flashbang Turbocharged March 12, 2017 Share March 12, 2017 Ok, let me deliberate if want to really go for rinseless. I am still doing rinseless as I need to finish up the bottle first, don't waste... ↡ Advertisement Link to post Share on other sites More sharing options...
Kklee 6th Gear March 12, 2017 Author Share March 12, 2017 I am still doing rinseless as I need to finish up the bottle first, don't waste... Hmm.... the bottle is staring at me. Maybe I will re-purpose it. Link to post Share on other sites More sharing options...
flashbang Turbocharged March 12, 2017 Share March 12, 2017 Hmm.... the bottle is staring at me. Maybe I will re-purpose it. Is it optimum no rinse? That's what I'm using. Can be repurposed into a quick detailer, much cheaper than what you can find outside based on the dilution ratio. 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear March 12, 2017 Author Share March 12, 2017 (edited) Is it optimum no rinse? That's what I'm using. Can be repurposed into a quick detailer, much cheaper than what you can find outside based on the dilution ratio. Yeah, that's the one. Any comments using that as a rinseless? As clean as normal wash? Edited March 12, 2017 by Kklee Link to post Share on other sites More sharing options...
flashbang Turbocharged March 12, 2017 Share March 12, 2017 Yeah, that's the one. Any comments using that as a rinseless? As clean as normal wash? It's clean, but still trying to cross the hurdle of rubbing the dirt around using cloths... By the time I'm done the cloths are black, especially the one I use for 4 rims, totally change colour to black. For body I use 3 cloths, 1 for glass, top and bonnet, 1 for side and front, 1 for other side and rear. Link to post Share on other sites More sharing options...
Maddriver 4th Gear March 13, 2017 Share March 13, 2017 Bro flashbang & kk, you can use ONR as a clay lub. Many ways for using this thing..I have some customers who dilute it in spray bottle, spray on surface and let is dwell for 5 mins and then use water to wash.. I normally use sponge to wash and then a mf cloth to wipe dry.. Link to post Share on other sites More sharing options...
flashbang Turbocharged March 19, 2017 Share March 19, 2017 Bro flashbang & kk, you can use ONR as a clay lub. Many ways for using this thing..I have some customers who dilute it in spray bottle, spray on surface and let is dwell for 5 mins and then use water to wash.. I normally use sponge to wash and then a mf cloth to wipe dry.. How much to use each time for a wash? Feel like it's a waste as I follow instructions to mix 2 oz with 2 gallons of water, but after car is clean feels like a lot of solution left and it's wasted as I pour it away. Should I use 1 gallon and 1 oz instead? I don't have any containers to keep the solution for reuse, else I would as I rinse off the cloths in another pail of water, so the solution is pretty fresh Link to post Share on other sites More sharing options...
Kklee 6th Gear March 23, 2017 Author Share March 23, 2017 How much to use each time for a wash? Feel like it's a waste as I follow instructions to mix 2 oz with 2 gallons of water, but after car is clean feels like a lot of solution left and it's wasted as I pour it away. Should I use 1 gallon and 1 oz instead? I don't have any containers to keep the solution for reuse, else I would as I rinse off the cloths in another pail of water, so the solution is pretty fresh If 1 bucket, better don't re-use. If 2 buckets (with or without lots of microfibers), 1 gallon is enough. If I use it as a pre-rinse, likely I get a BIG capacity pressure sprayer. After spraying as a pre-rinse, I can pour out for the wash. The remainder can be left inside the pressure sprayer for next round or into bottles for claybar lube. Link to post Share on other sites More sharing options...
ValentinoRyan 1st Gear April 14, 2017 Share April 14, 2017 not a fan of rinseless car wash.. generally i'll wash my vehicle with a two bucket system follow with quick wax to "repel" the dirt. Rinseless use up too much product IMO. Link to post Share on other sites More sharing options...
Ake109 6th Gear June 11, 2017 Share June 11, 2017 (edited) I wondered if it is technological or commercial reason that car paintwork remains roughly the same for the past few decades. With no many innovation why our car paintvwork still require period washing and polishing. If NASA can send a painted rocket into space and get back for re-use, I wondered why their paint technology had not filtered down. I have given up sending my cars to AD for their special polish that promise to last 6 months or some to a year. If you constantly part under a cover, generally the polish will last as what it claims. But most times our cars are often out in the open. Have you also notice our oven which can heat up to several hundreds of degrees centrigrade but the paint work still looks the same after several years of usage. Maybe oven company know something that we don't. The oven isn't painted on the inside is it? The outside doesn't get that hot. But if you want to talk about paints on other products. If you look at anything from cans to household equipment to walls, anything left exposed to the elements (like cars mostly are), none of them can last for several years without fading. The fact that our car paints can stay glossy for years while having to tahan UV, acidic rainwater, dust and road debris hitting it at highway speeds and having to be able to stay elastic to flex with heating and cooling as well as the car panels inherent flex as the car hits bumps and humps and twists as it moves. Its quite a feat. Edited June 11, 2017 by Ake109 1 Link to post Share on other sites More sharing options...
Buadongdong Twincharged July 6, 2017 Share July 6, 2017 Free advertisement ah?? @radx Alert pls 1 Link to post Share on other sites More sharing options...
RadX Moderator July 6, 2017 Share July 6, 2017 Free advertisement ah?? @radx Alert pls tks bro killed Link to post Share on other sites More sharing options...
Dany321 Neutral Newbie April 24, 2018 Share April 24, 2018 Rinseless car was has its place as a maintenance type wash. Anyone try AMMO's NYC FROTHe formula? ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
Optimum No Rinse Wash & Shine
