  • 1
  • Search this thread
  • Reply to this topic
4 replies to this topic | 0 praises
#1
Posted 22 February 2017 - 09:44 PM
newagepolish
  • THREAD STARTER
  • Premium member
    newagepolish
    Sponsor
    Author Image
    51
KubeBond Full Range Coating Solutions Products
CHOOSE NanoTech has developed a line of KubeBond coating solutions for the professional auto detailing. The key factor of the KubeBond is the Revolution Bonding Technology, which has excellent bonding strength with the coated surface forming a hard cubic ceramic layer. It protects surfaces from damaging contaminants and harsh chemicals, the hydrophobic effect makes it easy-to-clean. and keep dust and dirt harder adhesion to, without affecting the look or feel of it.
KubeBond can be applied on various surfaces in a car , such as metal, glass, leather, textile, wood, plastic, rubber, which allows our customers to improve the performance of their products drastically.
KubeBond Products:
  • KUBEBOND DIAMOND 9H (PERMANENT BOND)
  • KUBEBOND DIAMOND PLUS (FOR DIAMOND 9H MAINTENANCE)
  • KUBEBOND NANO X (DURABILITY UP TO 12 MONTHS)
  • KUBEBOND GLASSSHIELD (FOR EXTERIOR GLASS PROTECTION)
  • KUBEBOND LEATHERSHIELD (FOR LEATHER PROTECTION)
  • KUBEBOND NU INTERIOR (FOR INTERIOR RUBBER / PLASTIC PROTECTION)
  • KUBEBOND FABRICSHIELD (FOR FABRIC / TEXTILE PROTECTION)
  • KUBEBOND GERMSHIELD (BACTERIA DISINFECTANT)
Hardness scale of 9H & above Revolution Bonding Technology Super-Hydrophobic  Anti-Graffiti  Advanced Chemical Resistance Oxidation & Corrosion Resistant Temperature resistance  UV protection High Glossy Shine; retains colour Self Cleaning Effect
✦Tested & Certified by SGS ✦ISO Certified ✦REACH Compliance ✦Wind Drag Reduction Tested
NEW AGE POLISH PTE LTD AUTHORIZED APPROVED APPLICATOR
Our advantages:
 RBT - Revolution Bonding Technology
There are some solutions providing hydrophobic effect and surface protection, but soon they will be wear off due to lack of bonding strength, once they worn off from the surface, as the result, the substrate lost the protect that it should have, like a tree without tree bark.
Revolution Bonding Technology provides superior coating bonding strength, this bonding strength is not simply physical viscosity, but through chemical bonding between moisture in the air, liquid glass and the material of substrate, forming up cubic matrix structure during the curing process, it will tied up with surface permanently and the bonding strength is so high that even the smooth, glossy glass surface can be banded together.
This bonding strength will not decay and wear off in time, like the Tatoo, with this technology, CHOOSE NanoTech coating solution provide the substrate ultimate protection permanently.
KubeBond Diamond 9H Ceramic glass coating is the revolutionary product that create a superior layer to keep car surfaces strong and shiny, just like a diamond. Also known as " Liquid Diamond", this 9H ceramic coating simply transforms from a transparent liquid to a transparent 9H pencil-hardness glass film when applied on surfaces. All it takes is just one application and proper maintenance. A permanent nano-ceramic coating that gives the best protection and excellent resistance against water, weather & temperature.
KubeBond Diamond 9H is a Permanent nano-ceramic coating, Hard Cubic layer gives the best protection, Excellent resistance against water, weather & temperature, High glossy shine; retains colour , Protect against scratches, damaging substances & harsh chemicals, Hardness scale of 9H and above.
✔ Permanent Protection
✔ Anti-Scratch by 9H Hardness
✔ Enable Easy-to-clean Surface
✔ Super Hydrophobic effect
✔ Anti - Graffiti
✔ Excellent weather Resistance
✔ UV & Thermal Resistance
✔ High Gloss & Color Renew
KubeBond Products has been tested by "SGS" - A world's leading Inspection, Verification, Testing and Certification Company. Recognized as the global benchmark for Quality and Integrity.
ISO 9001 Certified -An International standard that specifies requirements for a quality management System (QMS).
REACH Compliance - European Union address the production and use of chemical substances, and potential impacts on both human health and the environment.
KubeBond NanoXhigh gloss finishing with a strong protection layer that lasts up to 12 months and excellent resistance against water, weather & temperature. Just one application transforms all the paintwork into a shiny surface that is resistance to all weather conditions. This is a result of the ceramic molecular net of the coating that enables a strong protection and creates a surface that stays clean for a longer period.
✔ Strong protection as a result of its ceramic molecular net
✔ Up to 12 months protection
✔ Repels water - hydrophobic effect
✔ Surface become easy to clean
✔ Excellent resistance to weather, UV & Temperature
✔ Giving a High Gloss finishing
KubeBond GlassShield a Strong, transparent finishing that repels water to keep your windows & windshields clear, even in thunderstorms. GlassShield Keeps the glass surfaces sparkling and easy to maintain. With no visible finishing after application, it's like a protective layer. It increase the visibility during raining day as when the rain contacts to the glass surfaces it become beads and roll down off the glasses, hence it increases your visibility when you are driving. Activation of the front wiper will also be reduce.
