Orangee 2nd Gear May 5, 2017 Share May 5, 2017 SGP. i very zhi tong one, never road hog and always give way to car catching up from behind me. Hmmm... but still, many drive without checking their rear! Seriously! Or maybe its outright selfish.Sadz... Sg law wont catch road hogger, but most likely to catch the ones trying to over take road hoggers! ↡ Advertisement Link to post Share on other sites More sharing options...
Cypher 4th Gear May 22, 2017 Share May 22, 2017 thanks for the recommendationSecond that, and long life too compared to Osram equivalent bulb(Silverstar). Link to post Share on other sites More sharing options...
zaidi4ever Neutral Newbie June 10, 2017 Share June 10, 2017 just dont exceed 4300ktry to find the max brightness on onemotoring and lta websites, could not find it. thanks. Link to post Share on other sites More sharing options...
Apersim Neutral Newbie July 29, 2017 Share July 29, 2017 Purchase 4300k color temperature LED headlights Link to post Share on other sites More sharing options...
AndreTang Neutral Newbie August 2, 2017 Share August 2, 2017 recommendations Link to post Share on other sites More sharing options...
Apersim Neutral Newbie August 16, 2017 Share August 16, 2017 At the same power, halogen is the least brightness compare to HID and LED Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear August 17, 2017 Share August 17, 2017 (edited) The main function of headlights on most modern cars are not to light up the entire space in front of you. It is just there to be bright enough, but not glaring, for awareness. The light is to allow others, especially those blur blur pedestrians to know your car is coming, so that they can stop using their mobile phone while crossing the road. On unlit roads, just go slow. That's the whole idea. If you look at these new Audi with LED head lights, do you really think they can fill up the area in front of their car too ? And by the way, the whiter the lights are , the dimmer it seems to be. It's the eye's color response, eye response best in the Yellow zone, so with yellowish light being the best responsive for human eyes. Don't go white or bluish, go slightly golden / yellowish bulbs. These modern white LED lights are a curse to the automotive industries because they are deviating away from human's best, they eyes. If you ask me, I would honestly tell you, it's a conspiracy between LED makers and automotive car makers. LED are expensive and demands more electronics control than a simple halogen light bulb which only requires 2 wires - 12V and ground. What led to the LED is basically a big scam out there. Edited August 17, 2017 by carloverguy2017 1 Link to post Share on other sites More sharing options...
Ronald728 Neutral Newbie August 3, 2021 Share August 3, 2021 I hate being blinded by the oncoming driver, but I installed LED headlight on my Corolla. All that matters for LED conversion is "light pattern". A LED bulb with perfect pattern projected doesn't blind others. The bulb that I use is HYUGA U9. Link to post Share on other sites More sharing options...
awhtc 6th Gear August 4, 2021 Share August 4, 2021 16 hours ago, Ronald728 said: I hate being blinded by the oncoming driver, but I installed LED headlight on my Corolla. All that matters for LED conversion is "light pattern". A LED bulb with perfect pattern projected doesn't blind others. The bulb that I use is HYUGA U9. LED Headlamps Light emitting diodes (LEDs) are semiconductor light sources that produce light when an electric current flow through them. In recent years, vehicle manufacturers have started to introduce LED technology to headlamps. LED headlamp bulbs require less energy, and have a longer lifespan compared to halogen and HID headlamps. LED headlamps produce light that is close to the colour of daylight, providing clearer visibility at night. LED headlamps require cooling systems such as heat sinks or fans to keep cool. This makes the LED light physically larger than a halogen bulb, so there may be compatibility issues when installing LED lights into headlamp housings designed for halogen bulbs. Like other headlamps, LED headlamps must meet international standards and be factory-fitted by vehicle manufacturers, to ensure that they are properly aligned and operate safely. https://onemotoring.lta.gov.sg/content/onemotoring/home/owning/modification.html#HIDLED Link to post Share on other sites More sharing options...
Beregond Supersonic August 4, 2021 Share August 4, 2021 2 minutes ago, awhtc said: vehicle manufacturers have started to introduce LED technology to headlamps. LED headlamp bulbs require less energy, and have a longer lifespan compared to halogen and HID headlamps. while this is true. manufactures dun change their car to LED because of it. the main and key reason is it look nicer. or ppl feel they have the latest tech, u see the comment, many bros already say they skip cars thats not using LED. Link to post Share on other sites More sharing options...
Ct3833 Supersonic September 25, 2021 Share September 25, 2021 On 8/3/2021 at 4:26 PM, Ronald728 said: I hate being blinded by the oncoming driver, but I installed LED headlight on my Corolla. All that matters for LED conversion is "light pattern". A LED bulb with perfect pattern projected doesn't blind others. The bulb that I use is HYUGA U9. It is ok if the headlights are the projector headlights, but the reflector headlights will cause a lot of glare if one changes them to brighter bulbs. I replaced my headlights and reverse bulbs to LED, it passed the LTA inspection using that test equipment but the guy told me I must replace them to halogen bulbs when I return for inspection next year ↡ Advertisement Link to post Share on other sites More sharing options...
Vicom Annual Car Inspection
Energy Savings / Non Heat up LED Headlights Technology
LED head light
LED head light
Theives Gouged Out This Poor Porsche Taycan's Headlights
Annual LTA inspection for commercial vehicles
Toyota Camry
Toyota Camry
Are LED lights subject to brightness checks?
