Guys my string attached to the roller blinds came off. How do I fix it. There is no space on either side to remove the blinds. ↡ Advertisement Link to post Share on other sites More sharing options...
Leinad8919 Turbocharged December 25, 2016 Share December 25, 2016 There you go. 1 Link to post Share on other sites More sharing options...
mersaylee Supersonic December 25, 2016 Share December 25, 2016 One side should be able to lift up vertically. Use a bit of force to yank it up if it hasn't been meddle with for a long while. Best to go for chain-less type - need not worry about rust or dirt... Link to post Share on other sites More sharing options...
Extremme 4th Gear December 26, 2016 Author Share December 26, 2016 One side should be able to lift up vertically. Use a bit of force to yank it up if it hasn't been meddle with for a long while. Best to go for chain-less type - need not worry about rust or dirt... There is no catch or whatsoever I could see though for me to yank up. Chainless? Link to post Share on other sites More sharing options...
mersaylee Supersonic December 26, 2016 Share December 26, 2016 There is no catch or whatsoever I could see though for me to yank up. Chainless? Refer to the video posted above...The catch is on the other end from the winder side. Given the space constraint in your photo, most likely you'll need to yank it towards you as per the video - the installer might have mounted it that same way. Chain-less type works like the good old slide projector screen - pull down to deploy, pull down again to retract. Chain tends to rust even paint coated type. 1 Link to post Share on other sites More sharing options...
Inlinefour Twincharged December 27, 2016 Share December 27, 2016 Install Lutron Blinds...battery operated Can use iphone to open close ↡ Advertisement Link to post Share on other sites More sharing options...
Heavy and rain proof curtains/blinder recommendations?
Window grill lock
Window grill lock
Anyone did Zip/ZipTrack blinds?
Home window - Sliding or casement?
STEK NEX Series Carbon Ceramic with Graphene Window Tint
Invisible Window Grilles
Curtain and blinds
Curtain and blinds
