Tianmo Hypersonic February 12, 2017 Share February 12, 2017 Stock is best, best is stock. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Watwheels Supersonic February 13, 2017 Share February 13, 2017 Just don't over do things like upgrading to bigger and bigger rims. You get bigger rims means in turn you have to get lower profile tires. Regardless the rims are expensive or cheap going thru a pothole surely they will dent/fracture or break. Big rims only look good in the show room. Practical usage wise you know it cannot withstand poor road conditions. What you need are small rims and high profile tires like those found on SUVs and off-road vehicles. Then going thru a pothole will be no worries. 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic February 13, 2017 Share February 13, 2017 practically no advantage under real world driving conditions definitely burn a big hole in the wallet 2 Link to post Share on other sites More sharing options...
Roberttan 5th Gear February 13, 2017 Share February 13, 2017 SSW, inforged, advanti... and other alike, 17". haven't checked the SG pricing yet, only checked out internet each around USD150-180, so I guess in SG should expect around $250 each? Brands at this price point is it reasonable to expect a good enough peroduct for my use? Not for flashiness, just hope to get some improved comfort and better fc if possible. Another noob question, I see all almost the same, besides price and specs to fit, design is just sui bo sui right? Dunno then scare. That's why I started this thread. If most advice here is better not, then of course won't change. Can give some brands considered as Al cheapo aftermarket to avoid? between the 3 , SSW and Advanti is more reliable to me ( I am talking about Real SSW and Advanti , not just the sticker on the cap) sorry for not knowing inforged brand well ,cos have seen the wheels finishing is not to my high expectation or cat type. getting a well know brand wheels usually cost some money , is the reliable and quality assurance. well known brand the Quality can be higher or at least equal = Original equipment rim some new wheels fitted on your car may not the Original Factory supplier just for your information. Steel wheels is not better than Alloy wheels , is just because almost all steels wheels are Original factory fitted. One more thing is also very important is the tires, please don't invest on wheels and Save money on your tires, between the 2 , tires is more important just MHO Link to post Share on other sites More sharing options...
Beregond Supersonic February 13, 2017 Share February 13, 2017 yep there is alot of brand out there, its not say must be BBS advan racing. 1 rim cost 1k , then its consider real / orginal rims. brand like kyowa, RM SSW, rota etc etc, these are orginal rims also. as long as they pass all the safety check, have all the necessary marking, its consider safe to use, regradless make in pinoy, my, china ,tawian. its like car, only cars make in japan and europe then consider orginal meh?? but normally ppl change rims to look nice. if u dun care about nice or not. just refer to F1 does F1 cars use big and lower pofile rims/tyres?? 'BTW having good tyres itself, its many many time more important then having better rims. ' Link to post Share on other sites More sharing options...
Kangadrool Supersonic February 13, 2017 Share February 13, 2017 (edited) I actually find some steel rims design quite nice compared to alloy rims. http://retrorides.proboards.com/thread/63253 http://www.californiaclassix.com/archive/71_280SE_3-5_p13.html http://www.vwt4forum.co.uk/showthread.php?t=158221&page=146 not too bad what... Edited February 13, 2017 by Kangadrool Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 13, 2017 Share February 13, 2017 Not a good idea cos this happens in MY. 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic February 13, 2017 Share February 13, 2017 (edited) Cheap alloy wheel is fine, unless you hit a pothole or blew up the tyre, like me. Then it may crack and need to be replaced.. I got a Enkei that crack after the tyre exploded. Then I replaced with 4 cheapo Taiwanese rims that worked fine. Edited February 13, 2017 by Kb27 Link to post Share on other sites More sharing options...
inlinesix Supersonic February 13, 2017 Share February 13, 2017 yep there is alot of brand out there, its not say must be BBS advan racing. 1 rim cost 1k , then its consider real / orginal rims. brand like kyowa, RM SSW, rota etc etc, these are orginal rims also. as long as they pass all the safety check, have all the necessary marking, its consider safe to use, regradless make in pinoy, my, china ,tawian. its like car, only cars make in japan and europe then consider orginal meh?? but normally ppl change rims to look nice. if u dun care about nice or not. just refer to F1 does F1 cars use big and lower pofile rims/tyres?? 'BTW having good tyres itself, its many many time more important then having better rims. ' Forged wheel vs casted wheel Purity of alloy Alloy used The above will determine the strength and weight of aftermarket wheel. It is nvr about the brand or origin. F1 tyre size has no relevant to production car. It has very wide tyre (front: 245; rear: 325) due to its massive power. On the other hand, the car is very short in height (about 3ft). No need very tall rim le. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged February 13, 2017 Share February 13, 2017 Thanks for adding in. Yes, this is one of the main concern. Worse still if hairline crack after pothole unnoticed then continue up high speed. Possible to happen to 'normal standard' rim? And appreciate all input and replies here. May I ask much price range is considered acceptable? Is SSW, or MITaiwan brand ok? I am not looking into really cheapo counterfeit, but if really need those high end rims to do the job, I would just stay put with the stock steel wheel. Will be parked at public car park around , don't want high end brand to attract unnecessary attention. Yup. Exactly. should have said HW plus rough roads plus HW plus highland plus.... Thanks If I'm not wrong, steel rims will also warp.. sTeel rims technically should be more resilient to warping based on more material mass, but doesn't mean alloy no good.. can also go for a almost similar weight or slightly lighter aluminium alloy rims from reputable wheel manufacturers which should be even stronger than the steel rims. There is benefits of doing wheel balancing every 7k-10k mileage when doing rotation.. which is to detect rim warping or cracking. So do that if you awant peace of mind Link to post Share on other sites More sharing options...
ClesterClarence 2nd Gear March 14, 2017 Share March 14, 2017 Stock Rims are best, 16 " will help to reduce fuel consumption too, then use thicker tyres to increase comfort Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 15, 2017 Share March 15, 2017 is correct to stay with stock because you are in doubt. But how you know your stock wheels is Original ? No all wheels fitted on your New cars are Original nowadays Stock wheels are no always Lighter / stronger / look nicer / cheaper They Original wheels are tested Strong for that particular car by the Car manufacturer. Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 15, 2017 Share March 15, 2017 yep there is alot of brand out there, its not say must be BBS advan racing. 1 rim cost 1k , then its consider real / orginal rims. brand like kyowa, RM SSW, rota etc etc, these are orginal rims also. as long as they pass all the safety check, have all the necessary marking, its consider safe to use, regradless make in pinoy, my, china ,tawian. its like car, only cars make in japan and europe then consider orginal meh?? but normally ppl change rims to look nice. if u dun care about nice or not. just refer to F1 does F1 cars use big and lower pofile rims/tyres?? 'BTW having good tyres itself, its many many time more important then having better rims. ' just to share my views Kyowa and SSW has its own Plant making the wheels RM is just a Private label wheels that source from any wheels maker. As for Passed all the Safety test or check ? sometime I was wondering is the Test a real test? is the Certificate Genuine? Even Singapore Authority got cheated by Some Foreign talent providing Fake Certificate. So how we as consumer know are they Genuine ? just MHO ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel Hubs
Wheel Hubs
Accident on NSHW with a malaysia car
Recommended Season Parking for Mapletree Business City
Any recommended workshop with reasonable labour charges?
Any recommended tyre shop
Shipping USA Rims
Shipping USA Rims
Singapore Brand Rims VS China Brand Rims
