Puteh83 1st Gear February 14, 2017 Share February 14, 2017 Hi all. The aircon on the driver side of my near COE expiry car suddenly not blowing cold air. I have tried playing around with different settings and variations as advised by my mechanic but still the same. Any idea why is that so? TIA ↡ Advertisement Link to post Share on other sites More sharing options...
Still2016 Twincharged February 14, 2017 Share February 14, 2017 Hi all. The aircon on the driver side of my near COE expiry car suddenly not blowing cold air. I have tried playing around with different settings and variations as advised by my mechanic but still the same. Any idea why is that so? TIA Are you trying to show off that on Valentine's Day, you are really hot stuff that air-conditioning cannot keep you cool? But on a serious note: if your car has multi region cooling (individual zone control) then, likely your driver side sensor not working. if your car does not have multi region cooling (individual zone control) then all air-conditioning outlet should not be cold either. if your car front air-conditioning outlets have individual control that allows you to control individual outlet how much outside air to let it, the control may be jammed or not functioning properly. 3 Link to post Share on other sites More sharing options...
Puteh83 1st Gear February 14, 2017 Author Share February 14, 2017 Are you trying to show off that on Valentine's Day, you are really hot stuff that air-conditioning cannot keep you cool? But on a serious note: if your car has multi region cooling (individual zone control) then, likely your driver side sensor not working. if your car does not have multi region cooling (individual zone control) then all air-conditioning outlet should not be cold either. if your car front air-conditioning outlets have individual control that allows you to control individual outlet how much outside air to let it, the control may be jammed or not functioning properly. No multi region cooling or individual control whatsoever. There's a total of 4 vents infront. The 2 at passanger side is blowing cool air. The other 2 just normal wind. ICar make is Honda Jazz GD Link to post Share on other sites More sharing options...
Evillusion Supersonic February 14, 2017 Share February 14, 2017 No multi region cooling or individual control whatsoever. There's a total of 4 vents infront. The 2 at passanger side is blowing cool air. The other 2 just normal wind. ICar make is Honda Jazz GD i kana once....my radiator water not enough. Had to top up nearly 1 bottle of water. Dont ask me how....i also not sure! But i driving a proton......dont know honda same anot! Link to post Share on other sites More sharing options...
Puteh83 1st Gear February 14, 2017 Author Share February 14, 2017 (edited) i kana once....my radiator water not enough. Had to top up nearly 1 bottle of water. Dont ask me how....i also not sure! But i driving a proton......dont know honda same anot! erm...that's weird.. How did you find out? Jin headache. COE expiring this may. Not here not there. Edited February 14, 2017 by Puteh83 Link to post Share on other sites More sharing options...
Evillusion Supersonic February 14, 2017 Share February 14, 2017 erm...that's weird.. How did you find out? Jin headache. COE expiring this may. Not here not there. kana 1st time at jb custom during traffic jam.....hot air blew out from my aircon! Saw the engine water temperature nearly boiling point....so i off engine! After clearing customs and driving on the edl the temperature went down. When i reached destination i went do my personal stuff 1st and after an hour opened up the radiator cap. Not enough water! I think its some kinda safety mechanism to reduce the heat stress on the engine when the water temperature rises! Samething happened when my fuse for the radiator got burnt. Radiator fan couldnt start so the temperature went up and again the aircon blew hot air! 1 Link to post Share on other sites More sharing options...
Puteh83 1st Gear February 14, 2017 Author Share February 14, 2017 kana 1st time at jb custom during traffic jam.....hot air blew out from my aircon! Saw the engine water temperature nearly boiling point....so i off engine! After clearing customs and driving on the edl the temperature went down. When i reached destination i went do my personal stuff 1st and after an hour opened up the radiator cap. Not enough water! I think its some kinda safety mechanism to reduce the heat stress on the engine when the water temperature rises! Samething happened when my fuse for the radiator got burnt. Radiator fan couldnt start so the temperature went up and again the aircon blew hot air! interesting. i will check later. Link to post Share on other sites More sharing options...
OngBrother Neutral Newbie February 14, 2017 Share February 14, 2017 Have u go down to ur workshop and check for the air con gas level coz sometime gas leakage may make this thing happen and if is gas leakage u can just top up gas since ur coe expiry is near Link to post Share on other sites More sharing options...
Puteh83 1st Gear February 14, 2017 Author Share February 14, 2017 Have u go down to ur workshop and check for the air con gas level coz sometime gas leakage may make this thing happen and if is gas leakage u can just top up gas since ur coe expiry is near Not yet. work timing quite off these 2 weeks. will do it this wkend. Link to post Share on other sites More sharing options...
Fainsyah Clutched February 15, 2017 Share February 15, 2017 From my previous experience... my air con compressor not functioning and there was a leak of my air con gas. Change compressor and topped up gas... it is fixed. Link to post Share on other sites More sharing options...
Puteh83 1st Gear February 15, 2017 Author Share February 15, 2017 From my previous experience... my air con compressor not functioning and there was a leak of my air con gas. Change compressor and topped up gas... it is fixed. Costly? Link to post Share on other sites More sharing options...
george78 1st Gear February 15, 2017 Share February 15, 2017 Left 3 months of driving try to tahan. My car also hot air blowing and I tahan 4 months till my new car came. Wind down window when driving, but inhale smoke when jam in traffic. Don't follow big lorry behind. Link to post Share on other sites More sharing options...
OngBrother Neutral Newbie February 15, 2017 Share February 15, 2017 Not yet. work timing quite off these 2 weeks. will do it this wkend. Did ur working place near kaki Bukit auto Bay coz if near there maybe u can come to my Father workshop and then have a look on it see whether it is worthy to repair or just top up gas til new car Link to post Share on other sites More sharing options...
Cypher 4th Gear February 15, 2017 Share February 15, 2017 Hi all. The aircon on the driver side of my near COE expiry car suddenly not blowing cold air. I have tried playing around with different settings and variations as advised by my mechanic but still the same. Any idea why is that so? TIA If pax side is cold and the driver side is hot, my wild guess is the evaporator is clogged. Link to post Share on other sites More sharing options...
Puteh83 1st Gear February 15, 2017 Author Share February 15, 2017 Left 3 months of driving try to tahan. My car also hot air blowing and I tahan 4 months till my new car came. Wind down window when driving, but inhale smoke when jam in traffic. Don't follow big lorry behind. thinking of renewing actually. car is actually in great condition except aircon. :P Link to post Share on other sites More sharing options...
Ghostami 2nd Gear February 15, 2017 Share February 15, 2017 My experience previously was the cooling coil died somehow, only 2 vents has cool air while the others are normal air. Link to post Share on other sites More sharing options...
Cypher 4th Gear February 15, 2017 Share February 15, 2017 May I suggest TS to go for the cheapest option first. Try to clean the evaporator first, DIY using those aircon cleaner if possible. Else just leave it to the experts. Link to post Share on other sites More sharing options...
Fainsyah Clutched February 19, 2017 Share February 19, 2017 Costly?Can't remember. Cos I changed my compressor together with radiator as it leaked as well. ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
COE Bidding - March 2024
Home Aircon
Home Aircon
2025 Mitsuoka M55
2025 Mitsuoka M55
