Puteh83 1st Gear February 20, 2017 Author Share February 20, 2017 If say im want to visit markcool. Must call them 1st or just drive in? ↡ Advertisement Link to post Share on other sites More sharing options...
Colin03 4th Gear February 20, 2017 Share February 20, 2017 If say im want to visit markcool. Must call them 1st or just drive in? My advise is to give markcool a call before you proceed else might need to wait. Link to post Share on other sites More sharing options...
Puteh83 1st Gear February 20, 2017 Author Share February 20, 2017 My advise is to give markcool a call before you proceed else might need to wait. okok.. Cos seemed like the obvious guy to go is ah huat... Link to post Share on other sites More sharing options...
Toyotaftw Clutched February 21, 2017 Share February 21, 2017 okok.. Cos seemed like the obvious guy to go is ah huat...Has your problem resolved? I'm also facing the same problem, weak aircon air on left passenger seat. Link to post Share on other sites More sharing options...
Cypher 4th Gear February 21, 2017 Share February 21, 2017 okok.. Cos seemed like the obvious guy to go is ah huat...Read through this thread before you make your decision. http://www.mycarforum.com/topic/2649922-tomika-auto-air-con/ Link to post Share on other sites More sharing options...
OngBrother Neutral Newbie February 21, 2017 Share February 21, 2017 (edited) Has your problem resolved? I'm also facing the same problem, weak aircon air on left passenger seat.Have u try top up gas for ur car? Coz it seems like shortage of air con gas.The middle site is blowing cooler air than the left right side right? U can come down to my Father workshop and take a look if u want.address no 1 kaki bukit avenue 6 #01-71 Edited February 21, 2017 by OngBrother Link to post Share on other sites More sharing options...
Puteh83 1st Gear February 24, 2017 Author Share February 24, 2017 Read through this thread before you make your decision. http://www.mycarforum.com/topic/2649922-tomika-auto-air-con/ Went to ah huat in the end. Leakage of gas due to a small hole with the condenser. Was experiencing a foul smell too. All gone. Phew. Link to post Share on other sites More sharing options...
Cypher 4th Gear February 24, 2017 Share February 24, 2017 Went to ah huat in the end. Leakage of gas due to a small hole with the condenser. Was experiencing a foul smell too. All gone. Phew. Thats good news. Glad you solved your problem. Link to post Share on other sites More sharing options...
MTMAutomotive Clutched March 2, 2017 Share March 2, 2017 Hi all. The aircon on the driver side of my near COE expiry car suddenly not blowing cold air. I have tried playing around with different settings and variations as advised by my mechanic but still the same. Any idea why is that so? TIA It's may air cond gas problem, somewhere leaking air cond gas. Link to post Share on other sites More sharing options...
rage06 Neutral Newbie March 6, 2017 Share March 6, 2017 Air Con Compressor Spoil or the Air COn Gas need to be refill Link to post Share on other sites More sharing options...
Johnnylim 5th Gear March 6, 2017 Share March 6, 2017 Went to ah huat in the end. Leakage of gas due to a small hole with the condenser. Was experiencing a foul smell too. All gone. Phew. What's the damage? Link to post Share on other sites More sharing options...
Puteh83 1st Gear March 6, 2017 Author Share March 6, 2017 What's the damage? $420 all in Link to post Share on other sites More sharing options...
Tazdevil Neutral Newbie September 8, 2017 Share September 8, 2017 Did ur working place near kaki Bukit auto Bay coz if near there maybe u can come to my Father workshop and then have a look on it see whether it is worthy to repair or just top up gas til new car HI Bro, I have in a similar situation can do a checkup at your dad's workshop before deciding? Link to post Share on other sites More sharing options...
Kklim Supercharged September 8, 2017 Share September 8, 2017 My G11 Sylphy like less cold, esp in daytime. Checked below car and there's condensate. But none of the aircon pipes in engine bay were wet. What could be wrong? Haven't changed the aircon filter in a while. Link to post Share on other sites More sharing options...
OngBrother Neutral Newbie September 8, 2017 Share September 8, 2017 My G11 Sylphy like less cold, esp in daytime. Checked below car and there's condensate. But none of the aircon pipes in engine bay were wet. What could be wrong? Haven't changed the aircon filter in a while.Could it be the air con gas leakage coz by right the bigger air con pipe should be cold and have water vapours condense around the pipe and while the other pipe should be very hot.Not enough of air con gas will make both pipes warm Link to post Share on other sites More sharing options...
Kklim Supercharged September 9, 2017 Share September 9, 2017 Could it be the air con gas leakage coz by right the bigger air con pipe should be cold and have water vapours condense around the pipe and while the other pipe should be very hot.Not enough of air con gas will make both pipes warm Thanks. Having it checked on Monday. Took out the aircon filter and it didn't look very dirty. Link to post Share on other sites More sharing options...
Alanspeed 1st Gear May 4, 2018 Share May 4, 2018 I got a problem with my Mitsubishi Lancer Ex. The window keep fogging when i drive. I set the temperature around 23 degrees and low speed wind. I have turn on the rear mirror demister but no help at all. Sometimes all the windows n windscreen will be foggy and i can't see anything. Is it due to the setting or my car doesn't have auto climate control? Link to post Share on other sites More sharing options...
Cypher 4th Gear May 4, 2018 Share May 4, 2018 I got a problem with my Mitsubishi Lancer Ex. The window keep fogging when i drive. I set the temperature around 23 degrees and low speed wind. I have turn on the rear mirror demister but no help at all. Sometimes all the windows n windscreen will be foggy and i can't see anything. Is it due to the setting or my car doesn't have auto climate control? Try cleaning the interior windows with shaving cream.. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Cars at Expo - Apr 2024
Crazy weather in Singapore ?
Xiaomi EV is Coming
Xiaomi EV is Coming