✔ Strong Protection as a result of its ceramic molecular net
✔ Excellent hydrophobic effect
✔ Surface becomes easy to clean
✔ Excelllent resistance to weather, UV & temperature
✔ Transparent Finishing
KubeBond LeatherShield protects your leather surface for a longer period of time with a strong protective layer that helps keep it soft, repels water and lets you maintain it effortlessly. Having with a clean, soft-touch leather seats.
✔ leather become easy to clean
✔ Repels water - super hydrophobic effect
✔ Contain No Wax
✔ Keeps leather Soft
Edited by newagepolish, 04 March 2017 - 06:05 PM.
New Age Polish Pte Ltd - Quality @ Low Cost
info@newagepolish.sg / +65 81610131
11 Yishun Industrial Street 1 #01-112
North Spring BIZHUB Singapore 768089
F - www.facebook.com/newagepolish
#2
Posted 04 March 2017 - 05:54 PM
newagepolish
  • THREAD STARTER
  • Premium member
    newagepolish
    Sponsor
    Author Image
    51
KubeBond Nu Interior (For Interior / Plastic Protection)
Make your car interiors as beautiful as the exterior.
KubeBond Nu Interior coats the car's interior plastic and rubber surfaces with a strong protective layer, as a result, of its ceramic molecular net. It leaves your interior surfaces looking brand new and shiny, and makes them just as protected as every other surface in your car that uses the KubeBond series. It works magic on the tyres too!
✔ Repel Water
✔ Surface become easy-to-clean
✔ Resistance to weather , UV & Temperature
Diamond Plus For Diamond 9H maintenance
Simple to install and maintain, the KubeBond Diamond Plus is created to prolong the effects of KubeBond Diamond 9H. KubeBond Diamond Plus enhances the life of the cubic ceramic molecular matrix structure within
KubeBond Diamond 9H, enabling you to keep the super hydrophobic effect of the surface and avoid water spots for a longer period.
Below is a simply Test to show how we avoid the annoyed water spots by Diamond Plus.
FabricShield for Fabric/Textile Protection
Based on in-depth research in the high-tech industry of semiconductor assembly for photoelectron, KubeBond FabricShield provides a strong, reliable coating for all absorbent surfaces. The coating dramatically reduces the surface energy of textile or suede, so that when liquids come into contact with it, they form beads and simply roll off.
KubeBond FabricShield keeps surfaces like fabric and suede free of water, dust and other liquids without affecting its look or feel. It completes the whole KubeBond look!
✔ Easy to install
✔ Repels water – hydrophobic effect
✔ Let your fabric breathe
✔ Excellent resistance to cleaning agents
✔ Saves time and money
GermShield photocatalytic coating
KubeBond series don't only protect car surfaces from the elements - KubeBond GermShield extends the protection. It gives around-the-clock protection against bacteria, viruses and mould!
KubeBond GermShield's photocatalytic self-cleaning property means the surfaces are coated with titanium dioxide (TiO2) in pigment form. This means that when exposed to ultraviolet light sources such as the sun, the coating's oxidative property decomposes organic substances such as germs, microbes or bacteria on its surface.
Modified and upgraded by ChooseNANOTECH's advanced technology, KubeBond GermShield works even without exposure to any light source. It can also be used on its own without any other coating products.
Organic Decomposition Feature Prevents Chemical Reactions
✔ Anti-bacterial, Anti-virus and Anti-mould
✔ Excellent durable coating with titanium dioxide (TiO2)
✔ High efficiency
Improved strength
✔ Adapts to outside temperatures
KubeBond Premium Test Kit
Edited by newagepolish, 04 March 2017 - 06:07 PM.
#3
Posted 17 March 2017 - 05:22 PM
newagepolish
  • THREAD STARTER
  • Premium member
    newagepolish
    Sponsor
    Author Image
    51
The combination of KubeBond Diamond 9H and KubeBond Nano X is always recommended.
While the Diamond 9H provide supreme protection to the substrate, the Nano X will boost the water contact angle up to nearly 120 degrees, giving the substrate ultimate hydrophobic effect and make it even shinier.
#4
Posted 13 May 2017 - 10:23 AM
BanCoe
  • BanCoe
    2Fast2Furious
    Author Image
    26,380
How much?? Apply ourselves DIY izzit??  or only at your place???
Strange, since Feb 2017 no one commented on your products??
#5
Posted 13 May 2017 - 11:19 PM
newagepolish
  • THREAD STARTER
  • Premium member
    newagepolish
    Sponsor
    Author Image
    51
Hi,
you may pm us on ur vehicle model to get a quote.
We are at:
http://www.mycarforu...ace-protection/
This is a platform where we showcase and promote our products! usually customer will Pm us directly.
Thank You,
New Age Polish  [thumbsup]
  • 1
Back to New Age Polish  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: car, coating, car wash and 6 more...
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
