  • 1
  • Search this thread
  • Reply to this topic
16 replies to this topic | 3 praises
#1
Posted 20 April 2017 - 09:54 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    2nd Gear
    Author Image
    186
Hi guys,
I am quite new to In Car Entertainment. I always wanted a better sound system for my vehicle but not gonna go too deep into it.
With the help of some friends we managed to install the following used items. ( KIA Optima K5 )
We have installed the following items
1)https://www.pioneer....oduct=TS-A1606C
02 sets of above. Hence my vehicle currently has 4 speakers and 4 tweeter.
2) Used Sony subwoofer in installed boot. Ancient big ass type. ( Powered )
All items are currently connected to my stock HU.
Now I am looking for one last piece of equipment to enhance my music listening experience.
May I enquire if changing HU or adding an AMP would be more significant?
Thanks in advance.
Edited by Lightsabre, 24 April 2017 - 09:13 AM.
#2
Posted 21 April 2017 - 10:00 AM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    281
What's your current headunit now?
#3
Posted 21 April 2017 - 11:08 AM
Ragingbull
Hi guys,
Thanks in advance.
I have a pair of this hooked to my stock HU + mini 4ch amp from pioneer, even bridged them for more power, still the result wasn't very favorable.
IMHO I guess replacing the HU first would help in a better way.
#4
Posted 21 April 2017 - 01:36 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    2nd Gear
    Author Image
    186
Stock factory HU.
#5
Posted 21 April 2017 - 02:09 PM
Ishiwgao
  • Premium member
    Ishiwgao
    3rd Gear
    Author Image
    357
Stock factory HU.
i dont know about Kia Optima HU, but nowadays car HU size not standard (at least for newer cars). make sure your HU size can fit those aftermarket 1 DIN or 2DIN units.
If can, i would recommend get a new HU rather than amp. an amp only boosts the signal to your speakers, but if the origin of your sound quality (from HU) is not what you like, then boosting or not will not help you any more. if possible, go to a shop where u can test different HUs with you current set of speakers and listen to which one give you the best kind of sound that you like. of course, make sure your HU can support your speakers (at least minimally).
after you change HU and you still want better quality, then you can move on to changing your amp to improve signal to noise ratio etc.
#6
Posted 21 April 2017 - 02:30 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    2nd Gear
    Author Image
    186
I have checked around. My ride is indeed able to install an aftermarket HU: My current stock HU is able to power up all the installed speakers and subwoofer and I am quite ok with the sound. Hence I am looking into adding an amp to enhance the sound. However I have also received recommendations to replace HU rather adding an amp.
Edited by Goldenvodka, 21 April 2017 - 02:36 PM.
#7
Posted 21 April 2017 - 03:47 PM
Ishiwgao
  • Premium member
    Ishiwgao
    3rd Gear
    Author Image
    357
in some sense, replacing HU also means adding an amp, because if you get a more powerful HU that can output more wattage, then that is the same as getting an amp already. of course, the power output from amp will be much higher than HU, so that's why sometimes adding an amp is necessary to support some new more powerful speaker, and that new speaker is then supposed to give you the nicer sound that you want.
replacing HU just give you more options to play with to cater to what you want to hear, be it the sound quality or more basic things like bluetooth connection to your phone to listen to phone MP3 without connecting etc.
for your case, if i were you, i would just leave it alone and not spend any money adding an amp since you are already ok with the sound. adding an amp will definitely enhance the sound like you said, but probably by a little bit only, and the benefit will not be as apparent to you as much as you think.
#8
Posted 22 April 2017 - 07:59 AM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    281
Bro, mind sharing what's your budget range? Another option u can go into is a processor cum amp.
#9
Posted 23 April 2017 - 12:11 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    2nd Gear
    Author Image
    186
About 300 max with installation?
#10
Posted 23 April 2017 - 06:02 PM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    281
300 with installation wun get u a good headunit to begin with.. My suggestion is save more $$ and 1 shot get a processor cum amp with installation that should cost in the region of around 1.5k.. But must go to the correct installer else $ wasted..
If u insist on spending the 300 now, i can assure you it'll be $$ down the drain.. Been there, done that... Hehee...
Listen to others setup to get an idea of how far away your setup is from theirs. There are also some cheap setup that sound much better than expensive setup. $$ is not everything in ICE, but it do plays a big part in buying you the proper stuffs.
#11
Posted 24 April 2017 - 10:01 AM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    2nd Gear
    Author Image
    186
Thanks. I have been reading up DSP since the last post.
Seems that DSP is the way to go instead of spending the amount of $$ on a HU. As I am very comfortable with the original HU and wish to keep the original look.
#12
Posted 24 April 2017 - 01:06 PM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    281
Good choice bro..
Let me know if u wanna listen to a 2 way simple setup with dsp..
I can help u arrange with friend (think his is stock headunit too)
Not to poison you, but to let u know what to expect when u wanna spend 1k+. But i'm sure u will kenna the poison. U can try mine too (3 way setup)
#13
Posted 24 April 2017 - 01:14 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    2nd Gear
    Author Image
    186
Good choice bro..
Possible to PM me which audio shop is specialize and have a big range of DSP to audit before committing?
TIA
#14
Posted 28 April 2017 - 11:44 AM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    2nd Gear
    Author Image
    186
After much considerations. I proceeded with the following.
1) Stock HU
2) DSP with build in AMP
3) Full active setup for all my speakers/tweeter and subs
Overall very satisfied with the results.
The next poison will be a new set of speakers/tweeter to replace my entry level pioneer speakers in the front and an audio card to expand my DSP hence the phone will talk directly to the DSP instead of going through the HU.
Edited by Goldenvodka, 28 April 2017 - 11:45 AM.
#15
Posted 28 April 2017 - 10:23 PM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    281
Good choice bro..
So what dsp u use?
#16
Posted 29 April 2017 - 02:13 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    2nd Gear
    Author Image
    186
I using this
http://www.audiotec-...-eight-dsp.html
Reason being I wanted to run a full active set up with DSP.
Edited by Goldenvodka, 29 April 2017 - 02:15 PM.
#17
Posted 29 April 2017 - 05:13 PM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    281
Ic.. Didn't consider Audison 8.9
  • 1
Back to In-Car-Entertainment  ·  Aftermarket Top Reply to this topic
Pioneer AVH-175DVD
Pioneer AVH-175DVD  |  Rating   Submit Review
Reviewed by burns_kazuo  |  Neutral Newbie
Simple, easy-to-use, reliable
This is a versatile DVD player that not only plays CDs, DVDs, Radio, it also plays music and videos from iPhone/iPod via the USB link. No complicated functions and its a very basic device which makes your ride enjoyable while keeping you ente... » Read More
Pioneer AVH-1450DVD DVD Player
Pioneer AVH-1450DVD DVD Player  |  Rating   Submit Review
Reviewed by AcuraNSX  |  Clutched
Basic- gets the job done
Backup camera attached, ability to access iPod functions, USB drive, mp3 CD, and the usual radio. Functionality is what you expect
Related Product Guide search on sgCarMart.com : DVD Player, Multimedia Player
Quick Reply
Tags: kia, kiahu, amp, replace and 2 more...
